#11 (permalink) | |
Place electrodes now
Other pros: Boost comes on quickly and smoothly, no spikes. Boost graph. Peak/hold boost gauge built in. Saved a little money and dash space on a gauge. (And fun to laugh 4 "channels" (presets) for quick setting. |
#12 (permalink) |
Unknown 3000GT VR4 :)
Blitz SBCiD III
Pro's: Read in bar or PSi Easy to use interface 4 channels no boost spikes cons: my solenoids died and now I have to shell out $220 to replace both of them.
Daily Driver: 2002 BMW 330ci (Angel Eyes+HID, 19" Rims, aFe Stage 2 Intake, ACS Exhaust, Interior Detailing)
Wkend Ride: Rare 1994 Custom Pearl White/Blue 3000GT VR4 - 82250 Miles - Weight: 3560lbs Best 1/4 Time: 13.0@???MPH with a ?.?? 60' Ft Click to read all about my rare 3000GT VR4 <---> Rate my vr4! Performance: 15G's, EVO 560cc, Hotwired Supra Pump, E2K Fuel Loop, EMU, FMIC+PPE Pipes, IPS Quad Tip Setup, ACPT 1 Piece CFDS, HKS SSBOV, 5 Defi BF Gauges, HKS Turbo Timer Type I, RaceConcepts Dimple Drilled/Slotted Rotors, 3sx Lightened crank pulley, 3SX SS Brake Lines (Blue), HPF 3S clutch + RPS Flywheel, 3rd Gen Lifters, Accel 8mm blue wires, Mongorunner's Grounding Kit (Blue), Rear battery mod Handling: 255/40/18 - 18x8.5" OZ F1 Racing Rims, 3SX/Saner Front & Rear AWD Sway Bars, KYB Struts, H&R Stage 2 Springs, 3SX Rear Control Arms, Black Corbeau CR-1's Sight & Sound: 99 Conversion, Custom Viper Style Hood, Modded Rear Bumper, VLS, Brightstar 6500k HIDs, Custom Pearl White/Blue Paint, AutoVation's VR-4 Matte Pedals, MH Gauge Faces & Glow Needle Kit, Kenwood Excelon X679 Mp3/CD Player, 2 Rockford Fosgate Punch Amps (160x4 & 135x2), RF Components P1625, 2 8" RF Subs Misc: Replaced ECU Caps. Sponsored by: Mongo PiMPiN Performance --> |
#13 (permalink) | |
Forum user
Not to old to have fun - yet ??? -
2007 Dodge SRT-8 Superbee 2007 Hemi Quad Cab 4X4 2006 Harley V-Rod , 1999 S&S 1200 Sportster 2005 H/D FatBoy(Stage II),1973 BMW R75/5 restored 2004 Ducati Monster SR2,1972 BMW R75/5 restored 2004 Ford MACH I Mustang, Pro-Charger 535 RWHP 2002 Viper SRT-10,2000 Custom 883 Sportster 1992 Stealth RT TT (Stage III) 633.9 AWHP 1992 Stealth RT 1991 Stealth RT TT ![]() and More |
#14 (permalink) |
In Training
Joe P MBC
Pros: Has held the boost I set it at for a year and a half with no adjustments. Only spikes to about 1.03 bar at WOT, have it set at .94. Neat, clean install. Nothing inside the cabin to worry about Cons: Have to get under the hood if I ever wish to adjust it.
K/N FIPK ll 3SX Downpipe ll Joe P. MBC ll Vac. Redux ll Precat Elims ll NGK 8MM Plug Wires ll Evo 8 BOV ll Test Pipe ll 99 Lifters ll FP Hotwire ll Bilstein Struts ll H&R Springs ll Blitz Turbo Timer w/boost gauge ll SS brake lines ll '99 Headlights and Turns ll Hybrid Datalogger ll 3SX 2" Core Radiator ll ACPT 1pc CFDS ll F/R Solid Mounts ll Side Poly Mounts
Stealth owners....Get vinyl lettering for your calipers! |
#15 (permalink) |
Wrenchmonkey #839
I had 3 different manual Boost controllers
1. Boost controller.com = eorkrd perfectly for 1 year then it would get stuck at 6 psi 2. Boost controller.com = JermyG's boost controller, worked perfectly for him, but My boost would drift around +- 2 psi depending on weather. 3. Voodoo MBC : It woul stick if I mooutned it sideways, I had to mount it with adjuster pointign stright up to wrok right. Boost would change +- 4 pis depedning on weather. 4. Boost DSBC, old one, worked perfect just wish didpsly was in PSI. 5. Greeddy, I just never liked it, it was hard to use compared to the Blitz
See this thread to buy remote IAC mounting block:
http://www.3si.org/forum/f4/f-s-remo...bodies-416611/ 1992 Stealth TT ![]() For sale 3.5L 6g74 Swap modified oil pans and thermostat hosuings http://www.3si.org/forum/f4/fs-6g74-...ied-3s-420690/ |
#16 (permalink) |
og
i have noticed many boost controllers fluctuate as temperature and humidity change, including my greddy profec b spec 1. i didn't note this as a con since just about everyone i have spoken to have had this issue. does anyone not have this happen?
93 stealth r/t tt: mildly modified, 12.4@109
94 stealth r/t na: used to drive, 13.9@100 03 ford focus se: beater |
