Old 05-21-2008, 01:20 PM   #1 (permalink)
Wyld is an unknown quantity at this point
Default Shaking Problem
I have a 1993 Mit 3000 GT SL which I have owned for 8+ years. It started occassionally shaking/shuddering when I stop at a traffic light, or shift into reverse while parallel parking. I paid a mechanic to find the problem and he couldn't.
Has anyone else had this problem, or know what it might be and how to fix it?
Thank you!
Wyld
Wyld is offline   Reply With Quote
Old 05-21-2008, 04:34 PM   #2 (permalink)
GTONW is good to go
Colt45_GTO's Avatar
Drives: Black '91 TT
Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7
Default Re: Shaking Problem
in what way shaking is it transmission or brake shake?
Colt45_GTO
Semper Fidelis
go register at www.gtonw.co.uk
Originally Posted by Stealthee View Post
Seriously. Just like people will talk down to you when you post about getting a ticket.
People on here need to learn when to shut the fuck up and stop being hypocritical.
Colt45_GTO is online now   Reply With Quote
Old 05-21-2008, 04:55 PM   #3 (permalink)
noob-saibot
my3kgtvr4's Avatar
Drives: the women crazy
my3kgtvr4 Level 2my3kgtvr4 Level 2my3kgtvr4 Level 2
my car shakes to all hell when I stomp on the breaks, I dunno why.
92 pearl white 3kgt vr4: 450cc injectors, safc, mbc, actual working boost gauge, HKS SSQV BOV, full 3 inch from the turbos back, greddy turbo timer, warlboro 255, steel fuel line, bad driver mod, and about 14lbs of boost
my3kgtvr4 is online now   Reply With Quote
Old 05-21-2008, 04:59 PM   #4 (permalink)
ESR/TWS6 Stealth owner
1991StealthR/T's Avatar
Drives: 91' Stealth eSR/T
1991StealthR/T Level 11991StealthR/T Level 1
my3kgtvr4- You most likely warped rotors.
1991 Dodge Stealth R/T - Passion Red - Spun bearing soon to be TTFWD
1985.5 Mitsubishi Starion - California Red - Blown head gasket and sat for 10+ years. - soon to be either running or sitting until the Stealth is done.
1991StealthR/T is offline   Reply With Quote
Old 05-21-2008, 06:19 PM   #5 (permalink)
Paid Member
Alt0id's Avatar
Drives: '94 3000GT SL
Alt0id Level 7Alt0id Level 7Alt0id Level 7Alt0id Level 7Alt0id Level 7Alt0id Level 7Alt0id Level 7Alt0id Level 7Alt0id Level 7Alt0id Level 7Alt0id Level 7
sounds like warped rotors if its when you are stopping and you feel it in the steering wheel.
Alt0id is offline   Reply With Quote
Old 05-21-2008, 06:22 PM   #6 (permalink)
Drives: 94 3000GT SL
Offspring is an unknown quantity at this point
either warped rotors or perhaps a broken bolt in the braking system, holding the caliper to the bracket etc etc, also you'll get a vibration when driving if you have bent wheels.
Offspring is offline   Reply With Quote
Old 05-21-2008, 06:23 PM   #7 (permalink)
Paid Member
Alt0id's Avatar
When it shakes like hell, what are your rpms? 400? that would explain why its shaking.
Mine does that if when I shift in reverse sometimes I get really low idle.
Old 05-22-2008, 12:37 AM   #8 (permalink)
GTONW is good to go
Colt45_GTO's Avatar
could be heat spots on the rotors, look for blued patches. could also be the one way valve sticking on the brake helper pipe off the back of the plenum
Old 05-22-2008, 03:44 AM   #9 (permalink)
Cyberwwolf!!
BlackDream's Avatar
Drives: The Blackdream:RT/TT
BlackDream Level 7BlackDream Level 7BlackDream Level 7BlackDream Level 7BlackDream Level 7BlackDream Level 7BlackDream Level 7
I think he mean trasmission shake when he stop at a traffic light and then starts to move or when put reverse to park and start to move ??
If so I've exact same problem here after clutch change, but it seems that most of the shake come from the under center/rear part so i'm going to change driveshaft carrier bearings hope it helps
1992 Dodge Stealth RT/TT
Engine: K&N open intake, polished plenum, powdercoated valve cover, polished radiator cover, painted timing belt covers, red silicone hoses,cold air intake, chrome oil cap,Polished engine cover kit,...
Exhaust:Stainsless steel catback with no mufflers and stock tips look,test pipe.
Interior: Stainsless Stell door sills, autometer gauges.
Suspensions: Tein S.tech springs, -2° camber...
---> http://www.dodgestealth.it <---
BlackDream is offline   Reply With Quote
