#1 (permalink) |
last night i raced a sti an, i didnt win. car wouldnt accelerate past 5500, today i was thinkin maybe theres a leak so i ran another pressure test an found 2 leaks, one on the intake for the front turbo an the other from the coupler on the throttle body. i tightened it test it again, found one really small leak an the front pcv hose. after i had put everything back together an started the car an i revved it, it looked a lot better than before, better throttle response but i couldnt rev past 5000 without hearing a huge air leak or something. the thing is that i was parked when i did this an the boost gauge said i was hitting 14psi(stock gauge), it shouldnt be hitting that, so i took it for a ride an i can barely accelerate. i thought maybe my bov is messed up so i took it apart again an still no air leak. im running out of ideas, ill try to get a video up tonight or something of how its reacting. please someone help me thanks
ps. that sti got lucky i had to short shift all the way haha i beat it on the launch easily. 3rd gear killed me though oh well another day |
#2 (permalink) |
H to the izzO
1) Don't use the stock guage. Its worthless.
2) How much boost are you trying to run? 3) How many miles are on the plugs and wires? How much gap? 4) Stock BOV? Its possible your BOV isn't holding boost. 5) Do you have a logger to watch knock? The engine might be pulling timing. When you say your car won't accelerate past 5,500 rpm, do you mean that th engine continues to rev smoothly but you start losing power? Or does the engine just start stuttering after 5,500 rpm?
#5 (permalink) |
i just fixed it an its still the same, it revs an stops at 5500 somewhere around there. i have a video but itll be up tomorrow, it was shot by a camera from a phone though but oh well, itll be up tomorrow as long as he remembers to upload it
#6 (permalink) | |
H to the izzO
In that case, could you take a look at the following questions...
#7 (permalink) | |
3) they are new i just had a rebuilt on my motor (cost about 3500 with labor) 4) stock bov 5) no i do not have a logger to watch knock, i never really thought too much of it i think i should get one though, how much do one go for anyways? video will be up later today |
#9 (permalink) |
theres one thats closes to the firewall that has the arrow, it had a leak, i replaced it with a pcv hose an found out i couldnt do that so i put the old one back in (luckily i saved it) and i think i fixed the leak too, i took a look at the hose you were talkin about, was it the on that is from the right side of the plenum? if so it does have the arrow.
#10 (permalink) |
Forum user
Does fuel cut off at 5500 ? If so check to see that your waste gate hoses are run correctly.
Not to old to have fun - yet ??? -
2007 Dodge SRT-8 Superbee 2007 Hemi Quad Cab 4X4 2006 Harley V-Rod , 1999 S&S 1200 Sportster 2005 H/D FatBoy(Stage II),1973 BMW R75/5 restored 2004 Ducati Monster SR2,1972 BMW R75/5 restored 2004 Ford MACH I Mustang, Pro-Charger 535 RWHP 2002 Viper SRT-10,2000 Custom 883 Sportster 1992 Stealth RT TT (Stage III) 633.9 AWHP 1992 Stealth RT 1991 Stealth RT TT ![]() and More |
