Update (6/13/2008)
In this update I will TRY to give you a full list of my parts and an explanation of anything I feel may need some clarification. Let's start off with my choice of Turbo.
After doing a bunch of research on TheTurboForums.com, I made a choice to go with a Master Power T70 turbo with a .68A/R T4 turbine housing with P-trim turbine wheel. Master Power is a company out of Brazil and have been making high-quality turbos since the early 1970's IIRC. I guess that they, as a company, like to do things a bit differently because my MP T70 isn't really a T70, infact it is something quite different.
A few of the members on TheTurboForums.com got together and made some measurements of all the Master Power turbos. They made a excel spreadsheet detailing their findings. My turbo has a P-Trim turbine wheel just as described but the Compressor wheel is what is totally different than that of a regular T70. Here's a little comparison for you:
Regular T70 Compressor Wheel(Garrett Precision):
70mm Inducer, 88.9mm Exducer. 62Trim wheel
Master Power T70 Compressor Wheel:
69.1mm Inducer, 97.8mm Exducer. 50 Trim wheel
and for comparison's sake
Garrett GT4294 Compressor Wheel:
70.3mm Inducer, 94.0mm Exducer. 56 Trim Wheel
So yea it is clear that the Master Power T70 eclipses a regular T70 but what was amazing to me was that while a GT4294 had 1.2mm more than the Master Power T70 on the Inducer side, the MPT70 has 3.8mm on the Exducer side over the GT4294. So hey.....I guess it looks like I made a good choice for my turbo haha.
*Other than that, I am getting my heads ported and polished. Basically trying to copy the design of the DR Stage 3 Heads. The uppers and lower intake manifolds will be gasket and port matched accordingly.* (I've opted not to go though with this but just to clean them up due to time constraints.)
Here's a list of supporting mod parts (atleast the ones I can remember):
-Custom Driver's side Intake Manifold with Infiniti Q45 90mm Throttle Body
-P.T.E 680cc Injectors (~64.7lbs for those of you not using the Metric system)
-AEM Adjustable FPR
-Hotwired Walbro 255lph in tank
-Tial 38mm Wastegate with 9psi spring
-Tial 50mm BOV
-Wiseco forged 8.3:1 92mm Pistons
-New Forged Crank and with forged rods
-Custom 3.5" DP mated to 4" Single Shot Exhaust
-FMIC 24x12x3(Core, 31x12x3 End tank to End Tank) with 3" Piping all the way (Cold and Hot side)
-MAFT Pro tuning unit with 3.5Bar MAP sensor and timing control
-Stock Twin Turbo ECU
-SPEC Stage 2 Clutch (Rated at 498ft-lbs)
-Resurfaced stock TT Flywheel
-Fwd Converted 5 speed Getrag
-AEM EUGO WideBand
-Datalogger
-Manual Boost Controller
-All Relavant gauges
-All the turbo related parts from my previous TT build
-Custom Single turbo manifolds using the runners from ebay "DN Style" TDO4 manifolds mated to 2.5" pipe and coupled with 2 VBand Clamps.
I'm sure there is alot more that I am forgetting to list because I always forget to post alot haha. I should have lots of pics shortly or maybe my boy KYLE@PCM will help me out by posting some (*hint*hint*)
As far as power goals are concerned, I am looking for 500-550fwhp on pump gas as easily as possible (running the least amount of boost). It shouldn't be too hard because all I will need is about 375ft-lbs of tq out at 7300rpms. Let me know what you guys think.
