#32 (permalink) |
ok so i just fixed the "cant rev pass 5000", i had to replace my filter, wierd but yes it worked. just did the hose reduction, egr block-off plated, MBC, boost guage, an pre intakes. i havent brought it out for a run because im waiting for my battery to be charged from autozone. im also trying to find a 4 guage wire to move my battery to the trunk.
#35 (permalink) |
hey i just installed a MBC with an aftermarket boost gauge an im only boostin at 5psi, atleast thats what the boost gauge was saying, iono if i am boostin at 5psi but it surely isnt fast, i tried turnin up the boost but it never seems to go up an i dont feel a different
#36 (permalink) |
ok so i did another pressure test, i left the tank running on 10 psi, i went into the car to see what psi it was on an it read 4-5 psi, while looking at the gauge i heard a air leak from my pedals. went under an found that the bushing for my clutch pedal was leaking pretty bad, i stepped on the house with the gauge in my hand an as i stepped on it the boost dropped to like 2-3 psi, im like oh shit thats where the leak was. i was wondering if theres a replacement for the bushing? i might just get a whole new pedal from ebay with bushings. hopefully my car will run better when the leak is fixed, i do have a leak with the pcv hose an the hose that connects to the plenum with the arrow pointing towards the engine.
#38 (permalink) |
needs boost
have you checked your timing belt to make sure it lines up on all 4 cams and the crank?
Slipped timing can be a cause for the car to not rev all the way to redline.
1 of 2 WA members at NG06!!!!!
2nd place stock AWD autox(not my car; first time driving a TT) 91 R/T Mods: SCE 5mm spacers, intrax, rear sway bar, rear camber/toe arms, tp, intake, 18x9.5" fn01rc's in hyperblack with 265/35 Yokohama AVS sports, 2gTT brakes, SS lines, ek2 spacer and goodies, poly motor mouts, Seattle roller-bearing shifter!, Accel wires,'99 lifters, custom stereo, yellowtop, 192K+ miles, m505 w/MMCd, 3500lbs w/driver, and a badass daily driver! Need to install: ss clutch line, 2g rear brakes, BT ground wires. Need: CASH, windshield, carpet, antenna, 5 point strut bar New DD- 91 base stealth- 90k miles, blue, vr4 wheels. NEEDS LOWERED! Getting r/t body coversion and painted... |
