Old 08-22-2008, 02:29 PM   #31 (permalink)
3.0 again
Trader Rating: (6)
3.5stealth is an unknown quantity at this point
Default Re: pros and cons of your boost controller
Old School Apexi AVC-D
Pros: Cheap, easy to use, install, RPM dependant adj. on the fly.
Cons: Hard to find, no english instruction available.
I guess not having a display could be a con but thats why I have a boost gauge. Scramble mode is cool instant temp. boost increase (adjustable) at the push of a momentary switch.
3.5stealth is offline   Reply With Quote
Old 08-22-2008, 03:50 PM   #32 (permalink)
is drifting WAY too hard!
Deathsled's Avatar
Drives: only in 1st gear
Trader Rating: (20)
Deathsled Level 7Deathsled Level 7Deathsled Level 7Deathsled Level 7Deathsled Level 7Deathsled Level 7Deathsled Level 7Deathsled Level 7Deathsled Level 7Deathsled Level 7Deathsled Level 7
I really want one of these. I always miss them on ebay
96 VR4 w/ Iridium Intercooler
Deathsled is offline   Reply With Quote
Old 08-22-2008, 04:45 PM   #33 (permalink)
king of ghetto
Highboosted's Avatar
Drives: '94 Stealth Turbo
Trader Rating: (29)
Highboosted Level 5Highboosted Level 5Highboosted Level 5Highboosted Level 5Highboosted Level 5Highboosted Level 5
Open wastegates
Pros:
max boost
max spool
max powa!
Cons:
no more pump gas
good way to blow up a motor
pıdnʇs 'ɹǝʌo ǝɯ dılɟ
Official member of the "I upgraded everything in my car and now it's slower than stock" club.
Highboosted is offline   Reply With Quote
Old 10-04-2008, 03:36 PM   #34 (permalink)
HVY HITR
Erick's Avatar
Drives: 94.99 STEALTH TT
Erick level 6Erick level 6Erick level 6Erick level 6Erick level 6Erick level 6
Had Greddy Profec and the 2nd version
liked the original but it would still change in drastic temps.
Now have a Blitz Boost control and its flawless
only thing is I still dont see much changes when adjusting gain, what are others set at? mines at 30 now.
94.99 2nd Gen TT - DR650s & then sum - Daily Driver
buy me http://www.3si.org/forum/f10/here-94...cs-etc-441204/
Erick is offline   Reply With Quote
Old 10-05-2008, 10:41 AM   #35 (permalink)
L_P
Woot!
L_P's Avatar
Drives: '95 Dodge Stealth TT
Trader Rating: (29)
L_P Level 2L_P Level 2L_P Level 2
AEM Tru Boost
Pro:
Gauge and controller in one!
Easy to read LED plus gauge sweep
Auto Dimming (Day/Night)
External MAP Sensor for high boost reading and so you don't have to run a vac line into the cabin.
Small valve footprint.
Three settings A/B/Off (WG pressure)
Cons:
Kinda a PITA to configure and get set just right
Price not that great unless you compare price of a gauge and a EBC together.
Recommend:
Yes indeed, well worth it to have one device in the cabin to watch and adjust plus if you have a AEM WB they match!
1995 Dodge Stealth R/T TT, Dark Green ext, Dark Int, 1 of 20 available to the US.
Mods: 13T/E3 16G turbos, FMIC 3" in/out, Spec Stage 3 clutch, RPS Billet Aluminum Flywheel, Gutted front and rear precat, test pipe, MSD 8.5mm SC Wires, 3rd Gen lifters, EGR Delete, 3SX EGR Block off plates, Blitz DD BOV, Hotwire Walbro 255 Fuel pump, Map ECU, Dual Pillar pod w/ AEM Wideband and AEM Tru Boost, Halo Hybrid Data logger, Supercar Engineering 1/2 billet aluminum Shift fork, fresh 1/2/3 friction rings, custom solid engine mounts, 3" Straight pipe exhaust single out.
Looks: DCC Conversion, White face glow gauges.
Sound: Infinity components up front, infinity 10" sub in back with Smokin' VR4 corner sub box, Pioneer HU.
Myspace
Must go faster project underway. E85 powered
Front E3 16G installed, next is the rear one!
Equal length headers custom made.
L_P is online now   Reply With Quote
Old 10-05-2008, 10:43 AM   #36 (permalink)
og
chansigril's Avatar
Drives: 93 stealth rt tt
Trader Rating: (48)
chansigril Level 7chansigril Level 7chansigril Level 7chansigril Level 7chansigril Level 7chansigril Level 7chansigril Level 7chansigril Level 7chansigril Level 7chansigril Level 7chansigril Level 7
Originally Posted by L_P View Post
AEM Tru Boost
Pro:
Cons:
Recommend:
john,
out of curiousity, can you log with that external map sensor? in other words, will it work with a palm datalogger, mmcd or otherwise?
*edit* or with the scanmaster 3? */edit*
93 stealth r/t tt: mildly modified, 12.4@109
94 stealth r/t na: used to drive, 13.9@100
93 dodge stealth r/t tt: personal parts car
03 ford focus se: beater
chansigril is offline   Reply With Quote
Old 10-05-2008, 10:56 AM   #37 (permalink)
NJStealthTT's Avatar
Drives: 92TT, 95RT, 97VR6
Trader Rating: (35)
NJStealthTT Level 4NJStealthTT Level 4NJStealthTT Level 4NJStealthTT Level 4NJStealthTT Level 4
I have the HKS IV
Pros: very stable, little to no spiking. overboost warning, max of 36psi
Cons: I have Very little complaints, except the knob is very sensitive and hard to adjust while driving.
Price was great on ebay
here is some info on it:
VC IV - Silver features
Peak Boost Hold Memory Function
Adjustable up to 2.5bar (36.25psi)
Real time Digital Boost and Vacuum Display
White-Colored Backlit Liquid Crystal Display Screen
High and Low Boost Preset Levels
Scramble Boost feature
External Scramble Boost Trigger available
Visual and Audible overboost warning feature
Internal and External wastegate applicable
Precision “closed-loop” boost regulating stepping motor
Fuzzy Logic Programming will learn natural boost curve and optimize it.
Flash Memory
Limited Edition Silver Colored Casing
Girl: "you know..my obsession with shoes is just like your obsession with cars"
--"no it's not, cause your shoes are ugly."
NJStealthTT is offline   Reply With Quote
Old 10-05-2008, 07:19 PM   #38 (permalink)
L_P
Woot!
L_P's Avatar
Trader Rating: (29)
Would be a lot of work but the HHH logger has the custom inputs so in a way you could if the logger that you are using has that feature. Not so sure how reliable it will be once you tap the line to read it though. But anything is possible I would assume.
Originally Posted by chansigril View Post
john,
Old 10-05-2008, 10:21 PM   #39 (permalink)
Mike94TT's Avatar
Drives: 94 Dodge Stealth TT
Mike94TT is an unknown quantity at this point
Blitz SBC i-D
Displays real-time boost and peak boost, love the option for the programmable overboost failsafe. If you use the manual settings instead of just putting in a given boost pressure I've noticed fluctuation between hot and cold weather. It spikes sometimes in 1st gear on me, although I haven't messed with the gain at all. And it fits perfectly in the center dash vent.
94 Pearl Yellow Stealth TT
3SXecutioners | PTE 680cc injectors | Denso Supra Fuel Pump w/ hotwire kit | EK2 Fuel Rail Loop | AEM EMS | AEM UEGO Controller | AEM MAP Sensor | AEM IAT Sensor | Blitz SBC i-D | Dejon Powerhouse Dual Intakes | TurboXS RFL BOV | 3SX Poly Motor Mounts | 3SX Aluminum Crank Pulley | 3SX Downpipe | Gutted Precats | ICH 3" Single Catback Exhaust w/ test pipe | RPS Max Series Street Clutch | Fidanza Flywheel | Front & Rear Drilled/Slotted Rotors | Stillen Metal Matrix Brake Pads
Mike94TT is offline   Reply With Quote
Old 10-05-2008, 10:41 PM   #40 (permalink)
Drives: 1996 VR4
Dunshster Level 7Dunshster Level 7Dunshster Level 7Dunshster Level 7Dunshster Level 7Dunshster Level 7Dunshster Level 7
I have a Tru-Boost, will most likely be selling for another option very soon.
Pro's:
Cheaper than some of the other EBC's
Looks nice
Cons:
Cannot fix boost spikes
Inconsistent boosting (1 pull might get 14.7psi, the other might be 13.9)
Dunshster is offline   Reply With Quote
