#1 (permalink) |
Little Mauve secret
Hey everyone,
I have had this problem come up recently, where my car will not make any boost past 6psi without stuttering and hesitating. I step on it in any gear, and once positive boost starts to hit, after 5-6psi, the car stutters, you can hear it from the exhaust, and it kinda feels like its hesitating. It never goes away in the higher RPM, it just continuously stutters. I can't really get over 4500RPM cause I don't want to keep my car stuttering too long. Everything else about the car is fine, idle, normal driving, light acceleration. Just when I pedal to the metal it, she won't boost. Here are a couple of the things I have already checked....I have checked my MBC, to see if that was the culprit, doesn't appear to be, cause I have pulled the line off the back of the y-pipe and it still did the same thing. Even though I have a crappy RFL, it doesn't appear to be leaking. I have tried disconnecting the ECS computer....nothing. Things I haven't done, pressure tested (need to get an adapter), I haven't checked the Caps on the ECU, I will be in the next day. I haven't changed my fuel filter(cause its probably due). My plug wires are about 7 yrs old, plugs were installed at the beginning of last summer gapped to .32. I don't believe its spark blow out.....but I guess I could be wrong. I have logged a bit with my Hybrid HHH logger, but when I export into a CSV file, all I get is a mess of data that isn't well layed out. Anyone know how to organize it properly so I can post it? The file right now is just a mess....lol so I hope I don't have to manually organize it..... Anyways....thanks for your time. MDB
1994 Dodge Steath RT/TT "Mya"K&N Filter, MBC @ 15psi ATR DP, ATR Exhaust Autometer Boost, Autometer Air/Fuel Cusco Rear Strut, RPS Max Street Blitz Turbo Timer NGK Copper Plugs Magnecor 8.5, Kumho Ecsta 255/40/17 Eneki RP02 17x9 GTPRO Y-Pipe Hawk HPS Pads |
#2 (permalink) |
My car has developed the exact same problem and I'm about to install new plugs and ignition wires today in attempt to cure the problem. However, I think the fuel filter is probably the real culprit now that you mention it.
#3 (permalink) | |
Little Mauve secret
MDB |
#5 (permalink) |
I just installed new NGK OEM platinum plugs, NGK ignition wires and fuel filter and the problem is still there.
I guess I'll keep my MSD ignition wires since there's not much mileage on them.I'm borrowing a brand new boost controller solenoid from a buddy for my Greddy Profec, so I'm pretty sure it's not boost controller related. I changed my ECU caps a few years back, I estimate about 30,000-40,000 KM's ago. For good measure I used better quality capacitors (105C) over the stock 85C. There was no leakage when I changed them then, and last year's ECU capacitor inspection was good too. My oil cap is leaking so naturally I inspected my PCV valve and it appears to be working so I purchased a new mitsu oil cap instead. Well my new oil cap is leaking now so I'm gonna go ahead and order a new PCV valve (MD153242). I hope a new PCV valve fixes the problem! |
#6 (permalink) |
Supporting Vendor
Did you get the Oil cap from the Factory? or a parts house? I used a parts house one and it leaked right out of the box..
Jason
Jason@PriceMatchedParts.com 3000GT/Stealth Performance parts! www.PriceMatchedParts.com PMP on Facebook!! PMP on Myspace!! PMP on Twitter.com too!! PMP on Digg check out PMP CCOTM! 91 vr4- Budget build! stay tuned! 1 of 3 in the US |
#8 (permalink) | |
Little Mauve secret
Its weird cause boost comes on strong and the car starts to pull, until it passes about 6psi....then it just stutters and boost climbs to 10 where I eventually get off the gas, but its not pulling hard like it should. I don't stay on it hard for fear that I am doing some damage when its stuttering....it also sounds like the exhaust is "popping" when its stutters. Very strange.... |
#10 (permalink) |
Little Mauve secret
Hmmmm didn't even think of the coils......well I got some other things I need to try/replace first.....then coils will be my next "guess"
at what could be wrong with it. These car's aren't very fun at only 6psi.... . |
