Old 04-02-2006, 04:22 AM   #121 (permalink)
Island boy
tarekwheeler's Avatar
Drives: 1994 3000GT SL
Trader Rating: (13)
tarekwheeler is an unknown quantity at this point
Default Re: Q&A with Trevor!
Gotcha, thanks!
tarekwheeler is offline   Reply With Quote
Old 04-02-2006, 04:50 AM   #122 (permalink)
Bored User
BOOSTD's Avatar
Drives: 92 Stealth R/T TT
BOOSTD is an unknown quantity at this point
My only question... is my car some bastardized younger sibling/relative of your car? haha. I've been on here forever and have always had the utmost respect for both you and your car, that's for sure.
Nick
Originally Posted by SnakeSkinner View Post
The stuff that goes in the gas tank that makes the car go rrrrmmmm rrrmmmm, it takes x amount of that to make x amount of horsy things that make the tires move.
BOOSTD is offline   Reply With Quote
Old 04-02-2006, 05:27 AM   #123 (permalink)
hated is an unknown quantity at this point
Trevor: Congrats again. Way overdue, but I'm happy to see all your hard work payoff. I had a question for you:
Could you run two stock MAF's (one to each turbo) control it with the e-manage, or AEM, and have enough airflow to support 10's? I ask cuz it may be a way for us Cali guys to pass a visual. Thanks in advance, and keep pushing.
move in silence...
hated is offline   Reply With Quote
Old 04-02-2006, 08:21 AM   #124 (permalink)
Row faster!
WolfSL's Avatar
Drives: 92 VR4 & 98 SL
WolfSL is an unknown quantity at this point
Originally Posted by Trevor
I need to go back...I have a feeling it's around 670-675 AWHP & Torque.
That's on the to-do list.
I realize this a hard question to answer without actually having been to the dyno and not having a graph in front of you with your current setup. But how would you or do you expect the curve to be? i.e. Do you expect the curve to look similar to your 14B graph with power coming on faster when you get on the boost? Or something different from that?
Also outside of the turbo's, were there any other changes that you believe are giving some extra power between your 14B and 16G setup? Would you go with some slightly higher compression pistons and/or a larger overbore if given the chance? Why or why not?
Thanks for your knowledge and insight Trevor
<-- How I plan on going fast
1992 VR-4 - It is being fixed (finally)
1998 SL - DD
WolfSL is offline   Reply With Quote
Old 04-02-2006, 10:16 AM   #125 (permalink)
New project in the works
niterydr's Avatar
Drives: Tractionless wonder
Trader Rating: (33)
niterydr Level 4niterydr Level 4niterydr Level 4niterydr Level 4niterydr Level 4
Not to interject in Trevors thread, but why not gut the mass 100% and install a map sensor hidden in the intake stream? That should pass any cali inspection as you are still using stock looking sensors. Heck, if you grab the wires off the mas plug far enough back, you can still leave the "maf sensor" plugged in.
-Josh
mildly modified blue 93 rt/tt-SOLD
3780lbs, pump gas 3/s. 127.08mph-92 octane.
I still tune cars!
new project, T.B.A
niterydr is offline   Reply With Quote
Old 04-02-2006, 10:40 AM   #126 (permalink)
Pro xfercase destroyer
mjannusch's Avatar
Drives: 2005 Toyota Prius
Trader Rating: (20)
mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7
Good idea with gutting it and whacking off the harness away from the MAF... Instead of putting the MAP in the intake stream, I'd just put a nipple on the underside of the Y-pipe and put the MAP somewhere down by the battery out of the way where nobody would see it. I think it'd look stock enough to pass a visual inspection.
-Matt
'95 3000GT Spyder VR4 (11.838@117.56)
'93 3000GT VR4 (Project for 2009)
'91 3000GT VR4 (Only a shell of its former self)
mjannusch is offline   Reply With Quote
Old 04-02-2006, 12:41 PM   #127 (permalink)
niterydr's Avatar
Trader Rating: (33)
Yeah I was thinking about something along those lines. (Get it lines ).
I didn't mean to actually mount it in the stream, I guess my wording was a bit off.
Old 04-02-2006, 01:31 PM   #128 (permalink)
Z15A Tweaker
Trevor's Avatar
Trader Rating: (15)
Trevor Level 7Trevor Level 7Trevor Level 7Trevor Level 7Trevor Level 7Trevor Level 7Trevor Level 7Trevor Level 7Trevor Level 7Trevor Level 7Trevor Level 7
The ultimate can't mix two Karman Vortex signals together.
It can mix two voltage based sensors together. They did that for the Skylines (RB26DETT). I don't see a way to get it to mix two voltage based sensors then output a single Karman frequency though.
96 Dodge Stealth R/T TT w/59k
10.396 @ 138.94 (C16+Meth)
10.898 @ 130.00 (91+Meth)
Trevor is offline   Reply With Quote
Old 04-02-2006, 01:46 PM   #129 (permalink)
Z15A Tweaker
Trevor's Avatar
Trader Rating: (15)
I bet from 0-4000 they're rally close...the E16G may have 10-15 extra HP in places. Once it hit 4000 I bet they would seperate dramatically. By 4550-4600 the torque will peak out along with the boost. I expect the same shape as the 14b graph from there on up...just magnified.
Here's the old chart if you want to compare:
http://members.cox.net/trevorlj/552AWHP.JPG
I think 90% of the gains I saw from the new E316G setup was the turbos themselves. I think the new intake, 4" exhaust, and methanol setup only accounted for a very small amount of that extra power. It's surprising how much going up from a 6cm2 turbine housing (like I ran with the 14bs) to a newer style 7cm2 housing could make. All without affecting spool...just like I was hoping would happen. Ah well...an extra 3.8 psi from the compressors at 6600 couldn't have hurt either.
I'm not a fan of the big overbores. I chose a 0.039" overbore because thats the max allowed in the service manual. I like having the extra block mass for heat transfer and strength. Plus I don't need any special head gaskets. That overbore alone probably raised my compression to somewhere in the 8.16-8.30 range...which is actually pretty good for pump gas. High compression motors with turbos do well on high octane fuel but they actually end up handicapped if you run them on pump fuel. You end up leaving some power on the table to keep knock at bay.
Old 04-02-2006, 01:58 PM   #130 (permalink)
vehicular thaumaturgist
Multiades's Avatar
Drives: 1994 Stealth TT
Multiades is an unknown quantity at this point
I just noticed that your dyno sheet is with ZERO smoothing. Your car purrs like a kitten.
The Pansy Patrol - a 3000GT/Stealth car blog with how-tos
Pearl Yellow 1994 R/T TT w/84k - FOR SALE! new 4-Bolt factory short block, DR StgII heads, Titan TD05 headers, 14B turbos w/ ported 7cm^2 housings, 3" minimum-bend catless exhaust, SCE oil pan, RPSII clutch, Fidenza flywheel, OZ F1 Plus 17x9.5" wheels, Kumho Ecsta MX 245/45 tires, Drweldin DSM SMICs, 3SX engine mounts (Maximal solid front), GReddy 60mm P/H/W boost, Carbotech Panther Plus & Bobcat pads w/ slotted/drilled rotors, KSport GT-Pro coilovers, Maximal rear camber arms, SCE balljoints, ABS delete w/ cockpit-mounted Wilwood proportioning valve, AC delete, EGR/evap/dashpot delete, cruise/vacuum-tank delete, '95 Lexan headlights, McCulloch 4300K HIDs, GReddy Type-S BOV, solid shift bushings; Misc Parts: Walbro341, 20# fixed-back seats, Accelerated Moto catch can
Multiades is offline   Reply With Quote
