Old 05-11-2008, 03:41 PM   #11 (permalink)
never a dull moment
DCIV's Avatar
Drives: 92 VR4
Trader Rating: (12)
DCIV level 6DCIV level 6DCIV level 6DCIV level 6DCIV level 6DCIV level 6
Default Re: rebuild soon
Originally Posted by DCIV View Post
Just depends on what power your talking about.
Coop
To many mods to list.
Old 05-11-2008, 04:14 PM   #12 (permalink)
SlowTT
slow91stealth's Avatar
Drives: not right now
Trader Rating: (28)
slow91stealth is an unknown quantity at this point
400-450ish awhp
My Car: 1991 Dodge Stealth RT/TT Pearl Metallic White
My Mods: FMIC(front Mount InterCooler) w/ Greddy RS Type BOV, Walboro 255 Fuel Pump ,IPO Fuel Pump Install Kit, IPO Fuel Pump Hotwire Kit ,EK2 Fuel Loop(not installed), Blitz FATT Turbo Timer ,KYB GR-2 Struts, TEIN S-Tech Lowering Springs, Power Slot Rotors and Pads, 3x 52mm Tripple Pillar Pod(not installed), AEM UEGO Wideband O2, AEM TRU-BOOST Boost Controller, Topline Engineering Ground Wire Kit, Accell Sparkplug Wires, NGK Iridium Sparkplugs, General Denastification(vaccum reduction), Powdercoated Gloss Black and Polished Lettering Valve Cover/Intake Manifold, Polished Sparkplug Cover With Red Lettering Comming
!!!FOR SALE!!!- PM me for more info
slow91stealth is offline   Reply With Quote
Old 05-11-2008, 04:39 PM   #13 (permalink)
never a dull moment
DCIV's Avatar
Drives: 92 VR4
Trader Rating: (12)
your fine with a 1st gen stock crank....would think about changing the bearings though.
Coop
Old 05-11-2008, 04:47 PM   #14 (permalink)
SlowTT
Trader Rating: (28)
ok so i should be fine if all th etests come out good with just the 60/120k tuneup, lifters, all new gaskets and seals and new bearings?
Old 05-11-2008, 04:48 PM   #15 (permalink)
never a dull moment
DCIV's Avatar
Drives: 92 VR4
Trader Rating: (12)
yes, please please please make sure you do the bearings correct though. If you dont then your going to have to rebuild after.
Coop
Old 05-11-2008, 05:05 PM   #16 (permalink)
SlowTT
Trader Rating: (28)
i will be doing them at my school since i get free access to all tools and everything needed including teacher help. so i will make sure i have my performance teacher(he builds professionaly 1/4 mile race cars) to take a look when im finished just as another set of eyes. or if i cant get the motor down there my garage it is and maybe ill see if i can get one of the local people(struggly, twintrubokid) to come take a look.
thanks for the help and quick responses
Old 05-11-2008, 05:22 PM   #17 (permalink)
Cant get there from here!
speedy25's Avatar
Drives: Various Japanese
You know you cant just swap cranks out right? You have to have the whole engine balanced if you want to change out cranks.
Coop
SOoo do you know something that we dont know about these parts and balancing? Sure its always NICE when blueprinting an engine to have it balanced, but swapping OEM parts shouldnt have any effect even if it is a different year crank.
Inquiring minds need to know.
-SP
One of 789
Old 05-11-2008, 07:54 PM   #18 (permalink)
SlowTT
Trader Rating: (28)
the difference in weight may throw off the center line. the OEM crank is built specific for the internals and by matching up a crank not meant for your internals(especially ones that are worn) it will not be evenly weighed for each journal. the counter weights are specific for each journal and the newr crank may have different weight inits counterweights... theres alot more to it but that was my 5 second help
Old 05-12-2008, 03:49 AM   #19 (permalink)
never a dull moment
DCIV's Avatar
Drives: 92 VR4
Trader Rating: (12)
-SP
Given that its an OEM part it MIGHT work, but thats a big risk to take when spending 800 on a crank and over 2500 on your engine. When messing with something as big as a crank then you get it balanced, thats basic stuff. If you want to gamble with your engine and try to save a little money then have at it but its not the correct thing to do.
Coop
