Old 09-21-2004, 09:43 AM   #21 (permalink)
Member # 2818
cred05's Avatar
Drives: 2000 Audi S4
cred05 is an unknown quantity at this point
Default Re: Rarity of a car
Your 1993 Mitsubishi 3000GT VR-4 is one of 2595. It was built in 3rd week of 03/93 and it was the 2421st post production car of that model to come out of the plant. There were 45252 other cars of the model year made at the Nayoga plant before your car.
There are 460 other cars that were made with both the same interior and exterior color. There are 868 cars with the same exterior color and 1395 cars with the same interior color.
Note: The production order is assigned based on the order of the serial number.
Other Numbers
Exactly Identical (*) 183
Mechanically Identical (**) 895
Same Model+Option Package 940
Same Model+Build Date 74
* Model, Interior & Exterior color, Equipment, Chassis
** Model, Equipment, Chassis
1/183....not bad. Doesnt beat the 1/2
They made 74 vr4's the same day mine was made, very interresting
SOLD the vr4 for an s4
13T's @ 15psi on Pump gas: 330HP/340TQ?
*DN Performance Y-Pipe*Magnacor Sparkplug Cables*NGK Irridium Spark Plugs(2 steps colder)*HKS Dual Sequential BOV
*3SX Lightweight Crank Pulley*Borla Catback*Test Pipe*ATR Downpipe*Fidanza Flywheel*RPS 6 puckClutch*Kormex Rebuilt Tranny*450cc Injectors*Apexi S-AFCII*Apexi Turbo Timer*Boost, and EGT Gauges*Stillen Brake Pads*Enkei RPO1 18X9*2 Nitto 555, 2 Pirelli PZero Nero 265/35/18*97 VR4 Brakes*GroundControl Coilovers*Drilled and slotted rotors*15psi*ProBoost MBC*FMIC, custom piping*3" GM MAS*MAFT*Dejon Tool Dual Intakes*Walbro 255 Fuel Pump*3SX Adjustable Control Arms*Fuel Rail Loop Adapter Kit*-6 Steel braided fuel lines*Aeromotive FPR*Battery Relocated in Trunk
cred05 is offline   Reply With Quote
Old 09-21-2004, 09:56 AM   #22 (permalink)
'96 VR4
tachyon_ftl's Avatar
Drives: It's spos'd to move?
Trader Rating: (11)
tachyon_ftl Level 1tachyon_ftl Level 1
Cool... I'll have to run mine when I get home. Who's got a '99 VR4 to run thru this thing?
GHOST - "Because it's white and it tends to vanish"
K&N FIPK, DSM Sidemounts, Hotwired Walbro, EK2 Fuel Loop & AEM AFPR, "The Only Known Dr. Stupid 3in SS DP in Captivity!",
Random Tech 3in Cat, Borla Catback, Greddy TT and EBC, Greddy Boost, Oil Prs and Fuel Prs in Cianci 3 Up Pillar Pod, Tein S-Techs,
Bilstein Struts, Maximal Control Arms, Carbotech Rotors/Pads and StopTech SS Brake Lines. In work- 450CC DSM Injectors and SAFC-2
tachyon_ftl is offline   Reply With Quote
Old 09-21-2004, 10:02 AM   #23 (permalink)
rock on, yeah rock on
spfan's Avatar
Drives: 4 x 22,000 lbs jets
Trader Rating: (6)
spfan is an unknown quantity at this point
Your 1993 Dodge Stealth R/T Turbo is one of 1299. It was built in 1st week of 08/92 and it was the 515th post production car of that model to come out of the plant. There were 10484 other cars of the model year made at the Nayoga plant before your car.
There are 25 other cars that were made with both the same interior and exterior color. There are 208 cars with the same exterior color and 232 cars with the same interior color.
Other Numbers
Exactly Identical (*) 5
Mechanically Identical (**) 311
Same Model+Option Package 370
Same Model+Build Date 49
that's some good stuff. i used to always just go to 3kgt. i was going to for this before anyone else replied, but when i ran his vin it gave me an interior code of INT and an exterior code of EXT. that never happened to me before, but oh well.
Dyno Collection Thread
1993 Dodge Stealth ES, White, April 2002 - April 2005, SOLD 1 of 53
1993 Dodge Stealth TT, Black, Since April 2004, 1 of 5 ever made more rarity info
2003 Subaru Forester 2.5X, Blue, Sept. 2005, Daily Driver with 165 HP of Fury! At least it's AWD.
305 awhp, 325 awtq(BPU minus full catback exhaust)Mods at that time
13.02@104.67 (9bs, dp, fipk, 15.5 psi, bov, no cats, streetmax clutch, 1.77 60', decent conditions, full weight (even spare tire/jack)
13.09@105.08 (1.80 60', same conditions as above)
Beyond BPU: (meaning upgraded turbos/fuel/etc) before engine rebuild Mods at that time
12.38@113.00(20 psi, 110 octane, massive knock above 6k rpms)
12.41@115.10(ditto)
After Rebuild: Current Mods Dyno Tune by IPS
12.8@108 (12.5 psi dropping to ~11 @redline, 2.0 60', pump gas, my tune)
spfan is offline   Reply With Quote
Old 09-21-2004, 04:20 PM   #24 (permalink)
spfan's Avatar
Trader Rating: (6)
Your 1993 Dodge Stealth ES is one of 5282. It was built in 2nd week of 09/92 and it was the 1869th post production car of that model to come out of the plant. There were 17136 other cars of the model year made at the Nayoga plant before your car.
There are 70 other cars that were made with both the same interior and exterior color. There are 812 cars with the same exterior color and 93 cars with the same interior color.
Other Numbers
Exactly Identical (*) 53
Mechanically Identical (**) 933
Same Model+Option Package 2131
Same Model+Build Date 125
Old 09-21-2004, 05:22 PM   #25 (permalink)
BULLSEYE: Six Fwags Guy!
blusilvr's Avatar
Drives: PiMpMobile
Trader Rating: (66)
blusilvr Level 4blusilvr Level 4blusilvr Level 4blusilvr Level 4blusilvr Level 4
91/92 Fiji blue is rare
Your 1991 Dodge Stealth R/T Turbo is one of 3016. It was built in 2nd week of 12/90 and it was the 1070th post production car of that model to come out of the plant. There were 10430 other cars of the model year made at the Nayoga plant before your car.
There are 21 other cars that were made with both the same interior and exterior color. There are 235 cars with the same exterior color and 473 cars with the same interior color.
Other Numbers
Same Model+Option Package 379
Same Model+Build Date 116
92 reds are common
Your 1992 Dodge Stealth R/T Turbo is one of 4355. It was built in 1st week of 03/92 and it was the 3789th post production car of that model to come out of the plant. There were 61092 other cars of the model year made at the Nayoga plant before your car.
There are 959 other cars that were made with both the same interior and exterior color. There are 1319 cars with the same exterior color and 2572 cars with the same interior color.
Other Numbers
Exactly Identical (*) 83
Mechanically Identical (**) 405
Same Model+Option Package 433
Same Model+Build Date 206
blusilvr is offline   Reply With Quote
Old 09-21-2004, 05:42 PM   #26 (permalink)
HowlerMonkeyShadetreeMech
tige's Avatar
Drives: 92 Stealth RT/TT
tige is an unknown quantity at this point
92 Red was very common - 1 of 645
Your 1992 Dodge Stealth R/T Turbo is one of 4355. It was built in 2nd week of 08/91 and it was the 616th post production car of that model to come out of the plant. There were 21867 other cars of the model year made at the Nayoga plant before your car.
Other Numbers
Exactly Identical (*) 645
Mechanically Identical (**) 2842
Same Model+Option Package 3542
Same Model+Build Date 22
Chris
92 Red RT/TT
Replaced since March '04:
Rebuilt ECU, FPR, Spark Plugs, Wires, Front Driver's ECS connector, Rear O2 sensor, Oil Pan Gasket (twice)
Upgrades:
K&N Cone, 13g's, Blitz DCTT, Hotwire kit, Suade Shift & E-Brake boots, Suade Center Console Panels, RC 550 Injectors
Waiting on ....
Money back from the 13g's I didn't get
Datalogger
255lph pump
Fuel Management
Big Red One = 75,000hp at the wheels
tige is offline   Reply With Quote
Old 09-21-2004, 05:47 PM   #27 (permalink)
No longer a 3si'r
mattyfatty182's Avatar
Drives: 97 Toyota Tacoma
mattyfatty182 is an unknown quantity at this point
Code:
The Story of Your Car: VIN JA3AM84J5TY002051
Your 1996 Mitsubishi 3000GT is one of 3233. It was built in 1st week of 07/95 and it was the 650th post production car of that model to come out of the plant. There were 1956 other cars of the model year made at the Nayoga plant before your car.
There are 409 other cars that were made with both the same interior and exterior color. There are 816 cars with the same exterior color and 1397 cars with the same interior color.
Other Numbers
Exactly Identical (*)	304
Mechanically Identical (**)	1263
Same Model+Option Package	3232
Same Model+Build Date	190
1997 Toyota Tacoma
PIAA Driving Lights -- 32" Dunlop Mud Rovers -- 15% Tint --12" Infinity Kappa powered by Kenwood KAC7201 Lifted by ToyTec
mattyfatty182 is offline   Reply With Quote
Old 09-21-2004, 05:59 PM   #28 (permalink)
3/S enthusiast
andyvr4's Avatar
Drives: 91 VR-4, 99 Zx2
andyvr4 Level 2andyvr4 Level 2andyvr4 Level 2
I assume that you are probably talking about my VIN. I had also tried several times, but was just getting INT and EXT. That's the reason why I posted this thread. If anybody knows why I was getting that please let me know.
andyvr4 is offline   Reply With Quote
Old 09-21-2004, 06:12 PM   #29 (permalink)
Michiana 3/S Chapter Pres
BrianHag's Avatar
Drives: 2000 Bonneville SSEi
BrianHag Level 7BrianHag Level 7BrianHag Level 7BrianHag Level 7BrianHag Level 7BrianHag Level 7BrianHag Level 7BrianHag Level 7BrianHag Level 7BrianHag Level 7
Your 1993 Mitsubishi 3000GT SL is one of 4310. It was built in 1st week of 09/92 and it was the 1791st post production car of that model to come out of the plant. There were 15018 other cars of the model year made at the Nayoga plant before your car.
There are 32 other cars that were made with both the same interior and exterior color. There are 951 cars with the same exterior color and 196 cars with the same interior color.
Other Numbers
Exactly Identical (*) 27
Mechanically Identical (**) 173
Same Model+Option Package 391
Same Model+Build Date 371
Michiana3s Will be back soon!!
The trophy is ours!!! 2006 and 2007 Chapter Challenge Champs!!
Some of us are more excited than others....
BrianHag is offline   Reply With Quote
Old 09-21-2004, 06:54 PM   #30 (permalink)
Drives: '99 3000GT
sag1441 is an unknown quantity at this point
Your 1999 Mitsubishi 3000GT is one of 1936. It was built in 3rd week of 06/99 and it was the 1668th post production car of that model to come out of the plant. There were 2728 other cars of the model year made at the Nayoga plant before your car.
There are 73 other cars that were made with both the same interior and exterior color. There are 571 cars with the same exterior color and 151 cars with the same interior color.
Other Numbers
Exactly Identical (*) 32
Mechanically Identical (**) 167
Same Model+Option Package 937
Same Model+Build Date 54
'99 3000GT, 5-spd, 15% tint, 17'' VR-4 chromies
sag1441 is offline   Reply With Quote
