Old 04-16-2008, 01:07 PM   #11 (permalink)
King3000gt's Avatar
Drives: 94' 3000gt vr-4
Trader Rating: (7)
King3000gt is an unknown quantity at this point
Default Re: S-AFC help with stock fuel HELP 911
car is still runing like sh*T could some sensors be shot?.. anything please
1994 pearl yellow vr-4
Mod List- 8" k&N intake filter, HKS BOV, Blitz SBC iD III Boost Controller, Fuel Pump Hotwire, Autometer Boost Gauge, TorxMax Front Mount w/Hard Piping, EGR block-off, VAC reduction, Cross drilled and Slotted Rotors, Stillen brake pads, Stillen Downpipe, Stage 3 SPEC clutch,, MSD 8.5mm spark plug wires, and NGK spark plugs
Future Mods- Already purchased-gtpro 357 turbos, Torque Max manifolds and 02 housings, walbro 255fp, Safc neo, RC 550CC fuel Injectors, Maximal Solid Motor mounts, Maximal Transfer Case Bracket
Need to purchase- A datalogger! leaning towards halo... got a hybrid!
King3000gt is offline   Reply With Quote
Old 04-16-2008, 01:59 PM   #12 (permalink)
3S Motorsports
Drives: 95 VR4
WidowMaker level 6WidowMaker level 6WidowMaker level 6WidowMaker level 6WidowMaker level 6WidowMaker level 6
read the manual and make sure you have everything hooked up right, and all of the settings are correct. if you are sure it is correctly wired and setup, than you have a problem with your afc... there is no problem with the car as it runs just fine without the afc
CLICK HERE FOR MONTHLY SPECIAL http://www.3si.org/forum/f1/3s-motor...pecial-435039/
3S Motorsports Is Open For Business
(631) 676-2448
Running the First Pampena 3.5L Stroker
http://www.3smotors.com
-Steve
WidowMaker is online now   Reply With Quote
Old 04-16-2008, 05:59 PM   #13 (permalink)
King3000gt's Avatar
Trader Rating: (7)
yeah i hooked up a friends afc neo and it ran fine! paypal is goingto see another dispute!
