Old 08-05-2008, 10:04 AM   #11 (permalink)
simace's Avatar
simace Level 1simace Level 1
Default Re: Problems with boosting and stuttering
I have the exact same problem and never really did anything - as I thought I was overboosting, hitting ~14.7.
I'm going to do some work now. One thing that I've noticed on my car; if I go from whatever throttle to WOT, I'll get that bad studdering as soon as boost climbs past 8psi. If I slowly press the throttle down until it's WOT (kind of matching the peddle with the RPMs), I won't get the studdering and the car pulls very strong (boost will be around 14.x).
Anyhow, time for me to get to work.....thanks for this thread....it is definately an eye opener for me...
K&N Intake * Greddy FMIC * 2.5" DP (No PreCats) * 3" Exh * Walbro 255 * AEM TruBoost * AEM EUGO * Prosport FP * SAFC-II
simace is offline   Reply With Quote
Old 08-05-2008, 10:18 AM   #12 (permalink)
Little Mauve secret
Mad Dog Bodine's Avatar
Mad Dog Bodine is an unknown quantity at this point
Well I am happy to hear I definitely am not the only one with this problem LOL.
My car though at any throttle, wide open or partial, if I get into boost and it passes 6psi (WG pressure) it stutters. For example, on my way home yesterday from out of town, with cruise on, and going up a hill, boost climbs, hits 6psi, and then stutters and shakes. The boost still tries to go to 10, but it doesn't pull like it should from 6-10psi.
I got some work cut out for me this week....good luck with your car!
MDB
1994 Dodge Steath RT/TT "Mya"
K&N Filter, MBC @ 15psi
ATR DP, ATR Exhaust
Autometer Boost, Autometer Air/Fuel
Cusco Rear Strut, RPS Max Street Blitz Turbo Timer NGK Copper Plugs
Magnecor 8.5, Kumho Ecsta 255/40/17
Eneki RP02 17x9 GTPRO Y-Pipe
Hawk HPS Pads
Mad Dog Bodine is offline   Reply With Quote
Old 08-05-2008, 12:10 PM   #13 (permalink)
Little Mauve secret
Here is a copy of a recent log I did. Excuse the size and amount of data.....not quite sure how to edit it except manually which will take forever......
Old 08-05-2008, 12:51 PM   #14 (permalink)
BlackStealth's Avatar
Drives: 93 RT/TT
Trader Rating: (162)
BlackStealth Level 7BlackStealth Level 7BlackStealth Level 7BlackStealth Level 7BlackStealth Level 7BlackStealth Level 7BlackStealth Level 7
Next time include the HHH datalog, some of us prefer that.
Anyhow, not surprisingly is your o2 numbers are indicating lean during WOT; this is expected if the engine is not igniting the fuel.
BlackStealth is offline   Reply With Quote
Old 08-05-2008, 01:16 PM   #15 (permalink)
Little Mauve secret
Alright....so I am running lean WOT....but now is this caused by the fuel filter not flowing enough....or my ignition not igniting the fuel? I am ordering a Fuel filter but I won't get it probably until next week
Should I look at gapping down the plugs?? Could this be spark blow out??
MDB
PS.
What did you mean by the HHH datalog, like the actually file I logged itself?? And not a CSV file??
Old 08-05-2008, 02:00 PM   #16 (permalink)
Drives: 93 RT/TT
When there's a misfire it will show up artificially as lean, so no surprise here since that's what you're feeling. I don't believe it's a fuel problem.
Stock gap was good for about 14psi, but I've regapped them to .028. I don't think it's spark plug blow out at this low boost, assuming the plugs are good.
I have HHH, so yes the normal HHH datalog would be fine.
Old 08-05-2008, 02:17 PM   #17 (permalink)
Little Mauve secret
Well here is the log file I did on Sunday......I am very confused....this is the first real bit of "tuning" I have done. Never had a problem until recently.
Thanks for all the help and suggestions.....
Old 08-05-2008, 02:37 PM   #18 (permalink)
Pow! Slam! Bam! Baff!
Patch's Avatar
Drives: 2 tons of fun
Patch Level 3Patch Level 3Patch Level 3Patch Level 3
I'm having a similar problem Mad Dog Bodine.. except I can boost until around 10psi then the mambo begins... I'm starting with EVO bov and new plugs. Keep us posted!
Patch is offline   Reply With Quote
Old 08-05-2008, 02:50 PM   #19 (permalink)
Little Mauve secret
Yeah I won't be able to do much until the Filter and Caps arrive. Can't get them in town anywhere. So I have to order them. Going to check my plugs and wires this upcoming weekend as well....just don't have time during the day to do it.....
PS.
Your sig pic is hilarious....LOL
MDB
Old 08-05-2008, 04:15 PM   #20 (permalink)
Drives: 93 RT/TT
That HHH session file makes it much easier to read and visualize now. Your o2 sensors are cycling like normal and then suddenly hits zero during WOT. It's a little difficult to pinpoint what's going on as your throttle is not steady during those runs.
It's gonna take a week to get my PCV order to come in...not certain if that will cure my problem.
