Old 06-12-2008, 02:57 PM   #1 (permalink)
porbund's Avatar
Drives: 1993 Sealth Base
porbund is an unknown quantity at this point
Default Rear wiper deleted
I pulled my rear wiper and motor off yesterday. It looks cleaner, especially since my old wiper arm was a POS. I am not sure how I like it yet, especially since my defrost does not work. I am kinda getting phantom wiper syndrome, like I miss its crappiness. How many others have done this, how do you like it, and do you have some pics?
1993 Dodge Stealth Base
1995 Plymouth Voyager-DD, mitsu 3.0L SOHC
"someone must've pulled the f*** switch"
Plymouth Voyagers improve with age, like a fine wine:
http://www.3si.org/forum/f36/222hp-d...ml#post4677717
porbund is offline   Reply With Quote
Old 06-12-2008, 03:05 PM   #2 (permalink)
daddy's Avatar
Drives: BPU 92TT
Trader Rating: (26)
daddy Level 7daddy Level 7daddy Level 7daddy Level 7daddy Level 7daddy Level 7daddy Level 7daddy Level 7
Default Re: Rear wiper deleted
One of the first thing I did to the car.
daddy is offline   Reply With Quote
Old 06-12-2008, 03:19 PM   #3 (permalink)
winter sucks
soclose3kgt's Avatar
Drives: a slow VR4
Trader Rating: (25)
soclose3kgt Level 7soclose3kgt Level 7soclose3kgt Level 7soclose3kgt Level 7soclose3kgt Level 7soclose3kgt Level 7soclose3kgt Level 7
I did it, it looks much cleaner(and mine worked, I just never used it and hated the look)
Dont have any close ups, but its MUCH cleaner
308awhp & 336awtq @1 bar
soclose3kgt is offline   Reply With Quote
Old 06-12-2008, 03:27 PM   #4 (permalink)
Drives: 94 VR4
Trader Rating: (20)
Blue94VR4 is an unknown quantity at this point
What do you guys use to fill the hole? Did you remove the fluid bottle as well?
94 3000GT VR4 (upgraded)
"Your 1994 Mitsubishi 3000GT VR-4 is one of 1650. There are 57 other cars that were made with both the same interior and exterior color. Exactly Identical - 8"
For sale:
1. used A/C belt (10K on the belt)
2. Stock front and rear sway bars.
3. 3SX dual O2 simulator
4. Used 2'' couplers/reducers/hump hoses
5. SPEC II+ clutch
Blue94VR4 is offline   Reply With Quote
Old 06-12-2008, 03:28 PM   #5 (permalink)
cyber bully
green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7
I pulled mine off to paint the trim and I didn't get around to painting it for a while. I missed it. I didn't realize how much I used it until I had it off so I put it back on.
Originally Posted by crazycracka928 View Post
^ lol "be the bigger man, poop on his hood"
Old 06-12-2008, 03:33 PM   #6 (permalink)
porbund's Avatar
thanks for the reassuring pics, everyone, I'll keep the motor handy in case I ever decide to put the wiper back on. I believe I used a Chrysler master cylinder gasket or cover (something like that) with silicone sealant. It was a very snug fit, but the silicone acted like a lubricant so I could get it in. I like the pics, let's keep them coming!
I hardly used my rear wiper because the rubber blade was missing. Just enough rubber on it to clean crap off the window.
Old 06-12-2008, 03:59 PM   #7 (permalink)
SOHC Power!!!
SOHC3000GT's Avatar
Drives: A Mitsu made turd...
Trader Rating: (97)
SOHC3000GT Level 7SOHC3000GT Level 7SOHC3000GT Level 7SOHC3000GT Level 7SOHC3000GT Level 7SOHC3000GT Level 7SOHC3000GT Level 7
I want to remove mine, but can't find anything to plug the hole...i still need to plug the three holes from the spoiler piece I removed...
'93 Green 3000GT
Fidanza 2.1 cltuch / Fidanza flywheel / 3SX ss clutch line / 3SX crank pulley / Lethal_VR4 manual steering rack / TT radiator / BigTyla ground wires / ebay intake / '99 lifters / TT fuel pump / Maximal solid motor mounts / 3SX long headers / TT race pipe / TT cat-back / KSport coilovers / Maximal rear toe & camber arms / UP rear strut bar / Seattle short shifter / TurboBob 8,800 rpm ECU
Want to buy 3000GT or RT rolling chasis near KC. PM me!
SOHC3000GT is offline   Reply With Quote
Old 06-12-2008, 06:16 PM   #8 (permalink)
TPW: Promoter
1veryfastvr4's Avatar
Drives: 97 vr4
Trader Rating: (60)
1veryfastvr4 Level 11veryfastvr4 Level 1
drive to a body shop and see if they have any rubber caps i put one in that hole and old ant hole.....when it goes for paint ill just weld them shut
1veryfastvr4 is offline   Reply With Quote
Old 06-12-2008, 08:24 PM   #9 (permalink)
NOTADSM
Polygon's Avatar
Drives: '89 GTC & '91 R/T TT
Trader Rating: (11)
Polygon Level 7Polygon Level 7Polygon Level 7Polygon Level 7Polygon Level 7Polygon Level 7Polygon Level 7Polygon Level 7Polygon Level 7Polygon Level 7Polygon Level 7
Did it on mine and I love it without. It looks so much cleaner. I also intend to get rid of the motor as well.
Polygon is offline   Reply With Quote
Old 06-12-2008, 09:04 PM   #10 (permalink)
Redlight to Redline
1320VR4's Avatar
Drives: 93 Dodge Stealth ES
Trader Rating: (15)
1320VR4 Level 71320VR4 Level 71320VR4 Level 71320VR4 Level 71320VR4 Level 71320VR4 Level 71320VR4 Level 71320VR4 Level 71320VR4 Level 71320VR4 Level 71320VR4 Level 7
would you reccomend doing this? My rear wiper blade is completely effed and the switch to put it on gets stuck and i have to beat the living shit out of it to turn it off.
1993 Dodge Stealth ES - 15.2 @ 92.4mph - September 2008 ROTM
1992 Mitsubishi 3000GT VR4 coming soon
1320VR4 is offline   Reply With Quote
