#31 (permalink) |
3.0 again
Old School Apexi AVC-D
Pros: Cheap, easy to use, install, RPM dependant adj. on the fly. Cons: Hard to find, no english instruction available. I guess not having a display could be a con but thats why I have a boost gauge. Scramble mode is cool instant temp. boost increase (adjustable) at the push of a momentary switch. |
#32 (permalink) | |
is drifting WAY too hard!
![]() ![]() 96 VR4 w/ Iridium Intercooler |
#33 (permalink) |
king of ghetto
Open wastegates
Pros: max boost max spool max powa! Cons: no more pump gas good way to blow up a motor
pıdnʇs 'ɹǝʌo ǝɯ dılɟ
Official member of the "I upgraded everything in my car and now it's slower than stock" club. |
#34 (permalink) |
HVY HITR
Had Greddy Profec and the 2nd version
liked the original but it would still change in drastic temps. Now have a Blitz Boost control and its flawless only thing is I still dont see much changes when adjusting gain, what are others set at? mines at 30 now.
94.99 2nd Gen TT - DR650s & then sum - Daily Driver
![]() buy me http://www.3si.org/forum/f10/here-94...cs-etc-441204/ |
#35 (permalink) |
Woot!
AEM Tru Boost
Pro: Gauge and controller in one! Easy to read LED plus gauge sweep Auto Dimming (Day/Night) External MAP Sensor for high boost reading and so you don't have to run a vac line into the cabin. Small valve footprint. Three settings A/B/Off (WG pressure) Cons: Kinda a PITA to configure and get set just right Price not that great unless you compare price of a gauge and a EBC together. Recommend: Yes indeed, well worth it to have one device in the cabin to watch and adjust plus if you have a AEM WB they match! -John
1995 Dodge Stealth R/T TT, Dark Green ext, Dark Int, 1 of 20 available to the US.
Mods: 13T/E3 16G turbos, FMIC 3" in/out, Spec Stage 3 clutch, RPS Billet Aluminum Flywheel, Gutted front and rear precat, test pipe, MSD 8.5mm SC Wires, 3rd Gen lifters, EGR Delete, 3SX EGR Block off plates, Blitz DD BOV, Hotwire Walbro 255 Fuel pump, Map ECU, Dual Pillar pod w/ AEM Wideband and AEM Tru Boost, Halo Hybrid Data logger, Supercar Engineering 1/2 billet aluminum Shift fork, fresh 1/2/3 friction rings, custom solid engine mounts, 3" Straight pipe exhaust single out. Looks: DCC Conversion, White face glow gauges. Sound: Infinity components up front, infinity 10" sub in back with Smokin' VR4 corner sub box, Pioneer HU. Myspace Must go faster project underway. E85 powered Front E3 16G installed, next is the rear one! Equal length headers custom made. |
#36 (permalink) | |
og
out of curiousity, can you log with that external map sensor? in other words, will it work with a palm datalogger, mmcd or otherwise? *edit* or with the scanmaster 3? */edit*
93 stealth r/t tt: mildly modified, 12.4@109 ![]() 94 stealth r/t na: used to drive, 13.9@100 ![]() 93 dodge stealth r/t tt: personal parts car 03 ford focus se: beater Last edited by chansigril : 10-05-2008 at 10:44 AM. Reason: added scanmaster |
#37 (permalink) |
I have the HKS IV
Pros: very stable, little to no spiking. overboost warning, max of 36psi Cons: I have Very little complaints, except the knob is very sensitive and hard to adjust while driving. Price was great on ebay here is some info on it: VC IV - Silver features Peak Boost Hold Memory Function Adjustable up to 2.5bar (36.25psi) Real time Digital Boost and Vacuum Display White-Colored Backlit Liquid Crystal Display Screen High and Low Boost Preset Levels Scramble Boost feature External Scramble Boost Trigger available Visual and Audible overboost warning feature Internal and External wastegate applicable Precision “closed-loop” boost regulating stepping motor Fuzzy Logic Programming will learn natural boost curve and optimize it. Flash Memory Limited Edition Silver Colored Casing
![]() Girl: "you know..my obsession with shoes is just like your obsession with cars" --"no it's not, cause your shoes are ugly." |
#38 (permalink) |
Woot!
Would be a lot of work but the HHH logger has the custom inputs so in a way you could if the logger that you are using has that feature. Not so sure how reliable it will be once you tap the line to read it though. But anything is possible I would assume.
-John |
#39 (permalink) |
Blitz SBC i-D
Displays real-time boost and peak boost, love the option for the programmable overboost failsafe. If you use the manual settings instead of just putting in a given boost pressure I've noticed fluctuation between hot and cold weather. It spikes sometimes in 1st gear on me, although I haven't messed with the gain at all. And it fits perfectly in the center dash vent.
94 Pearl Yellow Stealth TT
![]() 3SXecutioners | PTE 680cc injectors | Denso Supra Fuel Pump w/ hotwire kit | EK2 Fuel Rail Loop | AEM EMS | AEM UEGO Controller | AEM MAP Sensor | AEM IAT Sensor | Blitz SBC i-D | Dejon Powerhouse Dual Intakes | TurboXS RFL BOV | 3SX Poly Motor Mounts | 3SX Aluminum Crank Pulley | 3SX Downpipe | Gutted Precats | ICH 3" Single Catback Exhaust w/ test pipe | RPS Max Series Street Clutch | Fidanza Flywheel | Front & Rear Drilled/Slotted Rotors | Stillen Metal Matrix Brake Pads |
#40 (permalink) |
I have a Tru-Boost, will most likely be selling for another option very soon.
Pro's: Cheaper than some of the other EBC's Looks nice Cons: Cannot fix boost spikes Inconsistent boosting (1 pull might get 14.7psi, the other might be 13.9)
