LinkBack (1) Thread Tools
Old 02-21-2007, 10:24 AM   #21 (permalink)
Moderator
TooFast4Radar's Avatar
Drives: The real 94/96/99
TooFast4Radar Level 7TooFast4Radar Level 7TooFast4Radar Level 7TooFast4Radar Level 7TooFast4Radar Level 7TooFast4Radar Level 7TooFast4Radar Level 7TooFast4Radar Level 7TooFast4Radar Level 7
Default Re: Recall faulty ECU's for years 91-95 3000GT and Stealth
Originally Posted by jandoaudio
Maybe everyone should sell their car and buy a kia with a warranty It is rediculous the number of people who have something go wrong with a SIXTEEN YEAR OLD car and since more than one has broken, expect the manufacturer to replace it. Shit wears out, get over it. The Tcase was a gift for all those who don't check their oil. Just because you could afford to buy the car doesn't mean you can afford to drive it, stop looking for handouts from other people to fix your problems
BTW, I had a 91 RT/TT before my 95 and I replaced the caps in it, no big deal, just a little preventative maintenance. The car was 13 years old at that point, the fact everything still worked as well as it did on a car that complicated was incredible
I totally agree. The TC may be a design issue of sorts since people have sealed the TC themselves and had it leak. Mine has had a very slow leak ever after I resealed it myself 4 years ago. I knew it was leaking long before the recall and just kept an eye on it. It was just one of those things I took along with owning the car. I can see a TC or seatbelts that fail causing a total loss of control of the vehicle or your body during an impact, but an ECU is starting to get a little rediculous.
It really isn't Mitsubishi's fault that they couldn't travel into the future to see what parts would start to fail 13 years after the warranty went out.
- 94 R/T Turbo
- 94 R/T
TooFast4Radar is offline   Reply With Quote
Old 02-21-2007, 10:26 AM   #22 (permalink)
Staying in the Family
jandoaudio's Avatar
Drives: 95 RT/TT
Trader Rating: (13)
jandoaudio Level 7jandoaudio Level 7jandoaudio Level 7jandoaudio Level 7jandoaudio Level 7jandoaudio Level 7jandoaudio Level 7jandoaudio Level 7jandoaudio Level 7jandoaudio Level 7
Exactly, Engineering and Economics have to strike a balance somewhere
95 RT/TT Stock
92 VR4 Blacked out with a 98 conversion
dr900's
Stage 3 Heads
98 Jeep TJ
35's
Locked with all the toys
Cheap, Fast, Reliable.... You can only have two
jandoaudio is offline   Reply With Quote
Old 02-21-2007, 01:02 PM   #23 (permalink)
roguetrip's Avatar
roguetrip is an unknown quantity at this point
I can say you won't get anywhere. This wasn't a saftey hazzard.
Those years were common for mitsubishi to buy and use rubicon capacitors that where not good, 3SI had issues, DSM has the issues, and also all Mitsubishi Electonic devices has them (TV's, VCR's, and such). I've worked on soo many TV's with the bad capacitors it ain't funny (projection and direct view).
'92 Dodge Stealth ES DOHC ATX
Snake Eyes, Topline Engineering Ground Kit, Intake Resonator Removed, Rebuilt ECU&TCU, VentusII HR Tires
NGK Laser Platinum Spark Plugs
'90 Dodge Daytona ES V6 (6G72)
MTX A543 3.77FD, Optima RedTop, KYB's all around, 58mm TB, 2.5" CAI, 1" intake spacers, BPE underdrive pulley, Strut tower bar, solid motor mounts, Fidanza Aluminum Flywheel
+ more
roguetrip is offline   Reply With Quote
Old 02-21-2007, 01:18 PM   #24 (permalink)
King Detail
ProwlerGT's Avatar
Drives: 95 3000GT Base DOHC
Trader Rating: (11)
ProwlerGT is an unknown quantity at this point
Originally Posted by StealthES418
Probably gonna take a lot of work since these ECU's aren't exactly cheap. The TC recall took enough work and all we ended up getting was a few seals replaced.
Terry
What kind of lawyers are used for matters such as these?
INFO LINKS FOR EVERYONE:
 ProwlerGT's Revival Thread | My Service Log | IAC | SENSORS | Hesitation Tracking List | NO3S.com
Lata,
ProwlerGT
"Those who know me, know my real name and more importantly how to say it right."
ThinkAbtIt on AIM | searcherrr on Yahoo IM | Email in profile
ProwlerGT is offline   Reply With Quote
Old 02-21-2007, 01:22 PM   #25 (permalink)
King Detail
ProwlerGT's Avatar
Trader Rating: (11)
Originally Posted by 91vr4n00maxima
stalling and stumbling IS a direct safety concern. there are many recalls right now because of stalling.
getting mitsu to cover a recall? yeah......right.
Good to know.
and
We'll see.
Old 02-21-2007, 01:22 PM   #26 (permalink)
King Detail
ProwlerGT's Avatar
Trader Rating: (11)
Another fire hazard ECU thread:
Anyone hungry for some deep FRIED ECU?
and another:
ECU on fire! What part is this?
Old 02-21-2007, 01:28 PM   #27 (permalink)
Rock Chalk, Jayhawk
92rtawd's Avatar
Drives: 92 Stealth TT
Trader Rating: (7)
92rtawd is an unknown quantity at this point
Most of us know about the problem. Spend the $20 to have your caps replaced before they go bad. That's what I did.
It won't do any of us any good if we drive Mitsubishi out of business with a whole bunch of recalls.
Make sure the caps aren't leaking badly before you buy the car. Then have them replaced for $20. Pretty simple.
AIR: WRX 13T turbos, Greddy FMIC, K&N Filter, A'pexi twin chamber BOV, Greddy Profec B, ESP downpipe, IPS single shot catback
FUEL: Greddy E-Manage,Walbro 255lph pump, IPO hotwire kit, AEM AFPR, 450cc injectors
SPARK: MSD wires, NGK plugs
DRIVETRAIN: PST 2-piece CFDS, Centerforce dual friction clutch
92rtawd is offline   Reply With Quote
Old 02-21-2007, 01:34 PM   #28 (permalink)
King of the South
Mumbo_Jumbo's Avatar
Drives: '04 Jeep WJ
Mumbo_Jumbo is an unknown quantity at this point
Wouldn't opening the ecu to replace the caps technically void the warranty (even if expired) and them exempt it from the proposed recall?
-Dave
Mumbo_Jumbo is offline   Reply With Quote
Old 02-21-2007, 01:36 PM   #29 (permalink)
King Detail
ProwlerGT's Avatar
Trader Rating: (11)
But it isn't. Replacing the CAPs isn't the only thing going bad on these ECUs. I hardly think this would put Mitsu out of business because even if it gets passed probably half or less of the affected vehicles will actually get the recall fix implemented. Thats my guess anyway.
Old 02-21-2007, 01:56 PM   #30 (permalink)
Racing
Barefoot's Avatar
Drives: 92R/T - converted ;)
Trader Rating: (31)
Barefoot Level 3Barefoot Level 3Barefoot Level 3Barefoot Level 3
I replaced the caps in the TT ecu i bought when I did the initial TT conversion. 1.5 years later it still fried. a few months later the replacement fried, now im on my 3rd which was recently rebuilt.. hopefully this one lasts a little longer, if not.. I may have to go AEM
92 Dodge Stealth R/T AWD/TT (TD05) converted ( 11.894 @ 120.56 - 18 psi -> Video )
Barefoot is offline   Reply With Quote
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f1/recall-faulty-ecus-years-91-95-3000gt-stealth-365458/
Posted By For Type Date
Untitled document This thread Refback 04-08-2008 08:41 PM
