Old 05-22-2008, 12:45 PM   #1 (permalink)
MI SCUZI! MI SCUZI!
NeoValentine's Avatar
Drives: Twin Turbo SL
Trader Rating: (44)
NeoValentine is an unknown quantity at this point
Default Prosport Oil Gauge going nuts?
Anyone else have their Electronic ProSport gauge going nuts? Mines jumping between 80-100 psi and down to 0 then all over the place. What could be causing this?
NeoValentine is offline   Reply With Quote
Old 05-22-2008, 12:57 PM   #2 (permalink)
daddy's Avatar
Drives: Lexus IS300 2JZ!!1!1
Trader Rating: (32)
daddy Level 1daddy Level 1
Default Re: Prosport Oil Gauge going nuts?
The gauge defaults to 100psi if the sensor is not connected. Check wiring.
daddy is offline   Reply With Quote
Old 05-22-2008, 01:17 PM   #3 (permalink)
Do it once, do it right
pkchino's Avatar
Drives: 91 RT
Trader Rating: (94)
pkchino is an unknown quantity at this point
Yeah mine worked fine and then it starts to behave like that after a rainy day. I notice if I put thinner oil like 10w30 it will always be at 100psi, after switch to the heavier 15w40 it start behaving "somewhat" normal again.
I think the problem might be the sensor is not of the best quality tho...
96 VR4 - SOLD
Exactly Identical (*) 12
Mechanically Identical (**) 74
Same Model+Option Package 280
Same Model+Build Date 51
91 RT - DD -> SOLD
92 VR4 - SOLD
VERY VERY happy customer of 3S Motorsports
pkchino is offline   Reply With Quote
Old 05-22-2008, 01:20 PM   #4 (permalink)
Pearl White 92 Stealth TT
mike92stealthtt's Avatar
Drives: 100+ IDC's
mike92stealthtt is an unknown quantity at this point
Mine works well. I would check your ground.
mike92stealthtt is offline   Reply With Quote
Old 05-22-2008, 01:36 PM   #5 (permalink)
MI SCUZI! MI SCUZI!
Trader Rating: (44)
Thanks guys I'll look into those.
Old 05-22-2008, 02:15 PM   #6 (permalink)
Breaks all but Xfer case
flyman1981's Avatar
Drives: 08 RAM HEMI, 93 VR-4
Trader Rating: (7)
flyman1981 is an unknown quantity at this point
Mine acted like this when the wire on the sender was loose.
Black 93 VR-4
12.60 @ 108 w/ 9b's, 550's BlowThrough MAFT and E-Manage
11.77 @ 123 w/ 14b's (22psi), FMIC, MAFTPRO, 650's
??.?? @ ??? w/ 14b's (26psi)
??.?? @ ??? w/ 14b's (24psi) + NOS (35shot)
Show and Go:
98 rear garnish, EGR block off plates, Intrax, JayVR4 control arms, 1-4 Syncros, Kormex output shaft, RPS MAX Street Disc, Resurfaced Flywheel, ATR Downpipe, HKS SQV, Dejon dual intakes, AEM Wideband, mobo shift/ebrake boots, Battery Relocation, MAFT PRO, 14B +20G Turbos, DNP TDO5 Headers, Tial Wastegates, DNP FMIC, P+P Heads, 99 Lifters, Vac Reduction, 98 Body kit, 94 Robot headlights, Ross Pistons, Balanced Crank, 720cc's, IPO FPR w/ Gauge, Flexalite fans, Boost a Pump, ARP Head Studs, CF 575 Hood, NOCAR Xfer Case, Veilside CF spoiler, ACPT CFDS, 19x9 SSR D5R, Blitz SBC-ID, Prosport gauges, Corbeau LG1's, Yogurt's 4" cat-back, Twin Walpros dual feed fuel system, Boost a Spark, AEM EMS
flyman1981 is offline   Reply With Quote
Old 05-22-2008, 02:27 PM   #7 (permalink)
Slowest 3/S in chicago
DaveSlow's Avatar
Drives: 93 VR-4 & 98 M3
Trader Rating: (25)
DaveSlow is an unknown quantity at this point
I've seen this on another unit as well.
People really gotta stop buying prosport garbage.
DaveSlow is offline   Reply With Quote
Old 05-22-2008, 03:03 PM   #8 (permalink)
Drunk as a lord
Forest Gump's Avatar
Drives: 1992 Stealth TT
Trader Rating: (51)
Forest Gump Level 1Forest Gump Level 1Forest Gump Level 1
no, people need to double check their wiring before jumping to conclusions.
The gauge will read 100PSI if you unhook the sending wire or attach it to ground. He probably has the wire rubbing on something and it is wearing in two or grounding out.
Power:13Ts, 550s, SAFC, K&N, Downpipe, ATR Catback, DevilsOwn meth, UDP, SSQV, EVC5, Walbro, IK24s
Best 1/4 12.62 @ 111.9 2.0 60 FT Best 1/8th 8.00 @ 87.24 1.80 60FT
Suspension: Konig Villians, Pilot A/S, Tein S-Techs, Hawk HPS Pads, 2G front brakes AWS Delete
Drivetrain: ACT HDMM, 300m O/S, PST 2 piece Al/Steel Driveshaft, F&R Poly Mounts, EK2 ExoCage
Etc: Leatherseats.com Charcoal/Grey Interior, 99 front end/lights/wing/sideskirts/doorcaps, Scanmaster3, AEM UEGO
Forest Gump is online now   Reply With Quote
Old 05-22-2008, 04:20 PM   #9 (permalink)
MI SCUZI! MI SCUZI!
Trader Rating: (44)
So check the sender wire or the Ground wire?
Old 05-22-2008, 05:26 PM   #10 (permalink)
tonygold's Avatar
Trader Rating: (34)
tonygold Level 1tonygold Level 1
Is Prosport realy that bad!?!?!??!
tonygold is offline   Reply With Quote
