#11 (permalink) | |
Z15A Tweaker
-Gutted Pre-Cats -ATR Downpipe with no main cat -Borla Cat-Back If I were at 3600 lbs again the computer guesses I'd be 0.14 seconds slower and at 3671 lbs (stock) I'd be 0.22 seconds slower.
96 Dodge Stealth R/T TT w/58k
10.396 @ 138.94 (C16+Meth) 10.898 @ 130.00 (91+Meth) ![]() 05 Mercedes Benz C230 6-Speed Sedan 06 Dodge Magnum SRT-8 |
#12 (permalink) | |
Z15A Tweaker
I do know how I'd approach it though. If it was a 1G it'd be easy. Just log knock and sneak up on it. On a 2G I'd start with a small shot and the boost turned down. Get it on the dyno or at the track and watch the power numbers (1/8th > 1/4 gain on the timeslip). Slowly feed in boost (less than 1 psi per test). Once your power gains disappear due to knock induced timing retard I'd turn the boost way back down and up the shot one notch and retest...adding boost VERY SLOWLY again. See where you plateau at. Repeat until you find the sweet spot. It's a very slow process but its the only way to do it decently safely. |
#14 (permalink) |
TPW Educator
Why did you pick that boost controller? What other have you used- if any? What are the key differences?
97 SLtt
World's fastest fwdTT 97SL in Phoenix 410 Ft/lbs of torque-steer and 390HP to the front wheels, making 1-3 gear useless @17psi. Built and tuned by 3SX (Firebird) = Best 60ft 2.4 Best ET 13.8 , best trap 110.8MPH , picked up almost 30mph on the big end of the track. 3SI member # 5422 ![]() |
#15 (permalink) | |
ver. 3
#17 (permalink) | |
Z15A Tweaker
The MAP ECU's IAT was mounted on the brake lines right next to the air filters. Yes, true speed density is designed to use intake air temperature in the plenum (close to the MAP sensor) but our latest cheater piggyback systems are not true speed density (the VPC was but that's another topic). The MAP ECU and Emanage Ultimate both feed IAT to the stock computer and let it make its trims just like it did in the stock config. The mitsu engineers based the IAT maps on intake air before the turbos...not hot charge air. If you start feeding the stock computer 200+F numbers its not going to make the appropriate corrections for it. It was never designed to account for temps in any location except for BEFORE the turbos. |
#18 (permalink) | |
Z15A Tweaker
A crappy pic: ![]() That's the muffler right before the tip. Last edited by Trevor : 03-31-2006 at 01:55 PM. |
#19 (permalink) |
Meet the twins
Where did you get your cage and what was the cost? Also would like to see some pics of your cage if you've got any. thanks
1998 VR4 - Red - 1 of 231
15g's | PTE 550's | Walbro 255 | Apexi SAFC w/ Boomslang Harness | Maximal Performance Solid F/R Mounts | Stillen Downpipe | MSD Superconductor 8.5s | JIC Y-Pipe | Old school ProBoost MBC | EVOScan Logger (logging knock on OBDII baby!) | Kazera KZ-A 18x8.5's | Yokahoma AVS ES100 Tires 1/8: 8.1 @ 89 MPH, 1.9 60' (soft launch on stock clutch) - 16 PSI/rich tune & leaking stock y-pipe coming soon: more runs with MORE BOOST! ------------- 1990 Mustang GT - not stock - Gone but never forgotten..... ------------- 1992 Mitsubishi 3000GT SLTT - Formerly the SLSC - My first love (15g 10:1 TT Conversion) - Parting Out ------------- Old setup (worn 9b's, broken motor mounts, M&S tires, 6 psi) 1/8: 9.3 @ 85 MPH |
#20 (permalink) |
Regulator...
when Tuner Transformation installed their MAP ECU on their supra. They drilled and tapped their air temp sensor in the actual manifold? Is that a better place?
Also I have... Phantom turbo's. Are 650 cc injectors a reasonable choice for street running around 18-20 lbs boost? Supra fuel pump(not hotwired but I prob better). My goals... A nice street 400hp car not needing race gas visiting the track maybe 3 times a year. Fuel pressure, stick with stock levels right? |
