#41 (permalink) |
I compared my old PCV valve with the new and noticed the springs are stretched in the old valve. Replacing the PCV valve will fix a minor boost leak and oil cap leak, but this didn't fix the big problem I'm trying to solve.
Tomorrow I'm gonna do pressure test again. |
#42 (permalink) | |
Little Mauve secret
The rain has finally stopped here, and its supposed to get hot....31C on Saturday....so hopefully I can check some more things out...... MDB
1994 Dodge Steath RT/TT "Mya"K&N Filter, MBC @ 15psi ATR DP, ATR Exhaust Autometer Boost, Autometer Air/Fuel Cusco Rear Strut, RPS Max Street Blitz Turbo Timer NGK Copper Plugs Magnecor 8.5, Kumho Ecsta 255/40/17 Eneki RP02 17x9 GTPRO Y-Pipe Hawk HPS Pads |
#43 (permalink) |
Pressure testing results: Major leak found, passenger side intercooler clamp somehow got loose and moved the rubber pipe about 1.5" from normal position.
It's too dark to complete my task, but tomorrow I'll test drive the car again with the fix ![]() |
#44 (permalink) |
It's fixed and drives 100% smoothly now, and is incredible fast with all that boost.
![]() FYI, I did try to use a 2 gallon compressor earlier but the air pressure would be gone in seconds -- not enough time for me to locate the leak. Purchased a 19 gallon compressor and it gave me ample time to locate this massive leak. ![]() |
#45 (permalink) | |
Little Mauve secret
Its stopped raining yesterday, so I will be able to do some work on it this weekend. Congrats once again for getting her fixed up! MDB |
#46 (permalink) |
The dealership may have disconnected the passenger side intercooler hoses when they serviced the transmission and probably didn't tight it up enough. Fortunately it's not too difficult to fix, just remove some plastic shielding out of the way, jack the car up a bit, and you should be able to reach both.
#47 (permalink) |
FWIW, I found out my problem. Old spark plugs. I hadn't changed them for about 6 months.
Changed them (used stock plugs) with a gap of .32 and no more studdering. Car moves well. One thing tho that remains for me is the slow to accellerate problem. Anyone familiar with this demon? Eddie
![]() K&N Intake * Greddy FMIC * 2.5" DP (No PreCats) * 3" Exh * Walbro 255 * AEM TruBoost * AEM EUGO * Prosport FP * SAFC-II |
#48 (permalink) |
I'm having similar issues, plugs, with varying gap, doesn't fix my problem. My fuel pump ended up going out on me, and didn't change anything when i replaced it. I'll re-do a boost leak test and check a few other things, knock sensor is suspect for mine, reading a little high when i get the miss.
#49 (permalink) |
Little Mauve secret
I have pressure tested to 20lbs, and there are no apparent leaks. I have re-gapped my NGK Coppers down to .030, no change. The plugs are almost over a year old, but have less than 10,000KM (6,000M) on them. Maybe that is it, but if this is the case I am going back to platnums, cause I don't mind replace plugs every two or three years, but every year is a bit silly. And I had plats in before I ran th coppers....and had zero problems.
I will be replacing them next year after I get the car back on the road from her upcoming winter sleep. I have a new fuel filter I haven't replaced yet, hoping to do that. I will also over the winter be buying a Supra pump with hotwire, since I will need the extra fuel soon. When I log I get absoutely no knock, but when I hit boost and start to accel, my O2 voltages read dead lean. Like I am talking .05 etc. I can run WG boost fine, no stuttering it pulls strong. Just absolutely anything over WG and it stutters and hesitates. MDB |
