Old 03-31-2006, 01:37 PM   #21 (permalink)
Mellon's Avatar
Drives: 91 TT Stealth 05 EVO
Trader Rating: (18)
Mellon Level 4Mellon Level 4Mellon Level 4Mellon Level 4Mellon Level 4
Default Re: Q&A with Trevor!
why is it so slow?
JFWY, have you made a pass on the ultimate yet? what do you think about it?
- Chris
05 EVO and 91 Stealth R/T TT
**video**
Upload your 3/S videos here http://3svideo.vidiac.com and post www.racevideoforums.com
Intake: E16G turbos, DR Stage III heads, DR Race cams, Unorthodox Cam gears, Stock MAS, 6" K&N air filter, HKS SSBOV, Vacuum Reduction, custom 2.5" intake pipes and Dejon FMIC
Ignition: MSD 8.5mm spark plug wires, NGK non-resistor non-projected R5671A-8 gapped at .026, HKS Twin Power DLI
Electronics: Greddy Turbo Timer, Greddy E-Manage Blue, Greddy Profec E-01, MMCD and Palm, LM-1 Wideband + RPM Converter
Fuel: Blitz 720cc injectors, Denso 310lph fuel pump, Fuel pump Hotwire , relay bypass, IPO SX Fuel Pressure Regulator and Kenne Bell Boost-a-pump
Exhaust: Titan TD05 Headers and 02 housings, EGR Blockoff Plates, ATR downpipe, Twin Borla mufflers
Driveline: RPS MAX 6-Puck Clutch and RPS Flywheel, 17" Enkei RPF1 (16lbs each), Nitto 555 Extreme, TEIN S-Tech springs and KYB GR2 Struts
Other: Unorthodox Underdrive Pulley, Krankvents
Mellon is offline   Reply With Quote
Old 03-31-2006, 01:43 PM   #22 (permalink)
Moderator
HilbillyHomeboy's Avatar
Drives: Tin Indian
Trader Rating: (39)
HilbillyHomeboy Level 7HilbillyHomeboy Level 7HilbillyHomeboy Level 7HilbillyHomeboy Level 7HilbillyHomeboy Level 7HilbillyHomeboy Level 7HilbillyHomeboy Level 7HilbillyHomeboy Level 7HilbillyHomeboy Level 7HilbillyHomeboy Level 7HilbillyHomeboy Level 7
Originally Posted by Trevor
I have 3.75" of clearance as it swins around the diff.
Nice! I can live with that for sure. Shoot, my Beetle has only 4" at its lowest point. Thanks.
Jeremy
92 Stealth GT42 10.73...142.21mph (SOLD)
Originally Posted by ray pampena
good luck with your gears and i hope you choke on them.
HilbillyHomeboy is offline   Reply With Quote
Old 03-31-2006, 01:54 PM   #23 (permalink)
Twin Power Pellets
pacman3000gt's Avatar
Drives: 94 Mitsu 3000GT VR4
pacman3000gt is an unknown quantity at this point
very interesting thread.
boost-a-pump or aeromotive?
If you could go back... would you keep the kenne bell? or use the aeromotive option?
1994 Mitsubishi 3000gt VR4 - Black
AEM EMS | 700cc | Big16G | JPDC TD05 plates | FMIC | SouthBend DXD-F/UR Aluminum Flywheel | Blitz DSBC | Tanabe Hyper Medallion | Volk Racing LE37T | BFG KDW2 | R1Concepts Rotors
pacman3000gt is offline   Reply With Quote
Old 03-31-2006, 01:59 PM   #24 (permalink)
TEXAS!! FIGHT!!
AdamVR4's Avatar
Drives: NoCar XCase Test Car
Trader Rating: (22)
AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7
I have 1 Q -
When are you going to be in Texas again, Trev?
PEARL WHITE '93 VR-4 // Under Construction. Looking forward to lighting up the drag radials
E16G's: 10.573 @ 135.01
(Trevor owns me )
E16G's: 11.28 @ 124.7
(Pure pump gas ET record )
14B's: 11.10 @ 127.3
(AWD 14B ET record. Take THAT, Trev! )
9B's: 12.78 @ 107.1
Congrats to the current top 10 members!!
DynamicRacing: US 3S Top 10 Fastest List
AdamVR4 is offline   Reply With Quote
Old 03-31-2006, 02:06 PM   #25 (permalink)
I need more cars
2root4u's Avatar
Drives: Depends on my mood
Trader Rating: (13)
2root4u Level 12root4u Level 1
How are you liking the EMU? I know you went that route to keep the stock ECU for OBD2 and inspections. If inspections weren't an issue, would you have gone for AEM?
---== FOR SALE ==---
ATR full exhaust for sale
4" exhaust parts
Cheap, reliable hosting for 3Si members
1993 Green 3000GT VR4 - Best ET 11.7 - Best Trap 122 - 475hp / 477tq - Pauter rods/Ross pistons/High rev kit--springs and titanium retainers/Ported heads/Dual pump, dual feed fuel system with hotwire/Dejon intake/Scanmaster/550cc injectors/MSD 8.5 wires/HKS DLI/H&R springs/GAB adjustable struts/PST CFDS/EMU/SBC-iD/2 Greddy 60mm EGT with peak hold/Greddy 60mm Boost with peak hold/2 SPA dual digital gauges (oil pressure/temp, water temp, fuel pressure)/AEM WBO2/18x9 Bronze Pro N1s/265/35 Yoko AVS Sports/PPE FMIC with PPE HPC-coated pipes/Flexalite fans/Spec 3+ clutch/RPS flywheel/Tial BOV/DR 3.5" exhaust/Non-resistor copper plugs/Brembo F40 calipers and rotors/short shifter/poly motor mounts/rear control arms/Krank vents
1995 Caracas Red 3000GT VR4 - Sold - BPU - 12.7 @ 107
1995 Red Dodge Stealth RT/TT - Sold - RPS Stage II Clutch
1993 Champagne Stealth - Sold K&N intake
1993 Green 3000GT base - Sold
2root4u is offline   Reply With Quote
Old 03-31-2006, 02:14 PM   #26 (permalink)
*** Member #5912
Trader Rating: (11)
servidjo is an unknown quantity at this point
ditto for info about the roll cage
John Servidio - 94 VR4
servidjo is offline   Reply With Quote
Old 03-31-2006, 03:15 PM   #27 (permalink)
RESIDENT ASSHOLE
DJAuggie's Avatar
Drives: 1996 3000GT VR-4
Trader Rating: (41)
DJAuggie level 6DJAuggie level 6DJAuggie level 6DJAuggie level 6DJAuggie level 6DJAuggie level 6
Originally Posted by LVA3KGT
When you compare you WB a/f readings to your Arm1 readings, do you find that the Arm1 is off by a lot or a little- and to what direction is it off?
Are you joking?
DJAuggie is offline   Reply With Quote
Old 03-31-2006, 03:34 PM   #28 (permalink)
Ziggy Socky!
Lenny M's Avatar
Trader Rating: (66)
Lenny M Level 7Lenny M Level 7Lenny M Level 7Lenny M Level 7Lenny M Level 7Lenny M Level 7Lenny M Level 7Lenny M Level 7Lenny M Level 7Lenny M Level 7Lenny M Level 7
I'm interested in your opinion on ignition systems. You have a Kenne bell boost a spark. Why no MSD dis-4, or HKS Twin Power Ignition Amplifier. Are your coils new or accel?
Thanks Trever, you always helped me as a newbie and your continuing to give me knowldge now.
Lenny
92 VR4
DR-650r, DR Stage 3 heads, Z06 Maf/Maf-t, PTE 680's, Blitz DSBC, 8000k Xenon HID's, RPS Max street disc, S-AFCII, DSM intercoolers, EK2 spark plug plate, MSD wires, Greddy type-S, Stillen dp, No cats, Borla exhaust, Greddy FATT, Greddy PHW EGT, TRE probe, IPO ashtray plate, Carbon heated seats, Snake eyes, 3rd gen lifters, Pearl short shifter, Palm IIIc datalogger, Shiver cable, Denso fuel pump-hotwired, Streamlined clutch vac line, EK2 fuel rail loop, Viper keyless entry, Phenolic plenum spacer, Window tint 25%, Optima red top, Tein S-tech, Redline fluids, KYB shocks/struts, DN Y-pipe, M-spec vac line reduction, Grounding kit, Adjustable control arms, Enkei RPM-2 18x9, Fuzion 265/35, 3KGT floor mats, Dejon intake runners, EGR plates, NGK copper's, Pioneer P8400MP MP3, Underdrive pulley, Fidanza Aluminum Flywheel, Fumoto drain, eXo-cage transfer case, plug, Seatrab oil cooler, Rear strut bar, Propane injection
92 Stealth RT/TT
92 Lexus sc400
97 Land rover Discovery
94 Suzuki GSX600f
Lenny M is offline   Reply With Quote
Old 03-31-2006, 03:34 PM   #29 (permalink)
TPW Educator
LVA3KGT's Avatar
Drives: with EDFC at 0/0
LVA3KGT Level 7LVA3KGT Level 7LVA3KGT Level 7LVA3KGT Level 7LVA3KGT Level 7LVA3KGT Level 7LVA3KGT Level 7LVA3KGT Level 7LVA3KGT Level 7LVA3KGT Level 7LVA3KGT Level 7
Originally Posted by DJAuggie
Are you joking?
no. Sorry if it is a dumb question. I know the Arm1 is just little lights, vs. a real number, but I'd like to know in which direction it is off, and by how much.
If you know, then post.
97 SLtt
World's fastest fwdTT 97SL in Phoenix
410 Ft/lbs of torque-steer and 390HP to the front wheels, making 1-3 gear useless @17psi. Built and tuned by 3SX
(Firebird) = Best 60ft 2.4 Best ET 13.8 , best trap 110.8MPH , picked up almost 30mph on the big end of the track.
3SI member # 5422
LVA3KGT is offline   Reply With Quote
Old 03-31-2006, 03:50 PM   #30 (permalink)
RESIDENT ASSHOLE
DJAuggie's Avatar
Trader Rating: (41)
Sorry if I was rude but the ARM1 doesn't even give NB02 DIGITAL values does it? The resolution between NB02 and WB02 is night and day. I have seen solid .96 NB02 tune which almost had a full 1 AFR fluctuation.
