Old 12-07-2007, 06:55 PM   #81 (permalink)
*Insert Evil Laughter*
Eric_VR-4's Avatar
Drives: 93 VR-4
Eric_VR-4 is an unknown quantity at this point
Default Re: Pics of full ABS delete: Custom lines and Wilwood prop valve in center console
Does anything happen to the ECS system when you do this? They are connected.
Also, it seems you could remove even more stuff if you take out the wheel speed sensors.
Eric_VR-4 is offline   Reply With Quote
Old 12-07-2007, 07:09 PM   #82 (permalink)
Racing
Barefoot's Avatar
Drives: 92R/T - converted ;)
Trader Rating: (31)
Barefoot Level 7Barefoot Level 7Barefoot Level 7Barefoot Level 7Barefoot Level 7Barefoot Level 7Barefoot Level 7Barefoot Level 7Barefoot Level 7Barefoot Level 7Barefoot Level 7
ESC still worked.. until I installed the K-sports
92 Dodge Stealth R/T AWD/TT (TD05) converted ( 11.894 @ 120.56 - 18 psi -> Video )
Barefoot is offline   Reply With Quote
Old 12-07-2007, 10:53 PM   #83 (permalink)
Eric_VR-4's Avatar
Drives: 93 VR-4
cool thanks
Old 02-06-2008, 04:32 PM   #84 (permalink)
3Sxtc is an unknown quantity at this point
Originally Posted by mike2 View Post
mike@whitbygas.com
is it like this - its the two off the master cylinder what confuses me .does it matter which one goes to the front and which goes to the rear
thanx mike
Struggly, if you were to re-do your brake line system, how would you do it now to account for the theoretical shortcomings?
3Sxtc is offline   Reply With Quote
Old 02-06-2008, 05:03 PM   #85 (permalink)
Hammer
Drives: 95 3000gt vr4 stock
Hammer Level 7Hammer Level 7Hammer Level 7Hammer Level 7Hammer Level 7Hammer Level 7Hammer Level 7
Originally Posted by 1500awhp View Post
From what I've read, the main purpose of ABS is to allow steering ability during emergency braking conditions and prevent "flat-spots" on tires. As far as braking distances are concerned, ABS actually increases them (in bad weather).
Someone correct me if im incorrect.
Kinda off-topic: So, the advantages of deleting ABS are better pedal feel, shorter stopping distances, less weight, better wieght distribution, and more room under the hood. While the disadvantages of doing this are little or no steering ability under very heavy braking, possible occurance of "flat-spots", and loss of confidance. Right? Did I leave anything out?
Thanks
Something that I have noticed that I do not like about ABS (whats to like?)
is the fact that once it activates it does not reset nearly fast enough to
avoid a serious problem. I caught air once (don't ask) and came back down
on a clean dry road surface with brakes locked up. The ABS kicked in
and what should have taken 15 feet to stop took 45+ feet with the ABS fighting the brake pedal all the way til the car stopped. Even after all the weight of the car settled on the wheels on a clean dry surface the ABS never
allowed full braking. There was no accident and no one was injured save the
ABS. No damage to the car or anything else. But I did learn the limits of the
lousy ABS.
Take note the ABS can cause problems braking even on clear dry days if you
get a wheel out of contact with the ground for some reason.
Hammer is offline   Reply With Quote
Old 02-28-2008, 10:53 AM   #86 (permalink)
SPEED FREAK
motomaniac06's Avatar
Drives: 94' vr4
motomaniac06 is an unknown quantity at this point
Can some one tell me, when doing the delete w/ the oem parts;
on the prop. valve .... where do the rear brake lines hook up to theres 6 ports and i have it figured out its either the top right and left or the 2nd from the top right and left? Could some one please tell me which one..... cause i know it makes a difference if you hook it up backward
motomaniac06 is offline   Reply With Quote
Old 03-24-2008, 08:00 PM   #87 (permalink)
phule's Avatar
Drives: 92 RT/TT
Trader Rating: (16)
phule is an unknown quantity at this point
Just picked up a used prop valve from the junk yard. im going to order up the factory lines and start this in the next week or so. also does anyone have a diagram for the lines. i was in a hurry and didnt document them.
phule is offline   Reply With Quote
Old 03-24-2008, 08:19 PM   #88 (permalink)
My92Stealth's Avatar
Drives: 91RT/TT,92Base
Trader Rating: (34)
My92Stealth Level 5My92Stealth Level 5My92Stealth Level 5My92Stealth Level 5My92Stealth Level 5My92Stealth Level 5
They should be very self explanatory.
1991 RT/TT Pearl White/Porn Red 15g's + supporting, other mods. 92 Stealth Base DD.
My92Stealth is online now   Reply With Quote
Old 03-25-2008, 06:29 AM   #89 (permalink)
phule's Avatar
Drives: 92 RT/TT
Trader Rating: (16)
Thats what i was hoping.
Old 03-25-2008, 07:55 AM   #90 (permalink)
NG '03 6th Floor Crew
lethal_vr4's Avatar
Drives: 92 VR4/ 01 Lightning
Trader Rating: (58)
lethal_vr4 Level 7lethal_vr4 Level 7lethal_vr4 Level 7lethal_vr4 Level 7lethal_vr4 Level 7lethal_vr4 Level 7lethal_vr4 Level 7
If I remember correct the factory lines are labled what said they went to....
Web log: http://apps.blackflagracing.com/Blog/
The Armada
'93 Sandstone Gray 3000GT VR-4
2006 3SI Ride of the Year
2007 All Mitsu Cookout, 1st Place 1st Gen 3/S
2008 All Mitsu Cookout, 1st Place 1st Gen 3/S
'92 Fiji Blue 3000GT VR-4
2004 All Mitsu Cookout, 1st Place 1st Gen 3/S
2005 NG Quick 8 AWD Unlimited 1/4 Mile Qualifier.
BLACK FLAG RACING
'92 Emerald Green Pearl Stealth RT/TT
3.5L, 15Gs, AEM EMS
For Sale
lethal_vr4 is offline   Reply With Quote
