#101 (permalink) | |
165 mph and counting...
![]() 1991 Stealth Twin Turbo Mods: 13T turbos, Stillen downpipe, HKS Super Drager catback, Fidanza adjustable cam gears, UR flywheel, DXD-F, DSM sidemount intercoolers, front mount oil cooler, LS6 MAFT, DN Y-pipe, gutted precats, ported exhaust manifolds, Apexi AVC-R set to 1.0 kg/cm, Greddy BOV type S, Supra pump, and an Unorthodox racing pulley. |
#102 (permalink) |
Norcal3S.com
have any video clips of your car at the track?
![]() 13T's + Supporting Mods|DSM SMIC's|K-Sport Coilovers|Battery in Trunk Alchy Injection|Saner Sway Bars|Bronze 17x9 FN01R-C's|3" Straight Pipe 1996 Grand Cherokee: My DD, 4" Lift and 31" Tires ![]() 1992 VR-4: My Weekend Warrior ![]() |
#103 (permalink) |
what do you think about monifold upgrade for example from GTPRo? thanks
evo3 16g's, PTE 780cc, dual walbros, IPO dual feed setup, RPS cc clutch, aem ems, dr stage 3 heads, dr street grind cams, titan headers, ebay fmic, 3.1l, 8.5:1 ross pistons, pauter rods, APR head studs, gtpro head gaskets, mr gears, 1 piece pst driveshaft, setrab oil cooler, BORLA exhaust, etc etc.
Adjustable Control Arms, TEIN S Lowering Springs, re30. 99' Front End Conversion, VIPER Style Hood, 1st Gen Stealth Sideskirts |
#104 (permalink) | |
Z15A Tweaker
Some fuel pumps will do 140-150 psi while still flowing decent numbers. Of course they're huge/expensive external race pumps but you get the jist. Even Walbro's don't dead head until 120-130 psi.
96 Dodge Stealth R/T TT w/59k
10.396 @ 138.94 (C16+Meth) 10.898 @ 130.00 (91+Meth) ![]() |
#105 (permalink) | |
Z15A Tweaker
http://www.spacerat.net/Dori/trev's%2011s.wmv http://members.cox.net/jtrevor/Trevors1112.wmv Really old: http://members.cox.net/trevmov/Stealth.wmv |
#107 (permalink) |
TEXAS!! FIGHT!!
What about modifying the stock manifold to accept a larger throttle body? You could move the throttle body a bit further from the runners to increase the volume of the plenum as well. Could be a very cheap, effective way to pick up a few HP.
PEARL WHITE '93 VR-4 // Under Construction. Looking forward to lighting up the drag radials
E16G's: 10.573 @ 135.01 (Trevor owns me )E16G's: 11.28 @ 124.7 (Pure pump gas ET record )14B's: 11.10 @ 127.3 (AWD 14B ET record. Take THAT, Trev! 9B's: 12.78 @ 107.1 Congrats to the current top 10 members!! DynamicRacing: US 3S Top 10 Fastest List |
#108 (permalink) | |
I'm using the stock runners on my setup though, modified of course, but basically I'm cutting the surge tank off and fitting a bigger, better designed one, on there. As for doing 10's with not a lot of money...sure it's possible. -Big cheap turbos (td05's, hell use adapter plates). ($1500-2000) -Beefed up fuel system, (afpr, boost a pump, 660cc injectors at the least) ($600-900) -fuel management system (a safc can do it, maft pro may be better ~$200-400) -Nice clutch (6 puck may work, but if you need more holding power you may have to go dual disc, but you dont have to go c/c ~$500-1500) That will probably do it. Now you're not going to be as SAFE, or your engine isn't going to be as RELIABLE as people that put more money in (gobs of gauges, oil modifications, internals, $$ clutch), but you can hit 10's with that. Just turn up the boost. 99% of the people here area SCARED to turn up the boost. Good things happen after 16psi, and after 20psi, and after 25psi. I plan on running my next setup to ~40psi on the current turbo. But basically as with anything in life speed/power reliability cheap You can only pick two. P.S. I will post up my modlist when my car is completed, but I'm going for the most reliable car I can with massive power. AFTER selling my entire td04 setup (that was pretty heavily modified) I'm not spending a whole lot of extra cash. For $10k you can have a pretty reliable car that runs 10's. Now I will say, when you start wanting to make over 700awhp or so, cost goes way up. Talking internals, very heavy duty clutch, and lots of preventative stuff to make sure the car doesn't blow.
#109 (permalink) | |
Pro xfercase destroyer
-Matt
'95 3000GT Spyder VR4 (11.838@117.56) '93 3000GT VR4 (Project for 2009) '91 3000GT VR4 (Only a shell of its former self) ![]() |
