Old 05-16-2008, 11:56 PM   #11 (permalink)
Place electrodes now
1brett's Avatar
Drives: Yes.
Trader Rating: (24)
1brett is an unknown quantity at this point
Default Re: pros and cons of your boost controller
Originally Posted by leonel View Post
SBC ID 3
Easy to install.
handles about 36 psi
nice display.
easy to set.
fully digital
Cons are none other than price!
Same here - only real con is price, but still worth it to me. Solenoid is a little large, but that's a real stretch for another con.
Other pros:
Boost comes on quickly and smoothly, no spikes.
Boost graph.
Peak/hold boost gauge built in. Saved a little money and dash space on a gauge. (And fun to laugh at with wife when she takes the car out and brings it back peaked at 7.8psi.)
4 "channels" (presets) for quick setting.
1brett is offline   Reply With Quote
Old 05-17-2008, 03:35 AM   #12 (permalink)
Unknown 3000GT VR4 :)
Dj_Frost's Avatar
Drives: 94 Rare VR4
Trader Rating: (22)
Dj_Frost is an unknown quantity at this point
Blitz SBCiD III
Pro's:
Read in bar or PSi
Easy to use interface
4 channels
no boost spikes
cons:
my solenoids died and now I have to shell out $220 to replace both of them.
Daily Driver: 2002 BMW 330ci (Angel Eyes+HID, 19" Rims, aFe Stage 2 Intake, ACS Exhaust, Interior Detailing)
Wkend Ride: Rare 1994 Custom Pearl White/Blue 3000GT VR4 - 82250 Miles - Weight: 3560lbs
Best 1/4 Time: 13.0@???MPH with a ?.?? 60' Ft
Click to read all about my rare 3000GT VR4 <---> Rate my vr4!
Performance:
15G's, EVO 560cc, Hotwired Supra Pump, E2K Fuel Loop, EMU, FMIC+PPE Pipes, IPS Quad Tip Setup, ACPT 1 Piece CFDS, HKS SSBOV, 5 Defi BF Gauges, HKS Turbo Timer Type I, RaceConcepts Dimple Drilled/Slotted Rotors, 3sx Lightened crank pulley, 3SX SS Brake Lines (Blue), HPF 3S clutch + RPS Flywheel, 3rd Gen Lifters, Accel 8mm blue wires, Mongorunner's Grounding Kit (Blue), Rear battery mod
Handling:
255/40/18 - 18x8.5" OZ F1 Racing Rims, 3SX/Saner Front & Rear AWD Sway Bars, KYB Struts, H&R Stage 2 Springs, 3SX Rear Control Arms, Black Corbeau CR-1's
Sight & Sound:
99 Conversion, Custom Viper Style Hood, Modded Rear Bumper, VLS, Brightstar 6500k HIDs, Custom Pearl White/Blue Paint, AutoVation's VR-4 Matte Pedals, MH Gauge Faces & Glow Needle Kit, Kenwood Excelon X679 Mp3/CD Player, 2 Rockford Fosgate Punch Amps (160x4 & 135x2), RF Components P1625, 2 8" RF Subs
Misc:
Replaced ECU Caps.
Sponsored by: Mongo PiMPiN Performance
Dj_Frost is offline   Reply With Quote
Old 05-17-2008, 03:49 AM   #13 (permalink)
Forum user
beckerb's Avatar
Drives: Stealth RT TT
beckerb Level 1beckerb Level 1
Other pros:
Boost graph.
Same as above - did have the controller fail when it was first put in - replaced at no cost - The controls are very user friendly...
Not to old to have fun - yet ??? -
2007 Dodge SRT-8 Superbee
2007 Hemi Quad Cab 4X4
2006 Harley V-Rod , 1999 S&S 1200 Sportster
2005 H/D FatBoy(Stage II),1973 BMW R75/5 restored
2004 Ducati Monster SR2,1972 BMW R75/5 restored
2004 Ford MACH I Mustang, Pro-Charger 535 RWHP
2002 Viper SRT-10,2000 Custom 883 Sportster
1992 Stealth RT TT (Stage III) 633.9 AWHP
1992 Stealth RT
1991 Stealth RT TT
and More
beckerb is offline   Reply With Quote
Old 05-17-2008, 04:00 AM   #14 (permalink)
In Training
etecnifibre's Avatar
Drives: 1995 Stealth R/T TT
Trader Rating: (57)
etecnifibre Level 2etecnifibre Level 2etecnifibre Level 2
Joe P MBC
Pros:
Has held the boost I set it at for a year and a half with no adjustments.
Only spikes to about 1.03 bar at WOT, have it set at .94.
Neat, clean install. Nothing inside the cabin to worry about
Cons:
Have to get under the hood if I ever wish to adjust it.
K/N FIPK ll 3SX Downpipe ll Joe P. MBC ll Vac. Redux ll Precat Elims ll NGK 8MM Plug Wires ll Evo 8 BOV ll Test Pipe ll 99 Lifters ll FP Hotwire ll Bilstein Struts ll H&R Springs ll Blitz Turbo Timer w/boost gauge ll SS brake lines ll '99 Headlights and Turns ll Hybrid Datalogger ll 3SX 2" Core Radiator ll ACPT 1pc CFDS ll F/R Solid Mounts ll Side Poly Mounts
Stealth owners....Get vinyl lettering for your calipers!
etecnifibre is offline   Reply With Quote
Old 05-17-2008, 04:29 AM   #15 (permalink)
Wrenchmonkey #839
John Monnin's Avatar
Drives: crappy SHO
Trader Rating: (27)
John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7
I had 3 different manual Boost controllers
1. Boost controller.com = eorkrd perfectly for 1 year then it would get stuck at 6 psi
2. Boost controller.com = JermyG's boost controller, worked perfectly for him, but My boost would drift around +- 2 psi depending on weather.
3. Voodoo MBC : It woul stick if I mooutned it sideways, I had to mount it with adjuster pointign stright up to wrok right. Boost would change +- 4 pis depedning on weather.
4. Boost DSBC, old one, worked perfect just wish didpsly was in PSI.
5. Greeddy, I just never liked it, it was hard to use compared to the Blitz
See this thread to buy remote IAC mounting block:
http://www.3si.org/forum/f4/f-s-remo...bodies-416611/
1992 Stealth TT
For sale 3.5L 6g74 Swap modified oil pans and thermostat hosuings
http://www.3si.org/forum/f4/fs-6g74-...ied-3s-420690/
John Monnin is offline   Reply With Quote
Old 05-17-2008, 05:44 AM   #16 (permalink)
og
chansigril's Avatar
Drives: 93 stealth rt tt
Trader Rating: (43)
chansigril is an unknown quantity at this point
i have noticed many boost controllers fluctuate as temperature and humidity change, including my greddy profec b spec 1. i didn't note this as a con since just about everyone i have spoken to have had this issue. does anyone not have this happen?
93 stealth r/t tt: mildly modified, 12.4@109
94 stealth r/t na: used to drive, 13.9@100
03 ford focus se: beater
chansigril is offline   Reply With Quote
Old 05-17-2008, 06:01 AM   #17 (permalink)
Forum user
beckerb's Avatar
I have not noticed it on the Blitz controller in my RT/TT and I run as high as 28.5 psi at the strip....dont know about other with Blitz controllers - sure they will speak up....
