Old 03-31-2006, 04:00 PM   #31 (permalink)
Too fast 4 you
smokinvr-4's Avatar
Drives: Smokinvr4@hotmail
Trader Rating: (100)
smokinvr-4 is an unknown quantity at this point
Default Re: Q&A with Trevor!
Hey man, I will def hit you up for some help tuning my EMU once i get everything buttoned back up, I look forward to hitting the track with you Trevor
remember me saying 'my car wants to be your car when it grows up'??
smokinvr-4 is offline   Reply With Quote
Old 03-31-2006, 04:17 PM   #32 (permalink)
CTheiss is an unknown quantity at this point
Trevor, great post. It is great to see one of the leaders in our forum step forward and share his setup. Best on luck! Regards Chuck
CTheiss is offline   Reply With Quote
Old 03-31-2006, 04:38 PM   #33 (permalink)
I'm a Troll
Drives: too many 3/S cars
Trader Rating: (24)
Hans91GT is an unknown quantity at this point
I can answer the roll cage question, if you don't mind
It's from S&W Racecars
Hans91GT is offline   Reply With Quote
Old 03-31-2006, 04:39 PM   #34 (permalink)
Viking Style!
alienviking's Avatar
Drives: A land yacht
alienviking is an unknown quantity at this point
This might be a stupid question but I've wondered a while.. A lot of people who get fmics use as open bumpers as possible including cutting bumpers to allow more air. You have a stock bumper which I think gives a much cleaner look. Would there be a noticeable difference between what you have and let's say a '99 front? Or a completely cut open front?
"Of all God's creatures, there is only one that cannot be made slave of the leash. That one is the cat. If man could be crossed with the cat it would improve the man, but it would deteriorate the cat." - Mark Twain
alienviking is offline   Reply With Quote
Old 03-31-2006, 04:50 PM   #35 (permalink)
Trader Rating: (26)
surreal is an unknown quantity at this point
ill throw out some random questions:
what turbo setups have you run in the past? what made you move on from them?
was the switch from 14b to 16g worth it? will you eventually go bigger?
did you ever use adapter plates? thoughts on plates vs manifolds?
are there any other clutches youd consider using at that power level?
thanks!
Firestorm TT
APU---
surreal is offline   Reply With Quote
Old 03-31-2006, 05:04 PM   #36 (permalink)
TEXAS!! FIGHT!!
AdamVR4's Avatar
Drives: NoCar XCase Test Car
Trader Rating: (22)
AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7
Are you sure about that??
thanks!
I'm interested in knowing the answer to:
"will you eventually go bigger?"
"thoughts on plates vs manifolds?"
Here's my question.
Trevor, will you please run a little shot on top of the 30 psi? Use a progressive controller to make it gentle on your rods, get a bottle warmer, go all out on the kit (like you do with EVERYTHING on that car!). I'm pretty sure I'm sacking riding at this point, but you've got the engine and car to take this. This would be the EASIEST and cheapest way for you to dig deaper into the 10's IMHO.
Regardless, Trevor, you're the shit.
PEARL WHITE '93 VR-4 // Under Construction. Looking forward to lighting up the drag radials
E16G's: 10.573 @ 135.01
(Trevor owns me )
E16G's: 11.28 @ 124.7
(Pure pump gas ET record )
14B's: 11.10 @ 127.3
(AWD 14B ET record. Take THAT, Trev! )
9B's: 12.78 @ 107.1
Congrats to the current top 10 members!!
DynamicRacing: US 3S Top 10 Fastest List
AdamVR4 is offline   Reply With Quote
Old 03-31-2006, 05:38 PM   #37 (permalink)
TPW Educator
LVA3KGT's Avatar
Drives: with EDFC at 0/0
LVA3KGT Level 5LVA3KGT Level 5LVA3KGT Level 5LVA3KGT Level 5LVA3KGT Level 5LVA3KGT Level 5
Originally Posted by DJAuggie
Sorry if I was rude but the ARM1 doesn't even give NB02 DIGITAL values does it? The resolution between NB02 and WB02 is night and day. I have seen solid .96 NB02 tune which almost had a full 1 AFR fluctuation.
I've been here long enough to know better than to take anything personally.
You are correct the Arm1 doesn't give digital values. I don't want to waste space in this thread about it, but needless to say, I don't trust the pretty lights.
I'm just curious to know which light actually means "good".
Since I know Trev uses an Arm1 on each bank, plus a WB, I thought he would be a good person to ask.
97 SLtt
World's fastest fwdTT 97SL in Phoenix
410 Ft/lbs of torque-steer and 390HP to the front wheels, making 1-3 gear useless @17psi. Built and tuned by 3SX
(Firebird) = Best 60ft 2.4 Best ET 13.8 , best trap 110.8MPH , picked up almost 30mph on the big end of the track.
3SI member # 5422
LVA3KGT is offline   Reply With Quote
Old 03-31-2006, 05:52 PM   #38 (permalink)
Supporting Vendor
SnakeSkinner's Avatar
Trader Rating: (32)
SnakeSkinner Level 7SnakeSkinner Level 7SnakeSkinner Level 7SnakeSkinner Level 7SnakeSkinner Level 7SnakeSkinner Level 7SnakeSkinner Level 7SnakeSkinner Level 7SnakeSkinner Level 7SnakeSkinner Level 7SnakeSkinner Level 7
your right running 10's is not that hard. My car ran a 10.9@114 mph with a popped off IC pipe and coasting the last part of the track after the pipe came off and the car stalled. I ran a 10 second pass in Roswell with a 250+lb PASSENGER! A 3si member from Albuquerque. And all these passes were at 3600+ft!
if 10’s can be run under those conditions just about anybody can run 10’s with the right set-up if you are a ½ way competent driver.
93 RT TT 8.81@166.7mph @3600ft Worlds Quickest and Fastest 3000gt/stealth
95 3000GT VR-4 10.56@136mph- 714 AWHP & 607 AWTQ (dr-900's) (sold)
92 Stealth RT TT 10.69@133.45mph @3600ft (dr-800's) (sold)
95 RT TT 10.88@129.1mph @3600ft (sold)
95 RT TT 11.9@118mph (stock injectors)
2004 F350 Harley 14.4@90mph at 3600ft
2007 Charger SRT-8 12.3@120mph@3600ft, Heads/cam, NOS 548 RWHP
2001 Dodge Viper GTS Heads/cam 612 rwhp & 619 rwtq
There are 2 ways to make a car fast.
#1 use the Right combo of parts
#2 Throw so much money at it that the car has no choice but to be fast.
I choose #1
Click for US 3S Fastest ET list
Better to be a racer for a moment then a spectator for a lifetime
"Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education alone will not; the world is full of educated derelict."— John Calvin Coolidge
SnakeSkinner is offline   Reply With Quote
Old 03-31-2006, 05:52 PM   #39 (permalink)
1997VR-4's Avatar
Drives: 2000 WJ Jeep
1997VR-4 Level 11997VR-4 Level 1
What is the recipe for your special sauce and how exactly do you go about applying it?
-Russell
3STech.org - The city on the hill.
1997 3000gt VR-4 - Gone, 07/28/04
2000 Jeep Grand Cherokee Limited
1997VR-4 is offline   Reply With Quote
Old 03-31-2006, 06:05 PM   #40 (permalink)
Phillip is an unknown quantity at this point
Can you explain a little how you control the meth injection? I know you increase it progressively with boost, but how much are you spraying at each point (as in a real number). How much fuel do you have to pull? Is it equal to the amount of meth you spray?
How much extra boost is that allowing you to run on pump? C16? How much more power do you think that extra boost is giving you?
And finally, how do you go about tuning in general? Do you start where you know you'll be rich and gradually lean out? Do you have someone watch the wideband when you floor it so you can come off the gas quickly if you end up lean? If you could just explain your general tuning practice/method (like when you first went with the MAP ECU) that would be awesome.
Phillip is offline   Reply With Quote
