#41 (permalink) | |
Staying in the Family
You should go sit in the corner and think about what you have said No shit people buy the best VALUE, not the cheapest shittiest part, do you really think that rubicon, the company who produced all these caps thought they designed an inferior product? I doubt it, they have liability issues too.You have no grasp of the situation at hand and are a drama queen, come back with an education and don't just blindly blame the large companies because they are large companies. No ones pockets are bottomless, everything comes at a cost, there are real people that run those companies with families and lives of their own, not some faceless emotionless asshole who only wants your money. The cars have to be produced cheap enough people will buy them (they are a mitsubishi product, not a ferrari) and this comes with certain compromises. These cars are getting old, I imagine many of the ecu problems are not ecu related but a side effect of something else going out taking the ecu with it. Grow up
![]() 92 VR4 Blacked out with a 98 conversion dr900's Fully forged 3.1L Stage 3 Heads 98 Jeep TJ 37's Locked with all the toys Cheap, Fast, Reliable.... You can only have two |
#42 (permalink) |
i don't even know...
stop kicking the guy in the jimmies; if he wants to spearhead an effort to replace one of our many shitty components with one marginally less shitty, then hats off to him and go for it. there's no need for our many e-litigators to expound on the numerous reasons why they wouldn't 'take the case' at their respective 'law firms' of solid repute; you know if it worked you'd have your asses camped out at the nearest mitsu dealership to get shitECU v2.0.
1991 VR4
go-fast stuff k&n snorter; atr downpipe; atr cat; blitz dsbc-r; greddy type s bov; egr blockoffs; seattle short shifter; southbend dxd clutch; '99 lifters; forged 2nd gen crank; 3.1L ross forged pistons; cometic head gaskets; 3-angle, etc. heads; 14b's; jpdc plates, external dumps; ss oil returns; 3" maf/maf-t, dejon blowthru setup; IPO fuel pump hotwire kit; not-go-fast stuff hks turbo timer type 1; autometer a/f guage, boost guage, egt gauge; cross-drilled front rotors; infinity reference 6.5" w/ mtx thunder 50wx2, infinity reference 6"x9" w/ mtx thunder 50wx2, infinity reference 10" subs; clarion 7" dvd/mp3/cd; 18x8.5 5zigen fn01r-c's w/ 245/40/18 sumitomo htr-z II's; katzkins dark charcoal/red leathers; mobo charcoal/red shift boot, ebrake boot; 2nd gen rear bumper & core; sitting around/eventually coming stuff UR UDP; PTE 680cc's; midnight haze reverse gauge face, red needleglow kit; denso fuel pump; race concept 2nd gen slotted/dimpled rotors, SS brake lines; mtx thunder 265wx2; acpt 1-pc cfds; 24x12x3 fmic, ppe pipes; ctech ss pump-> filter line; maximal perf. solid mounts; topline grounding wires; devil's own meth injection; cianci '99 spoiler; ips evo316g kit; aem wideband; 2nd gen rear garnish; cianci triple pod pillar; 1988 ford ranger go-fast stuff 2.3L intercooled turbo engine swap; mbc@~10 psi; k&n snorter; 17" fan; 2.5"-3" exhaust piping; 3" high-flow cat; no muffler; resonator tips exit in front of rear wheel; custom hood scoop; not-go-fast stuff autometer a/f guage, boost guage; cerwin-vega 5x7's; pioneer 50wx2; blaupunkt cd head unit; 2003 dodge dakota sl(u)t go-fast stuff flowmaster 40(?) series loudass muffler; perpetually falling-off muffler-back pipes; some random cold-air snorter; |
#43 (permalink) | |
Moderator
I myself have NEVER had a problem with a bad ECU and I've owned a few 3/Ss including 1Gs. Perhaps I've just been very lucky. I have a spare hybrid ECU for my car just in case and I take responsibility for my car's condition after the warranty. Sure I would love to get a free/rebuilt ECU from Mitusibishi, but I would NEVER expect Mitsubishi to replace an item that is prone to failure in any electronic device. And the physics of electricity and computers isn't as cut and dry as the mechanics of a transfer case and where it fails. Things like spikes in amperage (both high or low) can weaken or damange electronics. These aren't visible so it's very simple to place the blame. Could it be the caps and the caps alone? Sure it could. Could it be something external to the ECU causing reoccuring problems in some cars by weakening the components of the ECU to the point of eventual failure? Sure it could. What's to say that people with ECU problems don't have an alternator that is hitting the ECU with an extra amp or two of current even for a split second? Or it's hitting a couple amps less? Brownouts in your home are just as dangerous to electronics as a spike with too much current. I could come up with a list of logical possibilities for what could cause the ECU to fail and I'm not an automotive engineer. Just think of the things Mitsubishi could come up with. And to boot it's NOT under warranty of ANY sort from the factory. And the comment about the manual not telling you to check the ECU for capacitors: Of course not. If they put a list of things to check for possible failures a decade after the warranty expired your glovebox wouldn't be able to close with the manual in it. I don't check my main and rod bearings every few months, yet see people with bearing issues all the time. Is this also Mitsubishi's fault? Should they give everyone with a 2-bolt that had a non-forged crank and looser tollerances a new motor after 100k miles because it's a possible cause of 2-bolts spinning bearings? Would you expect that? I don't see how this is ANY different as power loss from a rod and piston blowing out of the side of the block. You would have a sudden loss of power just like a dead ECU. How are the results of this failure any different from that of the ECU? As much as it sucks and my car is a possible candidate for an ECU failing based off your information, I do not and would not expect handouts if it did fail. Those of us with 3000GTs and Stealths aren't driving new cars with warranties where things will be fixed all the time, free of charge, on a whim. Please, give ME a break, if this is what you really expect then you need to consider a new car with a full warranty.
- 94 R/T Turbo
- 93 VR-4 - 94 R/T - ![]() Last edited by TooFast4Radar : 02-21-2007 at 05:29 PM. |
#44 (permalink) | |||||
King Detail
![]() So what if these cars are getting old. I have owned 3 other 10 year or more older vehicles all of which had an array of problems and not 1 of them had ECU's burning out all the time. You've made your point so feel free to just ignore this thread. Notice I won't bow to your level and tell you that you need an education. No matter who worked for Mitsu or Rubicon I have no doubt there were good people there below the line of mgmt and senior mgmt. I'm not gonna sit here and pretend the world exists as you've said because I've worked for money grubbing corporations and I know what they are. This isn't about getting back at them. This is about a faulty part that shouldn't be faulty. A fucking TV is one thing, but the motherboard - brain of a car that is supposed to get a human life from A to B without consequence ON MOST DAYS is another thing. Too often people sit and do nothing and take it in the ass because they don't have the power to fight these GREEN POCKET EMOTIONLESS assholes and I do not blame those working at the bottom of the org charts. Its Mgmt and those watching the corporate bottom line while pretending to try and uplift spirits by having Hawaiian t-shirt Fridays. If you have nothing productive to contribute to this thread that will help facilitate a recall then just stop posting. When does BEST VALUE and CHEAPIST SHITTIEST part differ? Where's the line? Sure I always try to go 1 notch up from the cheapest for this reason, but how do you know what they had to chose from? I don't and I admit that, but maybe in the pursuit of this we'll find that sort of thing out. If NOTHING comes of this at all SO WHAT. At least I will have tried along with whoever gets behind me and for the betterment of the platform. What if this results in a stronger ECU, one which will not buckle to other parts going bad? STILL you cannot prove to me that it isn't the ECU making the other parts go bad to begin with - which is likely the case since we know for a FACT that substandard parts were used to make these ECUs.
#45 (permalink) | |
Mr. Chocolate...
1997 Black Top Red Mitsubishi 3000GT VR4 - 93k miles and 100% stock
Cars Owned: 1992 Dodge Stealth RT (sold) 1992 Mitsubishi 3000GT VR4 #1 (parted) 1992 Mitsubishi 3000GT VR4 #2 (sold) 1993 Mitsubishi 3000GT VR4 (KIA) 1994 Mitsubishi 3000GT VR4 (sold) 1994 Mitsubishi 3000GT Base - awd/atx (sold) |
#46 (permalink) | |
King Detail
#47 (permalink) | |
Moderator
Yes, even those $2000+ ECU setups once out of warranty will not be fixed for free. Oh, believe me this is far from a beating and the responses are intended as anything but. However, if you consider this friendly, logical debate a kick in the jimmies perhaps you should consider waiting with a camera to capture the timeless image when he finds out it won't be legally pursued in any way. I'm sure the resultant look of pure shock in his face (not to mention punishment to his checkbook from the accrued legal fees now due) will be a testiment to "OWNED" pictures for years to come! Last edited by TooFast4Radar : 02-21-2007 at 06:03 PM. |
#48 (permalink) | |
King Detail
So if there were handouts you wouldn't take them? All of your speculation is very reasonable, but I cannot and will not standdown for speculation when there is a very obvious pattern going on. I'm going to make the web page that collects the necessary data and show the pattern even further. The pattern is the title of this thread. Soon enough there won't be enough 1st gen or 2nd gen hybrid ECU's to go around from all the ones that are lost to this bs. If someone wants to spearhead the WHY the ECU's eventually fail by doing all kinds of testing..... GREAT ! DO IT ! Is it really going to help us though when there are countless threads with people showing their knowledge that the capacitors are bad? ..that there are resistors that are bad? How many more cars need to have failing ECU's amongst the known years before we call it a manufacturers error? How is it different from failing rods and bearings? For 1 the ECU is electronic and IMHO should be the most reliable piece of electronics in the car. It should be just as reliable as the RIMS or the subframe and shouldn't need to be looked at just like in all the other cars I've ever driven that were 10+ years old. Another reason: Because the ECU's fail more often. Prove me wrong. I welcome it. Plus, rods and bearings are easier to diagnose whereas a faulty ECU yields unpredictable unstable results during troubleshooting costing people mucho $$$$ and time. I certainly didn't start this thread to cause a fight or to be attacked. I started this thread because the occurrence of people getting ECU's repaired and replaced is very high. Furthermore it represents an interior fire hazard. I don't really give a rats ass about when the warranty expired because thats irrelevant. The relevance is that they made it the way they made it and the warranty is only there to sell cars. You really think its there for US? Give me a break again. If they'd have it their way there would be no warranties, but the nature of competition brings warranties into the picture. This is far from coffee thats too hot at McDonalds. If anyone wants to help they could make suggestions on what type of information I should be collecting on the web page I will build. Results will be stored into a database. Will collect VIN, Name, car model, year, ECU failure info: How many times replaced, replaced with what from where, how many times repaired, what was repaired or replaced on the board, etc.., build dates. I need to know how to obtain these to be able to tell others. |
#49 (permalink) | |
King Detail
#50 (permalink) | |
Gixxer Fixer
92 Stealth RT/TT Best time: 13.2 @105
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f1/recall-faulty-ecus-years-91-95-3000gt-stealth-365458/
| Posted By | For | Type | Date | |
| Untitled document | This thread | Refback | 04-08-2008 09:41 PM | |
| Thread Tools | |
