Old 05-08-2008, 04:17 PM   #11 (permalink)
220K club
mehlosTT's Avatar
Drives: AWD or nothing.
Trader Rating: (8)
mehlosTT is an unknown quantity at this point
Default Re: problem with brakes
When bleeding the brakes on the antilock system, a good idea is to place a 2x4 under the brake pedal so you don't hyper extend the rod into the Master brake cylinder. The manual says to do with the engine running because? maybe to ensure the antilock vlaves are functioning? who knows_ I have done the brakes 9 times now and only once did I have the car running when I bled them. Then again, when I power flushed them, the tons of silvery aluminum? mix that came out of the MBCylinder was visible.
'92 R/T TT 236 K mileage club
AEM EMS,
Twin TD-O5 MHI EVO 16G,
Electronics:
AEM ems, FJO dual WBO2, GaugeTech AEM ems display, custom made EL type main gauge faces,
[/size]
mehlosTT is offline   Reply With Quote
