Old 05-14-2008, 08:29 PM   #1 (permalink)
Baerdad's Avatar
Drives: 1994 3KGT SL ATX
Baerdad is an unknown quantity at this point
Default Replacing thrust washer
We are in the middle of replacing the rod and main bearings and this is going well; except on replacing the thrust washers which side does the groove face? On the 3.0 engine there are 4 two on top and bottom between the 3&4 and 5&6 cylinders.
Baerdad is offline   Reply With Quote
Old 05-14-2008, 09:43 PM   #2 (permalink)
Baerdad's Avatar
Default Re: Replacing thrust washer
Bump for an answer?
Old 05-14-2008, 10:06 PM   #3 (permalink)
1stStealthN/A's Avatar
Drives: 94 SL, 92 VR4, 92 TT
1stStealthN/A is an unknown quantity at this point
The oil grooves face the crankshaft, the stamped numbers face the block. Make sure you have the tabs on two of the thrust washers installed correctly on the block and girdle.
1stStealthN/A is offline   Reply With Quote
Old 05-14-2008, 10:13 PM   #4 (permalink)
Baerdad's Avatar
The weird part is on the set we received, that works on the side facing the 3 & 4 cylinders but on the 5 & 6 cylinder the bearing with the bearing lock only fits with oil grooves toward the block. Did I just get a bad set?
