#21 (permalink) | |
og
also good feedback on manual boost controllers. i've known a number of folks with them and it seems there's a wide range of quality
93 stealth r/t tt: mildly modified, 12.4@109 ![]() 94 stealth r/t na: used to drive, 13.9@100 ![]() 93 dodge stealth r/t tt: personal parts car 03 ford focus se: beater |
#22 (permalink) | |
Are you running internal or external wategates?
Regards,
Leonel |
#23 (permalink) |
I`ve got an ancient Blitz SSBC.
Pros`s; Very simple to install. Very reliable. Holds boost setting very well, do not need to adjust with ambient temp change. Cons; You adjust the gain with a screwdriver.. I have never found an English manual for it. For what I use it for and how it`s wired (comes on with the Meth pump at 80%+ thottle over 2500rpm) it does great.
JDM GTO TT, Emanage Blue - 450`s Hotwired Walbro - K&N - Blitz SSBC Port Methanol Injection - E85 - 12.4@115 |
#24 (permalink) |
Hallmans Pro MBC.
Pro - easy install, set and forget, never flutters, never spikes. Cons - more expensive than most MBC's but it comes with being the best.
His - Red 93 RT/tt
Mods: Hallman's MBC @ 16 psi, turbo XS type H BOV, stillen dp, custom exhaust, Spec stage 2 clutch, RPS FW, 3sx lightweight crank pulley, BCP7RES-11 @ .030 gap, autometer gauges, slightly gutted mas, dsm SMIC's, ACPT 1 piece CFDS, Tein S springs, pte 580 inj's, safc neo/SITC, 13t's, hotwired walbro, maximal performance solid motor mounts, DR plenum spacer. Hers - BPU Green 94 vr4 |
#25 (permalink) |
SOHC you in the FACE
Grainger Valve.
Pros- =Ball and spring so it doesnt open until your boost level is reached (which means wastegate doesnt crack open early). That means it works just as good as a couple hundred dollar controller. -$7 -stays within 0.1psi (i have good gauges and datalogging )Cons -wont work if you are stupid and get the bleed hole dirty or dont make it the correct size. -Wont work if you dont take it apart every year or so to clean it. -Not for people to lazy to wipe their own butt. -Wont fix problems that your crappy car/wastegates/installation/low IQ is at fault for.
Brent
1992 Duster -12.7@114 - 14psi boost -13.9@107.4 - 5psi - 6g72 3.13L "built" SOHC, Precision T67 P-trim, Tial 38mm open dump, 3" downpipe, 20x12x3" evo style intercooler, 7:1 compression, balanced, shot peened rods, heavily ported heads (+40% on flowbench), Ferrea Competition Plus +2 +1 stainless valves, Nielson Vintage 278 duration custom turbo cams, RPW Cam gears, Custom Ram Style short runner intake manifold, Walbro 255hp, 6*47# injectors, +0.096" Forged Venolias, Total Seal chrome gapless top rings, Fidandza Flywheel, Clutchnet 3 puck solid hub, OBX Helical LSD, Zeitronix wideband/EGT/Boost sensors, 100watt DevilsOwn Meth Kit. 1994 Spirit - 13.987@101.89 - 5psi- 6g72 SOHC, K27 Turbo ![]() |
#26 (permalink) | |
Driving While Ukrainian
TruBoost
pros: easy to install (if you know how to), works great, controller and gauge all in one, etc... cons: not that cheap, if you don't have instruction its pain. boost spike? maybe. but on e85 its not a problem..
1993 3000GT VR4.
![]() ________________________ Was bored, had to do stuff: Cross drilled/slotted rotors, S-Tein springs, BOV, intake, exhaust, Datalogger, S-AFC, AEM TruBoost, 560cc, XTD Stage 3 clutch, hotwired 255lph fuel pump, DSM SMICs. Working on: Driver mod. E85 powered VR4 For Sale: stock injectors and pump. Dream car: F40 (LM) Quote:
#27 (permalink) |
Mr. Cheese
AEM TruBoost
Pro's Easy to install. 2 boost settings plus an "off" (wastegate setting) with one button push Looks great Accurate boost gauge Never had a boost spike and I log and constantly moniter Cons, Expensive I really like this boost controller, I had a greddy profec spec b and I always got boost spikes and my boost was always changing. This one I have never had a spike other then maybe .25 to .5 a lbs spike once in a blue moon. I got this after a guy from my local club had it and had great results with it. I got it, we set mine to the exact settings that he had and it works perfectly ![]()
1992 Dodge Stealth RT-Twin Turbo
64,000 miles, Stored Winters, AEM Tru-Boost, Greddy Type S BOV, DNP Hardpipes, Palm MMCD, Tein S-Tech Springs, Brembo Rotors, MSD Wires, K&N FIPK, EGR Delete, Vacuum Reduction, Cianci 3 Gauge A-Pillar, 5zigen FN01R-C 18x9.5's wrapped in BFG KDW 265-35-18's. 13% Tint, 12 Disc CD changer, 3 1/2 inch Custom Exhaust. ![]() DD-Pearl White 92 Stealth TT-85,000 on it, BPU 270 awhp, 307 awtq on 8-23-08 |
#28 (permalink) |
Profesional Insomniac
Profec B spec II
Pros Good control Low and High settings Digital display, records your peak Can set up warning levels Very little spike (I'm usually spiking about 15.2 and holding 14.7) Looks great, half din size provides great mounting options, I have mine mounted below my radio. ![]() Cons A little tricky to get used to, but once you're used to it it's easy. If you like the Profec I would go with this one, pretty much the same as the old one, but with a digital display.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
#29 (permalink) |
old Greddy Profec-A (fuzzy logic)
Pros: zero boost spike, and I mean none. When I asked for 14.5psi it was within 14.49 and 14.51 psi which totally shocked me how good it is, verified using emanage datalogger. Super easy to change boost, no need to estimate any stupid duty cycle numbers, what you asked for is what you got. No need to look up a manual when changing boost, as it's just one knob. Cons: programming fuzzy logic requires you to do a 3rd gear run which where I live means you'll lose your license for 1 week, impound your car for a week, and a $2,000-$10,000 ticket, not to mention increased car insurance for next several years. ![]() At higher boost ie 17psi, the fuzzy logic sometimes gets confused with twin turbos and drops your boost level. This makes it a poor choice if you run upgraded turbos, which is the reason why I got rid of it. Greddy Profec B Spec II Pros: It works with upgraded turbos, but doesn't have much of a brain. Cons: Can't select a particular boost level, you have to estimate duty cycle numbers and see where it got ya with making a couple runs. Often have to refer to the manual as it's confusing. Observation: Boost numbers fluctuate a little bit as there's no feedback control, this is pretty much true with most electronic boost controllers. I miss that fuzzy logic. |
#30 (permalink) | |
wiggedywiggedywack yo!
Pros: rock solid boost control Cons: sucks trying to get 2 back to back 3rd gear pulls for it to "learn" the boost curve. i've had better luck with the learning mode in 2nd gear.
![]() Mods: TD05 14b's, 10.0:1 NA Pistons, AEM EMS, etc... //img507.imageshack.us/img507/389/newsigtj8.jpg //img34.echo.cx/img34/4804/td05sig4ji.jpg |
