Old 04-02-2006, 02:07 PM   #131 (permalink)
Z15A Tweaker
Trevor's Avatar
Trader Rating: (15)
Trevor Level 7Trevor Level 7Trevor Level 7Trevor Level 7Trevor Level 7Trevor Level 7Trevor Level 7Trevor Level 7Trevor Level 7Trevor Level 7Trevor Level 7
Default Re: Q&A with Trevor!
Originally Posted by Multiades
I just noticed that your dyno sheet is with ZERO smoothing. Your car purrs like a kitten.
Hehehe...you're observant.
I could have tuned out that hiccup at 5400 but that was my last pull and the only one I made at that boost level.
I'm not BS'ing about my car pulling smoothly without an ignition amp.
96 Dodge Stealth R/T TT w/59k
10.396 @ 138.94 (C16+Meth)
10.898 @ 130.00 (91+Meth)
Trevor is offline   Reply With Quote
Old 04-03-2006, 06:55 AM   #132 (permalink)
Banned from Classifieds
stealthtwin69's Avatar
Drives: 92 steath tt
stealthtwin69 is an unknown quantity at this point
hey trevor maybe you can help me out....my car seems to be making alot of power but at the track i can only manage a 13.3 at 108mph..with all my mods i figured i could have run better...granted my 60ft time is a 2.0 what do you think i could do to make it faster..i have been running 110 leaded on those runs with 20lbs of boost..no knock..except 3 random counts, on the street i seem to be a monster but i just cant seem to pull mid 12's to low 12's like i figured..considering people have runs faster times with stock turbos and mods similiar to mine..just wondering if you could give me some insight..thanks
stealthtwin69 is offline   Reply With Quote
Old 04-03-2006, 08:03 AM   #133 (permalink)
Pro xfercase destroyer
mjannusch's Avatar
Drives: 2005 Toyota Prius
Trader Rating: (20)
mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7
Post a complete timeslip.
-Matt
'95 3000GT Spyder VR4 (11.838@117.56)
'93 3000GT VR4 (Project for 2009)
'91 3000GT VR4 (Only a shell of its former self)
mjannusch is offline   Reply With Quote
Old 04-03-2006, 08:15 AM   #134 (permalink)
i will later..not at home with the car
Old 04-03-2006, 11:32 AM   #135 (permalink)
Back in the Saddle
VR4neophyte's Avatar
Drives: 95 VR4 + 03 Vette
Trader Rating: (23)
VR4neophyte Level 7VR4neophyte Level 7VR4neophyte Level 7VR4neophyte Level 7VR4neophyte Level 7VR4neophyte Level 7VR4neophyte Level 7VR4neophyte Level 7VR4neophyte Level 7
Describe your launch technique. Agree that your mods at 20 psi should be able to do better.
VR4neophyte is offline   Reply With Quote
Old 04-03-2006, 12:30 PM   #136 (permalink)
mjannusch's Avatar
Trader Rating: (20)
108 trap with a strong launch and quick shifting should get you in the mid 12's somewhere. Your launch is probably costing you around a half second at the end of the track, maybe more. Fix that to a 1.7 and you'd probably get around 12.6 - 12.7 with the same trap or slightly higher. Might also want to look at your shift points for each gear.
Old 04-03-2006, 12:30 PM   #137 (permalink)
RESIDENT ASSHOLE
DJAuggie's Avatar
Drives: 1996 3000GT VR-4
Trader Rating: (42)
DJAuggie level 6DJAuggie level 6DJAuggie level 6DJAuggie level 6DJAuggie level 6DJAuggie level 6
You should be no where near 108 with 20PSI.
DJAuggie is offline   Reply With Quote
Old 04-03-2006, 12:33 PM   #138 (permalink)
Ready... Steady... GO!!!
Internexus's Avatar
Drives: 92 Stealth RT/TT
Trader Rating: (54)
Internexus Level 7Internexus Level 7Internexus Level 7Internexus Level 7Internexus Level 7Internexus Level 7Internexus Level 7Internexus Level 7Internexus Level 7Internexus Level 7Internexus Level 7
Wow didn't know my car had a twin Just keep fighting it, it only requires around 23psi a ton of mods, and some nitrous to finally clip an 11 I sure hope this set of guys has a solution to this.
-Sean
I'm not A.D.D., I'm just . . . Hey look, a Squirrel!
Internexus is offline   Reply With Quote
Old 04-03-2006, 12:57 PM   #139 (permalink)
Back in the Saddle
Trader Rating: (23)
I'd like to see a WOT log with RPM, TPS, PSI, AFR (WB), NBO2, and EGT.
Old 04-03-2006, 01:18 PM   #140 (permalink)
Z15A Tweaker
Trevor's Avatar
Trader Rating: (15)
Of course you've already got some help. Everything the guys have replied with is spot on. Answer their questions and they may have guidance for you.
Things that jump out at me:
- 110 leaded : all the stuff in that octane range is designed for for bracket racing V-8's. My car always ran like poo on it. No knock...but it wasn't responsive or even all that powerful. Find some VP C16. It's very high octane but besides it being a hair more heasitant to start you really can't tell its in there while behind the wheel. The car will stay decently peppy and you can run a buttload of boost without knock.
- Is your base timing correct? If you don't know for sure then verify it.
- On the same lines is your cam timing spot on?
- What AFR have you been tuning to? I've had good results at 12.3 (+/- 0.2) on C16.
