Old 10-01-2008, 07:35 AM   #11 (permalink)
Kibwe Walker's Avatar
Drives: 93 RT/tt
Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7
Default Re: Porsche questions GT-R Ring claim...
Originally Posted by Drweldin View Post
I think by now it's pretty clear that Nissan has been
guilty of some shinanagins with the GT-R....the numbers
never added up...
I believe Car and Driver also accused Nissan of providing
"hot" test car(s)....basically suggesting the boost was
messed with.
Interesting article - thanks
Edit: And the Porsche spokesman was way too nice....lol
They had one GTR that didn't match the times of the other 4 they tested.
The response from neason was that the ECU was not the final version for production units. The most recent GTR they tested had the final ecu version in it and produced identical times to the 1st one they tested.
With a EFI car it is vary easy to make minor to massive changes in output just by changing stock timing, a/f ratios, and in a case of FI stock boost. C&D got a couple of GTR's on the dyno and IIRC they were hitting around 420 AWHP which I don't know how you would get from 480 crank hp through all the accessories and drivetrain that comes on that car.
The only thing Nissan is guilty of is lowballing the output numbers of the GTR. That car is pushing a good 5xx hp crank to be running those times in the 1/4 with those traps. Its nothing new, the terminator mustang was lowballed, Ford claimed 390/390 for them and they dyno 370-38x to the wheels, ford also low balled the ford GT, chevy lowballed the c6z06 I always believed that car to be closer to 550 hp than the 505 they were claimed at.
I don't mind lowball numbers, as the truth always comes out eventually. Its better than the alternative (overestimating output numbers). Look at all the rx8 owners scratching their heads about wheres my HP.
His - Red 93 RT/tt
Mods: Hallman's MBC @ 16 psi, turbo XS type H BOV, stillen dp, custom exhaust, Spec stage 2 clutch, RPS FW, 3sx lightweight crank pulley, BCP7RES-11 @ .030 gap, autometer gauges, slightly gutted mas, dsm SMIC's, ACPT 1 piece CFDS, Tein S springs, pte 580 inj's, safc neo/SITC, 13t's, hotwired walbro, maximal performance solid motor mounts, DR plenum spacer.
Hers - BPU Green 94 vr4
Kibwe Walker is offline   Reply With Quote
Old 10-01-2008, 08:08 AM   #12 (permalink)
Warning: I'm an asshole
SkortchGT's Avatar
Drives: 1992 3000GT VR4
Trader Rating: (10)
SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7
The GTR is an extremely impressive car, don't get me wrong, however the reported performance was always a bit questionable.
It's not the first time Nissan has produced questionable performance numbers.
1992 3000GT VR4
--Completely rebuilt 5/06-4/07. Everything new. For a list see: http://www.3si.org/forum/showthread.php?t=372579
--First time on dyno: 364AWHP@16psi with a 10.3AFR (now tuned at 11.4-11.6 with timing control, time for another dyno run soon)
--Mods: DR Stage I heads, 3rd gen lifters, TD04L 13Gs, DSM SMICs, PTE 550s, Apexi SAFC, Apexi SITC, Walbro FP, IPO hotwire, Robbeck adapter & AEM FPR, 3SX underhood fuel gauge, 3SX fuel rail loop, DN Y-pipe, HKS SSQ BOV, K&N FIPK, Greddy Profec Spec S, AEM WB02, Autometer C2 boost, egt, oil press & water temp gauges, MSD wires, NGK BCP7ES's, TEIN FLEX coilovers, Maximal performance control arms, solid engine mounts & powdercoating, RPS Streetmax Clutch, RPS Flywheel, NBT Tranny (cryotreated OS, shift forks & rails), updated speedo gear, solid shifter bushings, full 2nd gen brake conversion, 3SX SS brake & clutch lines, Carbotech Panther+ pads in the front & Bob Cats in the rear, 3SX clutch vac delete, EGR delete, vac reduction, Ebay DP, gutted pre cats, Bronze FN01RCs 5Zigen 18x8.5 + 30 offset, Pirelli P-Zeros, engine dress up kit, Bigtyla ground wire kit.
--Daily Driver: 98 Malibu, 4cyl, auto
SkortchGT is offline   Reply With Quote
Old 10-01-2008, 08:41 AM   #13 (permalink)
bane of unintelligence
inperfectdarkness's Avatar
Drives: dreaming of a TT ecu
Trader Rating: (13)
inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7
^ i.e. anytime something they built is compared to a 3/s.
inperfectdarkness is offline   Reply With Quote
Old 10-01-2008, 08:54 AM   #14 (permalink)
Regulator...
mikes2nd's Avatar
Trader Rating: (31)
mikes2nd Level 7mikes2nd Level 7mikes2nd Level 7mikes2nd Level 7mikes2nd Level 7mikes2nd Level 7mikes2nd Level 7mikes2nd Level 7mikes2nd Level 7mikes2nd Level 7mikes2nd Level 7
damn Datsuns!
Hijacking semi's with black Civics since 2001...
mikes2nd is offline   Reply With Quote
Old 10-01-2008, 10:03 AM   #15 (permalink)
3000GT MR's Avatar
Drives: with MR gears
Trader Rating: (6)
3000GT MR is an unknown quantity at this point
i personally think nissan hasn't been testing production cars. they were such in a hurry to beat porcshe they probably did all they could in order to do so..
94 VR4
99 conversion with 6K HIDs and PIAA fogs, 17G/15G combo, FMIC, DN downpipe, 560cc, walbro 255lph hotwired, MR gears, RPS 6-puck clutch, fidanza flywheel, hybrid logger, dejon preturbo, MAFT pro. K&N and custon carbon fiber heat sheild, HKS ssq, blitz turbo timer, 18" TSW kyalamis wraped in proxy 4's, polished Y-pipe, polished strut bar,solid engine mounts, seattle short throw, vac line reduction, misc REAL carbon fiber trim and misc gauges..ect
3000GT MR is offline   Reply With Quote
Old 10-01-2008, 10:11 AM   #16 (permalink)
Drives: An AEM car in -10F
Trader Rating: (9)
MustGoFaster Level 5MustGoFaster Level 5MustGoFaster Level 5MustGoFaster Level 5MustGoFaster Level 5MustGoFaster Level 5
Originally Posted by OBXboost View Post
I think the answer is simple.
Have the Nissan driver take the Porsche cars out and show up their driver.
Winner. There are too many variables to take into account. Maybe the chassis engineer didn't put enough faith in the electronic handling aids of the GTR?
P.S. never been a huge GTR fan, maybe they did cheat.
~Ryan
92 Stealth R/T TT- Not exactly done- 93 RT TT- Not much of a car anymore.
"This is a solution looking for a problem." - Not me
MustGoFaster is offline   Reply With Quote
Old 10-01-2008, 10:25 AM   #17 (permalink)
Вanned
i3igpete's Avatar
Drives: GoPigGo v2.0
Trader Rating: (80)
i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7
running a 7:30 in a street car (porsche or not) means you're pretty damn good.
HOLY COW I'M TOTALLY GOING SO FAST OH FUCK
give him the stick DONT GIVE HIM THE STICK.
i3igpete is offline   Reply With Quote
Old 10-01-2008, 10:40 AM   #18 (permalink)
The Mastermind
Brian GT PRO's Avatar
Trader Rating: (78)
Brian GT PRO Level 1Brian GT PRO Level 1
In my opinion, there are far too many *what if's*. It is my belief that there needs to be some sort of rules governing this testing, which includes a battery of tests to make sure that the actual car being tested is what is being given to the consumer, if not, it needs to be stated as to what was different, make things fair. This king of the hill game they are playing is very misleading.
WWW.GTPRO.COM
WWW.3000-GT.COM < COMING SOON!
Brian GT PRO is offline   Reply With Quote
Old 10-01-2008, 02:40 PM   #19 (permalink)
3KGTTusch's Avatar
Drives: Wishing
3KGTTusch Level 13KGTTusch Level 1
Damn straight, more so in recent years, manufacturers have been using ring times for publicity and show off their new cars. Well how the hell can anyone take them seriously, or for use in comparisons if there is not proof that is even the car you can buy. I think should be controlled just like anything else. No biased judges/testers etc.
3KGTTusch is offline   Reply With Quote
Old 10-01-2008, 02:45 PM   #20 (permalink)
Drives: 94 VR4
Trader Rating: (20)
Blue94VR4 is an unknown quantity at this point
Originally Posted by Ondontii View Post
By his own words, the GTR is 20 kilos heavier. How does 20 kilos = 20 seconds slower then the porsche?
That sorta screws up his reasoning.
It's not 20, it's more like 200kilos. It's a typo in the original article. Nissan GTR ~3830lbs, 911 TT ~ 3500lbs. Given the same "claimed" output of 480HP, how can GTR beat 911 TT? It does not make sense to me, at least on paper. It would be nice to see independent tests though. I trust nether Nissan nor Porsche in this case.
94 3000GT VR4 (upgraded)
"Your 1994 Mitsubishi 3000GT VR-4 is one of 1650. There are 57 other cars that were made with both the same interior and exterior color. Exactly Identical - 8"
For sale:
1. used A/C belt (10K on the belt)
2. Stock front and rear sway bars.
3. 3SX dual O2 simulator
4. Used 2'' couplers/reducers/hump hoses
5. SPEC II+ clutch
Blue94VR4 is offline   Reply With Quote
