#32 (permalink) |
Little Mauve secret
I have tried unplugging the ECS already....but it didn't make a difference....or didn't appear too. I only left it unplugged for a little while though. Unplugged it....and went for a drive. Noticed it didn't change anything....so the next day I plugged it back in. I found some documentation on calibrating the TPS to make sure its getting the proper amount of volts....so I am going to hopefully try get that done today.....
1994 Dodge Steath RT/TT "Mya"K&N Filter, MBC @ 15psi ATR DP, ATR Exhaust Autometer Boost, Autometer Air/Fuel Cusco Rear Strut, RPS Max Street Blitz Turbo Timer NGK Copper Plugs Magnecor 8.5, Kumho Ecsta 255/40/17 Eneki RP02 17x9 GTPRO Y-Pipe Hawk HPS Pads |
#34 (permalink) |
Waterfall chairman
I don't know if it's been mentioned but I'd start with a pressure test. It sounds like you have a fairly large boost leak somewhere. Check your vacuum hoses, very likely that one got disconnected.
![]() Doctors say alcohol is your enemy, God says love your enemy ![]() |
#36 (permalink) |
Little Mauve secret
What else besides ECS which I have unplugged and nothing seemed to change could cause the 5V supply to be messed up to the TPS? Is there away to test the TPS to see if its not fubarred?? I have read some where people have unplugged their TPS and other who have unplugged their MAS to see if the problems went away.....would it be worth my while to try either of these?? Just looking at any/all options.
Pressure testing will have to wait a little bit until I get my tester..... |
#37 (permalink) |
One Sinister Motha Sucka!
i have the same problem. No matter what boost settings its at, it wont go over 6psi and it stutters. I changed out the plugs, NGK vpower 1 stage colder and same thing. Its at the shop so we'll see what is going on
Still Waiting for her to get on the road!! $$$ and counting!!!!
#38 (permalink) | |
Little Mauve secret
Hopefully it gets nice in the next day or so, still raining right now so I can go out and attempt to fix this very annoying problem. Good luck with finding out what is wrong with your car....keep me posted on the results! |
#39 (permalink) | |
My PVC valve arrived so I gotta go and grab it from the dealer today and try it out tomorrow. But I got a feeling something else is responsible. Will post results when I do find. |
#40 (permalink) | |
Little Mauve secret
I liked it when I just installed my upgrades, turned the boost to 15psi....and had fun. Here is something else I don't think I mentioned when thinking about when this started to happen. I had recently....well last year, had my clutch replaced(dealership)....and due to the break in period....never boosted hard. Then when the clutch was finally broken in, it was time to put the car away for winter. So I never ever truly got a change to put her through the paces after the clutch install. There was absolutely no problems with boost prior to the clutch going out. Can't believe I almost forgot the new clutch install..... Need to get a pressure tester.....to make sure its not a big leak..... |
