Old 08-15-2008, 12:48 PM   #31 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (65)
Default Re: a problem after another
Yep, stock carrier bearings.
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts
Old 08-23-2008, 03:55 PM   #32 (permalink)
roneyyem's Avatar
roneyyem is an unknown quantity at this point
ok so i just fixed the "cant rev pass 5000", i had to replace my filter, wierd but yes it worked. just did the hose reduction, egr block-off plated, MBC, boost guage, an pre intakes. i havent brought it out for a run because im waiting for my battery to be charged from autozone. im also trying to find a 4 guage wire to move my battery to the trunk.
roneyyem is offline   Reply With Quote
Old 08-23-2008, 07:15 PM   #33 (permalink)
In Training
etecnifibre's Avatar
Drives: 99 3/4 Ton Silverado
Trader Rating: (64)
etecnifibre Level 7etecnifibre Level 7etecnifibre Level 7etecnifibre Level 7etecnifibre Level 7etecnifibre Level 7etecnifibre Level 7etecnifibre Level 7etecnifibre Level 7etecnifibre Level 7etecnifibre Level 7
You can get 4 gauge battery cable at AutoZone, but they are only 49". You can get wire by the foot on ebay.
etecnifibre is offline   Reply With Quote
Old 08-24-2008, 12:39 PM   #34 (permalink)
roneyyem's Avatar
uea i found a 2 gauge with 72" but still kinda short, i guess i gotta go ebay
Old 08-24-2008, 04:36 PM   #35 (permalink)
roneyyem's Avatar
hey i just installed a MBC with an aftermarket boost gauge an im only boostin at 5psi, atleast thats what the boost gauge was saying, iono if i am boostin at 5psi but it surely isnt fast, i tried turnin up the boost but it never seems to go up an i dont feel a different
Old 08-31-2008, 11:41 PM   #36 (permalink)
roneyyem's Avatar
ok so i did another pressure test, i left the tank running on 10 psi, i went into the car to see what psi it was on an it read 4-5 psi, while looking at the gauge i heard a air leak from my pedals. went under an found that the bushing for my clutch pedal was leaking pretty bad, i stepped on the house with the gauge in my hand an as i stepped on it the boost dropped to like 2-3 psi, im like oh shit thats where the leak was. i was wondering if theres a replacement for the bushing? i might just get a whole new pedal from ebay with bushings. hopefully my car will run better when the leak is fixed, i do have a leak with the pcv hose an the hose that connects to the plenum with the arrow pointing towards the engine.
Old 09-07-2008, 01:07 AM   #37 (permalink)
roneyyem's Avatar
i just got my hhh an is my rear 02 suppose to be reading 0.08v? because my front is reading 0.20-0.80
Old 09-07-2008, 03:30 AM   #38 (permalink)
needs boost
91Stealthrt2's Avatar
Trader Rating: (10)
91Stealthrt2 Level 291Stealthrt2 Level 291Stealthrt2 Level 2
have you checked your timing belt to make sure it lines up on all 4 cams and the crank?
Slipped timing can be a cause for the car to not rev all the way to redline.
1 of 2 WA members at NG06!!!!!
2nd place stock AWD autox(not my car; first time driving a TT)
91 R/T
Mods: SCE 5mm spacers, intrax, rear sway bar, rear camber/toe arms, tp, intake, 18x9.5" fn01rc's in hyperblack with 265/35 Yokohama AVS sports, 2gTT brakes, SS lines, ek2 spacer and goodies, poly motor mouts, Seattle roller-bearing shifter!, Accel wires,'99 lifters, custom stereo, yellowtop, 192K+ miles, m505 w/MMCd, 3500lbs w/driver, and a badass daily driver!
Need to install: ss clutch line, 2g rear brakes, BT ground wires.
Need: CASH, windshield, carpet, antenna, 5 point strut bar
New DD-
91 base stealth- 90k miles, blue, vr4 wheels.
NEEDS LOWERED! Getting r/t body coversion and painted...
91Stealthrt2 is offline   Reply With Quote
Old 09-08-2008, 05:26 PM   #39 (permalink)
roneyyem's Avatar
fixed the reving already, gonna check to see if my wires are getting power with my multimeter, now gonna have to invest in a air/fuel ratio
