Old 04-15-2008, 08:36 PM   #1 (permalink)
King3000gt's Avatar
Drives: 94' 3000gt vr-4
Trader Rating: (7)
King3000gt is an unknown quantity at this point
Default S-AFC help with stock fuel HELP 911
Just hooked up my afc NEO... car seems to idle ok but when you drive it down the road you cant give more than %5 throttle or the car will pop like crazy, I selected karman but not sure i have it hooked up right as far as the "mas input and output wires" goes! I used the black/white and brown/white wires coming from afc to the afs wire on the ecu
1994 pearl yellow vr-4
Mod List- 8" k&N intake filter, HKS BOV, Blitz SBC iD III Boost Controller, Fuel Pump Hotwire, Autometer Boost Gauge, TorxMax Front Mount w/Hard Piping, EGR block-off, VAC reduction, Cross drilled and Slotted Rotors, Stillen brake pads, Stillen Downpipe, Stage 3 SPEC clutch,, MSD 8.5mm spark plug wires, and NGK spark plugs
Future Mods- Already purchased-gtpro 357 turbos, Torque Max manifolds and 02 housings, walbro 255fp, Safc neo, RC 550CC fuel Injectors, Maximal Solid Motor mounts, Maximal Transfer Case Bracket
Need to purchase- A datalogger! leaning towards halo... got a hybrid!
King3000gt is offline   Reply With Quote
Old 04-15-2008, 09:02 PM   #2 (permalink)
King3000gt's Avatar
Trader Rating: (7)
Default Re: S-AFC help with stock fuel HELP 911
anyone?
Old 04-15-2008, 09:16 PM   #3 (permalink)
daddy's Avatar
Drives: BPU 92TT
Trader Rating: (26)
daddy Level 7daddy Level 7daddy Level 7daddy Level 7daddy Level 7daddy Level 7daddy Level 7daddy Level 7
Switch 'sensor type' to 'karman'
daddy is online now   Reply With Quote
Old 04-15-2008, 10:20 PM   #4 (permalink)
King3000gt's Avatar
Trader Rating: (7)
Am i suppose to hook up the pink and orange wires to the "mas output and input wires" OR the black/white and brown/white to the "mas outpt and input wires"?
Old 04-15-2008, 10:47 PM   #5 (permalink)
King3000gt's Avatar
Trader Rating: (7)
help!!!
Old 04-15-2008, 11:17 PM   #6 (permalink)
King3000gt's Avatar
Trader Rating: (7)
HELLO! anyone with a AFC NEO HELP
Old 04-16-2008, 12:02 AM   #7 (permalink)
King3000gt's Avatar
Trader Rating: (7)
wow! noone huH!?
Old 04-16-2008, 12:37 AM   #8 (permalink)
King3000gt's Avatar
Trader Rating: (7)
Ive got a 94 hybrid ecu ... all fuctions seem to work fine rpm, throttle, etc... Im tryint to run this on a STOCK Fuel system, wont be stock for long!
HELP!!!
Old 04-16-2008, 01:41 AM   #9 (permalink)
Damage Control
Dark-Hawk's Avatar
Drives: `92 240SX
Dark-Hawk Level 7Dark-Hawk Level 7Dark-Hawk Level 7Dark-Hawk Level 7Dark-Hawk Level 7Dark-Hawk Level 7Dark-Hawk Level 7Dark-Hawk Level 7Dark-Hawk Level 7Dark-Hawk Level 7Dark-Hawk Level 7
Oh my God, would you calm the fuck down and give it at least a day for people to wake up and reply?
SOLD
Walbro 255, 450CC injectors, S-AFC, 300M output shaft, SPEC II clutch, RPS flywheel, ATR single shot exhaust, ATR downpipe, saner sway bars, PRM 3 pt strut bar, Greddy Type-S BOV, stillen cross drilled rotors, stillen brake pads, koyo rad
Dark-Hawk is online now   Reply With Quote
Old 04-16-2008, 09:38 AM   #10 (permalink)
King3000gt's Avatar
Trader Rating: (7)
ok booklet says to hook up:
Red wire: Power supply - CHECK
Green wire: rpm signal - AFC SHOWS RPM- CHECK
Red and white wire: Power supply - CHECK
Gray wire: Throttle signal - AFC SHOWS THROTTLE- CHECK
Brown wire: Grounding - CHECK
Black wire: Grounding - CHECK
Brown and white wire: Karman signal output - CAR SHOWS THERE IS A KARMAN SIGNAL NO VALUES THOUGH
Black and white wire: Karman signal input - CAR SHOWS THERE IS A KARMAN SIGNAL NO VALUES THOUGH
Orange wire: Illumination power - DID NOT HOOK UP NOT SURE WHICH WIRE TO USE
Car still runs like crap when you try and drive it normally, ive checked wires everything seems ok... i even hooked the karman signals back up stock and the car ran perfect so its got to be something with my afc just dont know
