Replace front main seal without removing oil pump? - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 02-14-2008, 09:01 PM   #1 (permalink)
gearheadvr4's Avatar
Drives: Topless
gearheadvr4 is an unknown quantity at this point
Feedback Score: 37 reviews
Default Replace front main seal without removing oil pump?
Can you replace the front main seal (maybe also called crankshaft seal?) without removing the oil pump? If you have the crank pulley and timing belt off already, that should be pretty easy right?
Anyone had success with oil seals from NAPA or Autozone?
gearheadvr4 is offline   Reply With Quote Quick reply to this message
Old 02-14-2008, 09:22 PM   #2 (permalink)
hellbent in a dodge Viper
mikes2nd Level 1mikes2nd Level 1mikes2nd Level 1
Feedback Score: 35 reviews
Default Re: Replace front main seal without removing oil pump?
i dont see why just make sure you use some kind of seal installer or make one of some sort. I make my transfer case seal tool out of pvc pipe.
Note the exact depth the seal is seated at.
Go to a "seal" company and get a couple. These seals are so tight you can often destroy a couple trying to get them in. Make sure you get the exact size seal.
Use a screw (big sharp thread. Pop a small hole in with a small nail, then screw it in). Use vise grips to finish getting the seal out.
mikes2nd is offline   Reply With Quote Quick reply to this message
Old 02-14-2008, 09:41 PM   #3 (permalink)
3/S tech
TTstealthracing's Avatar
Drives: cops crazy
TTstealthracing Level 1TTstealthracing Level 1
Feedback Score: 23 reviews
I would use the dealer seal only but thats just me
2 wheels spinning 4 wheels winning
AFFORDABLE ECU REBUILDS
QUALITY TRANS REBUILDS DONE CHEAP
Auto Velocity
301-991-6501
TTstealthracing is offline   Reply With Quote Quick reply to this message
Old 02-14-2008, 10:19 PM   #4 (permalink)
Drives: Topless
I will have to check dealer prices. I'm in the hole so much with this car already with all these little things really adding up.
Old 02-14-2008, 10:25 PM   #5 (permalink)
Forum user
streamlnauto's Avatar
Drives: 1993 VR-4
streamlnauto is an unknown quantity at this point
Feedback Score: 15 reviews
Yeah, but those costs double and or triple when you use equipment that leaks/fails.
streamlnauto is offline   Reply With Quote Quick reply to this message
Old 02-14-2008, 10:37 PM   #6 (permalink)
mk_
Drives: Rx-8
mk_ is an unknown quantity at this point
Feedback Score: 12 reviews
I'm SOHC and yes I was able to get the crankshaft seal off without removing the oil pump.
Its doubtful that you are SOHC also, but what I had done was with the tensioner spring (sohc only) i shaved it off until it was like a pick. I stuck it in at such an angle to puncture and get it good enough to pull out. I didn't get it on the first try, or the tenth. but it eventually came free. Put the other one on, and with an appropriate size socket, you can hammer it on (rubber mallet maybe)
I got the 'front main seal' at Advanced Autoparts (for once they got something right for me ) And it was in stock, somehow.
Good luck,
Michael
For sale (PM me):
EA 200amp HO Alternator
Street Wires 0/1 Gauge Power wire (2 runs)
Knuconceptz 0/1 Gauge Ground wire
mk_ is offline   Reply With Quote Quick reply to this message
Old 02-14-2008, 10:39 PM   #7 (permalink)
Drives: Topless
Ever leak on you?
Old 02-14-2008, 10:47 PM   #8 (permalink)
mk_
Drives: Rx-8
Well, after my rebuild, needless to say I was pretty pissed to see my car pissing oil all over after having the car run for 5 minutes. I thought it was the oil pump itself or the oil pan. Either way I thought I was looking at another 6-7 man hours of work just to get the thing running right so I wasn't too happy. Me and my buddy determined it was actually the front main seal based on how it was leaking and took care of it the next day. took about two hours cause I had to take timing belt and what not back off. again this is sohc = cake... but this was back in August when it was done and believe me its the least of my worries now... no problems at all with leaks.
Old 02-14-2008, 10:50 PM   #9 (permalink)
Cougar Hunter
EMC 3000GT's Avatar
Drives: 3000GT FWD TT
EMC 3000GT is an unknown quantity at this point
Feedback Score: 9 reviews
The OEM seal is $ 8.48
http://www.horsepowerfreaks.com/oem/...tion=000393221
they will ship tomorrow.
All you need is a flat head screwdriver and a hammer and some oil. Lube the seal press it in gently.
You do not need to remove the oil pump. But if I remember correctly you do have to remove the timing belt from the bottom bracket. So you might as well change that.
My only question though, is why is the seal leaking?
Has it been punctured?
EMC 3000GT is offline   Reply With Quote Quick reply to this message
Old 02-14-2008, 11:03 PM   #10 (permalink)
Cougar Hunter
EMC 3000GT's Avatar
Here is the page out of the service manual. If you want any other pages let me know.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Date of Birth
Month Day Year
Privacy
Log-in
Random Question
