Old 05-05-2008, 05:14 AM   #21 (permalink)
now with more jinba ittai
Stegmann is an unknown quantity at this point
Default Re: rear mounted engine?
It would be kind of like an LS1 rx7, fun in a straight line, but useless for anything else due to the thrown off weight distribution.
recovering ex-3s'er (will return)
1994 Miata 'A-Package'
- OEM hard top
- Hard Dog SCCA roll bar
- Torsen LSD
Stegmann is online now   Reply With Quote
Old 05-05-2008, 06:42 AM   #22 (permalink)
Now with 100% more NSX
leet's Avatar
Drives: 95 NSX-T
Trader Rating: (24)
leet Level 1leet Level 1
what? LS1 RX7's make great track cars, the LS1 actually weighs a little bit less then a 13b
the stealth is officially for sale, PM for info
leet is offline   Reply With Quote
Old 05-05-2008, 06:56 AM   #23 (permalink)
Wha??
Old 05-05-2008, 06:56 AM   #24 (permalink)
H to the izzO
Hannibalzero's Avatar
Drives: Recklessly
Trader Rating: (53)
Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7
Yup. Agree 100%.
Old 05-05-2008, 02:08 PM   #25 (permalink)
bane of unintelligence
inperfectdarkness's Avatar
Drives: dreaming of a TT ecu
Trader Rating: (12)
inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7
mounting the engine longitudinally in the front...and mounting the transaxle in the rear---would be much more productive. and much more conducive to maintaining weight balance.
inperfectdarkness is offline   Reply With Quote
Old 05-08-2008, 04:53 PM   #26 (permalink)
Drives: 92 stealth tt/ 92 gt
Trader Rating: (11)
92-stealth-13g is an unknown quantity at this point
I was thinking about doing this for a long time, but after I put my cage in it made the idea a lost cause. I don't think weight would be a problem at all. If anythink you would be spreading out weight compared to a fwd 3s. Stock the rear seats and fuel tank are all the weight the rear has, the front has everything. In a rear engine, the engine/trans are over the rear tires instead of the front, but you still have the battery, radiator, ac condensor, rack an added fuel tank and when I was looking into doing it an air/water heat exchanger/water tank. The reason I don't like the idea is the front of the 3s is very large, it just looks like the engine belongs there.
92-stealth: stage three clutch, blitz dual boost controller, GT-35r turbo, racing seats, harnesses, cage, 550 injectors, mafpro and 255 pump
92 mr2 with nitrous- totaled
92 mr2 tdo6-totaled
92-stealth-13g is offline   Reply With Quote
Old 06-16-2008, 08:41 AM   #27 (permalink)
Drives: 1992 eurospec 3000GT
TiberiusTribun is an unknown quantity at this point
With you on that. Same concept as the Ferrari 599 GTB and the new Nissan GT-R.
TiberiusTribun is offline   Reply With Quote
Old 06-16-2008, 08:57 AM   #28 (permalink)
est. sept, 2000
91vr4n00maxima's Avatar
Drives: slow 97 VR4
91vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 7
chevy has been doing that since 1997
97 VR4 12.417@111.16 9b time. whats next?
95 mark viii. 14.35@98
03 cobra vert. 4 mods=118mph traps
91 stealth TT. td05 18G, heads/cams, 3000lbs
91vr4n00maxima is offline   Reply With Quote
Old 06-16-2008, 09:56 AM   #29 (permalink)
Kessel run in 12 parsecs
Broch's Avatar
Drives: Viper...yikes!
Broch Level 1Broch Level 1
Side vents would finally have a purpose!
Broch is offline   Reply With Quote
Old 06-16-2008, 11:34 AM   #30 (permalink)
cyber bully
Trader Rating: (7)
green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7
true that!
I got a little excited when I saw the title of this thread because I have often wondered about it. I was hoping someone had done it or was trying to do it.
green-lantern is online now   Reply With Quote
