Old 06-16-2008, 11:43 AM   #31 (permalink)
hotrodhendrix's Avatar
Drives: 94' VR4/ 91' GT4
hotrodhendrix is an unknown quantity at this point
Default Re: rear mounted engine?
It would be cool but it wouldnt really be a 3sx if you did it right. Build a full tube frame and go from there. Keep weight distribution 50/50 like the RX8 but give the rear a bit more power. It would be cool! I too have considered the project sense I have 2 extra vr4 engines...
"It's not a question of if it will break down but a question of when it does can you afford to fix it."
By: James Hendrix (me)
Pearl White 94' VR4
hotrodhendrix is offline   Reply With Quote
Old 06-28-2008, 09:02 AM   #32 (permalink)
calibornn1979's Avatar
Drives: Carro Rapido Rojo
Trader Rating: (13)
calibornn1979 Level 3calibornn1979 Level 3calibornn1979 Level 3calibornn1979 Level 3
13b is more than a 350? omg the strangest thing ive ever heard.
Rob Beck 13T WRX turbos, DSM Sidemounts, DEJON Y-Pipe, DEJON Turbo intake pipes, KN Filters, Synapse Syncronic BOV, MSD Wires, Maximal Solid motor mounts, AEM EMS, AEM Duel UEGO, AEM Boost Solinoid, AEM AIT, AEM MAP Sensor, Stillen Down Pipe, Pit Road M 3.5 inch Titanium Catback, Seattle Roller Bearing Short Throw Shifter, Tein S-Tech, 3SX Rear camber arms, 3SX Stage 2 Clutch, 3SX light crank pully, Nelson Transfercase Bracket, RC 680cc Injectors, Walbro fuel Pump, Fidanza Flywheel
calibornn1979 is offline   Reply With Quote
Old 07-03-2008, 02:03 PM   #33 (permalink)
Now with 100% more NSX
leet's Avatar
Drives: 95 NSX and 92 TT
Trader Rating: (24)
leet Level 2leet Level 2leet Level 2
LS1, not a 350
LS1 is all aluminum vs cast iron for the 13b
the stealth is officially for sale, PM for info
leet is offline   Reply With Quote
Old 07-03-2008, 04:22 PM   #34 (permalink)
H to the izzO
Hannibalzero's Avatar
Drives: Recklessly
Trader Rating: (55)
Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7
Originally Posted by leet View Post
LS1, not a 350
Whoa, when did you get the NSX? Do you still have the red/black stealth too?
Old 07-05-2008, 07:42 PM   #35 (permalink)
leet's Avatar
Trader Rating: (24)
last month
still have the stealth but it's for sale now
Old 07-06-2008, 03:25 AM   #36 (permalink)
Trader Rating: (13)
huh? LS1 is a 5.7 liter. Which is 346ci which ever since 5.7's came out were called 350's
But you are right about them being fully aluminum.
Old 07-06-2008, 07:05 AM   #37 (permalink)
bane of unintelligence
inperfectdarkness's Avatar
Drives: dreaming of a TT ecu
Trader Rating: (12)
inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7
last month
yep. gotta pay for that comptech supercharger kit somehow.
inperfectdarkness is offline   Reply With Quote
Old 07-06-2008, 07:52 AM   #38 (permalink)
leet's Avatar
Trader Rating: (24)
I've never heard anyone call an ls1 a 350
Old 08-19-2008, 05:28 PM   #39 (permalink)
Drives: 92 stealth tt/ 92 gt
Trader Rating: (11)
92-stealth-13g is an unknown quantity at this point
well guys, I spent the last 2 months looking at my car and drawing up ideas for a rear engine. I had sergery this spring and have not been able to finish my projects already going on, but I should have plenty of time this winter and hope to be healed. I'm going to keep testing my body work talent on my s40, if that goes well I'll be back on my stealth. Once I finish my targa top I plan on doing a rear engine swap. I will only have to remove two of my role cage bars so it won't get in the way. It all depends on how buisy the shop I work at stays this winter, but I am very serious about doing this conversion.
92-stealth: stage three clutch, blitz dual boost controller, GT-35r turbo, racing seats, harnesses, cage, 550 injectors, mafpro and 255 pump
92 mr2 with nitrous- totaled
92 mr2 tdo6-totaled
92-stealth-13g is offline   Reply With Quote
Old 08-19-2008, 05:47 PM   #40 (permalink)
H to the izzO
Drives: Recklessly
Trader Rating: (55)
What do you plan on doing for the transmission? Are you just using a transverse mount FWD setup?
