#111 (permalink) | |
#112 (permalink) | |
Pro xfercase destroyer
Short term 2007 goals, maybe.
-Matt
'95 3000GT Spyder VR4 (11.838@117.56) '93 3000GT VR4 (Project for 2009) '91 3000GT VR4 (Only a shell of its former self) ![]() |
#114 (permalink) | |
There's 1400 awhp there. You're just asking for trouble with that. spool is at 6000 rpms, very small powerband. Drag only turbo. with 1000awhp you can run 8's Those guys with 1400rwhp run 59psi. anyways, back to the thread. I'll just have to lower my fuel pressure a bit. Guess that will help on the top end too because pumps wont have to work as hard at 80-90psi. I'll get some extra flow as well. Might have to go with 1200cc injectors though. |
#115 (permalink) | |
Z15A Tweaker
That's on the to-do list.
96 Dodge Stealth R/T TT w/59k
10.396 @ 138.94 (C16+Meth) 10.898 @ 130.00 (91+Meth) ![]() |
#116 (permalink) | |
Z15A Tweaker
I have a local source with a barrel of it. ![]() |
#117 (permalink) |
Viking Style!
A question that I am sure has been asked quite a few times in other threads but I am enjoying learning from this thread heh. Recommend me a setup for mostly street with some track now and then. Would love to reach 400 AWHP and have a wild shot at 11s while still on kind of a budget. Turbos and supporting mods. Give me something to research and plan for the fall with!
"Of all God's creatures, there is only one that cannot be made slave of the leash. That one is the cat. If man could be crossed with the cat it would improve the man, but it would deteriorate the cat." - Mark Twain
#118 (permalink) | |
Z15A Tweaker
Besides that of course you'll need a boost controller, boost gauge, intake (DSM FIPK is cheap and functional), exhaust, and I would spring for a wideband O2 gauge. For a clutch many people have had excellent experiences with the RPS max pressure plate coupled with a full-face street disc. That setup should meet your goals & be reliable while not spending much cash. |
#119 (permalink) |
Island boy
Very good thread Trevor. I've always admired your car <----massive swingage of nuts.
Is there a particular reason you didn't go with a Greddy EBC? Wouldn't it be easier to interface with the Ultimate?(aside from the fact that you already had your EBC installed and set) I was looking at the e-01 and Ultimate combo. Is there anything that I should consider for a different combo?
#120 (permalink) | |
Z15A Tweaker
From what I understand the emanage blue & E-01 only use a USB cable out of simplicity. The pair actually don't communicate using the normal USB protocol/language. The Ultimate on the other hand does use the normal USB protocol/language. |
