#1 (permalink) |
My brakes have way too much play and almost no stopping power. I have a '94 SL. At higher speeds, I have to push the brakes almost all the way in. At lower speeds (1st, bottom end 2nd gear) I get some more feedback from the brakes but they still don't brake as much as they should.
My brake light came on (not the anti lock light) when I first noticed this problem. It only came on during 1st and 2nd gear, even though braking power was noticeably less at all speeds/gears. Fluid level looked a little low, so I went out and bought some DOT3 brake fluid and put some in there. I only had to put in a tiny amount though, the bladder that is attached to the cap is pretty damn big and made some of the brake fluid I added spill out. Also, I noticed that whereas the new brake fluid I added was clear, the fluid already in there looked pretty dark. Afterwards, I drove around the block to test the brakes. The brake light did not turn on during 1st or 2nd gear, but braking power was still about as weak as before, maybe a little better. I looked at my brake pads (front and rear), they look OK I think. I don't know what brand they are, the previous owner installed them. No squeaking when braking. Oh, and like a few days before the light came on, I went out and drove around some back roads pretty hard. I don't drive too hard on a daily basis (usually shift at 3-3.5k), but I do brake late/hard. Anyone have an idea what the problem might be? I'm guessing (from my nonexistent knowledge base) that I need to flush the old fluid. |
#2 (permalink) |
3SX FTL
Change your brake fluid and bleed your brakes, then see how they feel. If they still give you trouble, get back to us.
Sounds to me like you've just got a bunch of air in the system, and old nasty fluid. Clint
The Pansy Patrol
1995 3000GT VR-4 but real niggaz don't give a fuck: V1, comprehensive denastificizzle, vishizzous accessory biznelt mod, K&N, Greddy Profec B S-P-to-tha-izzec II, S-AFC, Walbro 341, DSM 450s, n AEM UEGO; battery relocizzle K-R-to-tha-izzank Vents, EK2MFG fizzle rizzle loop n plenum spaca, lethal_vr4 manual gang bangin' rizzay, SKVR4 AWS delete, polyurethane motor mounts, adjustable control arms, SS brakes lines, n EGR blockoffs; Custom brakes lines wit cockpit-mounted adjustable proportion'n valve, 332mm Stoptechs, Carbotech Brotha Plus/Porterfield Rizzle ATE Pusha Blue, OZ Gang Bangin' F1 Plus 17x9.5 +36mm, Yokohama AVS ES100 275/40/17, Tein Fizzle w/EDFC n SCE Casta/Camba Plates, SCE oilpan, DSM sidemounts, DN Precat Eliminizzles 13G/9B combo (9psi springs), J-spec final drive, RPS flyhweel n Spec II clutch, IPO propane, ATR downpipe, tizzest pipe, n Single Shot1994 Mazda Protege DX: 253K miles, DOHC 1.8L swap, rear disc brake conversion, poorly-designed header, some cheap-ass suspension upgrades, Carbotech Panther Plus, Miata wheels, other crap here and there, arguably the fastest piece of shit in New England and no one can do anything about it ![]() |
#3 (permalink) |
July 2003
Yes, the first thing to try would be to do a proper full flush of the brake fluid. Seems like it hasn't been changed in quite a while and for all you know, you might have entrained air bubbles in the system. That's the most liely reason for the pedal going practically to the floor.
Max
1994 3000GT VR-4. Hobbies... what are hobbies? Oh, those things people do when they're NOT working on their cars?
#4 (permalink) |
That "Bladder" shouldnt make any spill out as it should be colapsed up into the cap. You need to push it back up in the cap then refill you fluid. You probably have sucked a big gulp of air into the system so fully bleed everyting and see if that makes a difference.
![]() 1993 VR4 Exactly Identical 169 Mechanically Identical 895 Same Model+Option Package 940 Same Model+Build Date 140 #916 |
#5 (permalink) |
So I bled the brakes, got rid of the air bubbles and the brake warning light. Brakes work a lot better now. Unfortunately, since it was my first time jacking up my car on all fours, it took a while and I didn't get to do a full brake fluid flush before it got dark. That's next on my list though, as soon as my test pipe comes in I'll install that and flush. Thanks for the help guys.
#7 (permalink) | |
3SX FTL
If you use a colored brake fluid like ATE, it's fairly easy to tell when you've forced all the old fluid out. But if you're just usuing regular fluid, you have to just go overboard with it. Clint |
#8 (permalink) |
Here's a good thread, details a full brake fluid flush and bleed:
http://www.3si.org/forum/f13/how-bleed-brakes-153864/ |
#9 (permalink) | ||
July 2003
Here's a simple and fairly cheap way to do it on your own: Quote:
If you don't have or don't want to get Speedbleeders, then ask someone to give you a hand. Simply follow the procedure above except without the SB's, you have your assistant stand on the brake pedal and then you open the bleeder valve to allow fluid to spurt out (use some tubing over the bleeder nipple to some kind of container. Brake fluid is corrosive and toxic even from skin contact). With them still standing on the brakes, close the bleeder valve. Then tell them to allow the pedal to rise again and stand on the pedal again then repeat. The advantage to bleeding brakes under pressure like this is that a) it prevents air from getting into the brake system. b) the higher velocity of the brake fluid going through the lines is more effective for removing small air bubbles. It's also a good idea to use a rubber mallet to tap the calipers every once in a while as you bleed the brakes to get any bubbles to move. Max |
