Old 04-19-2008, 09:42 PM   #1 (permalink)
3Sfever's Avatar
Drives: '91 Stealth TT
3Sfever level 63Sfever level 63Sfever level 63Sfever level 63Sfever level 63Sfever level 6
Default Should Rear Engine Mount be Offset?
I was looking at rear mount this evening, (thinking about going poly), and noticed the bolt sleeve is not centered . . . Is that normal?
Photo attached.
-Ron
'91 Stealth TT
purchased Aug 2004
3Sfever is offline   Reply With Quote
Old 04-19-2008, 10:05 PM   #2 (permalink)
i can make your vtech cry
turbosprentice's Avatar
Drives: '96 3000gt(base)
turbosprentice Level 2turbosprentice Level 2turbosprentice Level 2
Default Re: Should Rear Engine Mount be Offset?
that seems to be the same with a buddy of mine that we switched out two weeks ago. i guess it's ok?
turbosprentice is offline   Reply With Quote
Old 04-19-2008, 10:11 PM   #3 (permalink)
Damage Control
Stealthee's Avatar
Drives: 1994 Stealth
Trader Rating: (78)
I have a pile of mounts in the garage. I can take a look tomorrow.
Old 05-11-2008, 11:11 PM   #4 (permalink)
3Sfever's Avatar
I pulled the mount out today and noticed that the rubber has a crack in it above the steel sleeve. . . . Now I am REALLY wondering if mine has sunk a little.
Anybody have dimensions of where the sleeve should be, relative to the center of the mount?
Old 05-11-2008, 11:33 PM   #5 (permalink)
Former DSMer - now VR-4er
James92TSi's Avatar
Drives: #388 Red
Trader Rating: (11)
James92TSi Level 7James92TSi Level 7James92TSi Level 7James92TSi Level 7James92TSi Level 7James92TSi Level 7James92TSi Level 7James92TSi Level 7James92TSi Level 7James92TSi Level 7James92TSi Level 7
Pics here might be helpful.
1995 3000GT VR-4: 3SX Polyurethane Motor Mounts Installation
'91 3000GT VR-4 Jackstand Racing League 2008 points leader.
'03 G35 Sport Coupe Retains transmission and full warranty, even with VDC off!
James92TSi is offline   Reply With Quote
Old 05-12-2008, 05:01 AM   #6 (permalink)
In Training
etecnifibre's Avatar
Drives: 99 3/4 Ton Silverado
Trader Rating: (64)
etecnifibre Level 7etecnifibre Level 7etecnifibre Level 7etecnifibre Level 7etecnifibre Level 7etecnifibre Level 7etecnifibre Level 7etecnifibre Level 7etecnifibre Level 7etecnifibre Level 7etecnifibre Level 7
Mine is offset like that. It, too, was ripped. I replaced it with a solid mount.
etecnifibre is offline   Reply With Quote
Old 05-12-2008, 04:22 PM   #7 (permalink)
3Sfever's Avatar
Originally Posted by James92TSi View Post
The photos in that link, as well as others I found today, all appear to show the bolt sleeve to be in the center of the rubber.
Does anyone have a relatively new OEM, or a solid mount that could be measured from the base, up to the center of the bolt sleeve?
Old 05-14-2008, 11:46 AM   #8 (permalink)
rock on, yeah rock on
spfan's Avatar
Drives: 4 x 22,000 lbs jets
Trader Rating: (6)
spfan Level 2spfan Level 2spfan Level 2
i think it's, at least partly, due to the angle you're looking at it from. you're kinda looking "up" at it. so it's a little bit of an optical illusion.
Dyno Collection Thread
1993 Dodge Stealth ES, White, April 2002 - April 2005, SOLD 1 of 53
1993 Dodge Stealth TT, Black, Since April 2004, 1 of 5 ever made more rarity info
2003 Subaru Forester 2.5X, Blue, Sept. 2005, Daily Driver with 165 HP of Fury! At least it's AWD.
305 awhp, 325 awtq(BPU minus full catback exhaust)Mods at that time
13.02@104.67 (9bs, dp, fipk, 15.5 psi, bov, no cats, streetmax clutch, 1.77 60', decent conditions, full weight (even spare tire/jack)
13.09@105.08 (1.80 60', same conditions as above)
Beyond BPU: (meaning upgraded turbos/fuel/etc) before engine rebuild Mods at that time
12.38@113.00(20 psi, 110 octane, massive knock above 6k rpms)
12.41@115.10(ditto)
After Rebuild: Current Mods Dyno Tune by IPS
12.8@108 (12.5 psi dropping to ~11 @redline, 2.0 60', pump gas, my tune)
spfan is online now   Reply With Quote
Old 05-14-2008, 12:35 PM   #9 (permalink)
Paid Member
Drives: 91 GTO SR
Trader Rating: (6)
kylejw Level 4kylejw Level 4kylejw Level 4kylejw Level 4kylejw Level 4
I just installed solids, I believe my rear mount was undamaged. I'm at work right now but when I'm home I can measure it. PM me if I don't do it tonight because that means I forgot
kylejw is online now   Reply With Quote
Old 05-14-2008, 12:45 PM   #10 (permalink)
Kibwe Walker's Avatar
Drives: 93 RT/tt
Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7
Maybe it is suppose to be centered.
Its rubber though, add heat, weight, and torsional forces from the engine twisting around in the engine bay and 10-15 years of service and I would guess it won't be in the center anymore and its probably leaning towards the area where weight and gravity will take it.
His - Red 93 RT/tt
Mods: Hallman's MBC @ 16 psi, turbo XS type H BOV, stillen dp, custom exhaust, Spec stage 2 clutch, RPS FW, 3sx lightweight crank pulley, BCP7RES-11 @ .030 gap, autometer gauges, slightly gutted mas, dsm SMIC's, ACPT 1 piece CFDS, Tein S springs, pte 580 inj's, safc neo/SITC, 13t's, hotwired walbro, maximal performance solid motor mounts, DR plenum spacer.
Hers - BPU Green 94 vr4
Kibwe Walker is offline   Reply With Quote
