Re: Pics of full ABS delete: Custom lines and Wilwood prop valve in center console
Originally Posted by JonsRT
Yeah. Here are all the parts you need from the dealer. Only thing else you need is a prop. valve from an ES model....Its the one with 6 ports on it instead of 4.
BTW the part number for the proportioning valves for us:
MB668915 is for the ABS models and
the non ABS models take a MB668841 $44.33
Sure would be nice if we had the brake bias numbers for both... for $44.33 I'm tempted to go with an adjustable proportioning valve.
The Armada '93 Sandstone Gray 3000GT VR-4
2006 3SI Ride of the Year
2007 All Mitsu Cookout, 1st Place 1st Gen 3/S
2008 All Mitsu Cookout, 1st Place 1st Gen 3/S
'92 Fiji Blue 3000GT VR-4
2004 All Mitsu Cookout, 1st Place 1st Gen 3/S
2005 NG Quick 8 AWD Unlimited 1/4 Mile Qualifier.
BLACK FLAG RACING
'92 Emerald Green Pearl Stealth RT/TT
3.5L, 15Gs, AEM EMS
For Sale
I recently track-tested this system and it works just fine. I had to use the proportioning valve to taper the rear bias down progressively, but the system was very effective.
The Pansy Patrol - a 3000GT/Stealth car blog with how-tos Pearl Yellow 1994 R/T TT w/84k - FOR SALE! new 4-Bolt factory short block, DR StgII heads, Titan TD05 headers, 14B turbos w/ ported 7cm^2 housings, 3" minimum-bend catless exhaust, SCE oil pan, RPSII clutch, Fidenza flywheel, OZ F1 Plus 17x9.5" wheels, Kumho Ecsta MX 245/45 tires, Drweldin DSM SMICs, 3SX engine mounts (Maximal solid front), GReddy 60mm P/H/W boost, Carbotech Panther Plus & Bobcat pads w/ slotted/drilled rotors, KSport GT-Pro coilovers, Maximal rear camber arms, SCE balljoints, ABS delete w/ cockpit-mounted Wilwood proportioning valve, AC delete, EGR/evap/dashpot delete, cruise/vacuum-tank delete, '95 Lexan headlights, McCulloch 4300K HIDs, GReddy Type-S BOV, solid shift bushings; Misc Parts: Walbro341, 20# fixed-back seats, Accelerated Moto catch can
Just curious, is this something that you continously adjust while your driving? Or just drive some, correct and then drive some more?
Adjust, drive for a while, adjust.
On the systems Chris and I have, we could certainly adjust it "on the fly". But for an analog prop valve, you're not going to be making corner-to-corner adjustments.
Clint
The Pansy Patrol 1995 3000GT VR-4 but real niggaz don't give a fuck: V1, comprehensive denastificizzle, vishizzous accessory biznelt mod, K&N, Greddy Profec B S-P-to-tha-izzec II, S-AFC, Walbro 341, DSM 450s, n AEM UEGO; battery relocizzle K-R-to-tha-izzank Vents, EK2MFG fizzle rizzle loop n plenum spaca, lethal_vr4 manual gang bangin' rizzay, SKVR4 AWS delete, polyurethane motor mounts, adjustable control arms, SS brakes lines, n EGR blockoffs; Custom brakes lines wit cockpit-mounted adjustable proportion'n valve, 332mm Stoptechs, Carbotech Brotha Plus/Porterfield Rizzle ATE Pusha Blue, OZ Gang Bangin' F1 Plus 17x9.5 +36mm, Yokohama AVS ES100 275/40/17, Tein Fizzle w/EDFC n SCE Casta/Camba Plates, SCE oilpan, DSM sidemounts, DN Precat Eliminizzles 13G/9B combo (9psi springs), J-spec final drive, RPS flyhweel n Spec II clutch, IPO propane, ATR downpipe, tizzest pipe, n Single Shot
1994 Mazda Protege DX: 260K miles, DOHC 1.8L swap, rear disc brake conversion, poorly-designed header, some cheap-ass suspension upgrades, Carbotech XP8/AX6, 15x7 +30 Kazera KZ-M w/ Avon Tech Ra slicks, other crap here and there (like an air filter that doesn't have 1/4 of a million miles), arguably the fastest piece of shit in New England and no one can do anything about it
Nice, I've been waiting on those pics for a while hah. Definately on the "to do" list, since my shit's just got the fuse pulled, and I absolutely hate all that clutter in the engine bay.
'94 RT/TT
13T's | PTE FMIC - PPE Pipes | 560's | Supra FP w/ 8ga Hotwire | MAF-T 1.37 & LT1 Blow-Through | E-Manage Blue w/ Boomslang Harness | HKS DLI | Stillen Downpipe | Gutted Rear Pre-cat | Borla Catback | Tial BOV | AEM FPR & Rob Beck Adapter | DejonTool Intake Pipes | PWR Radiator w/ IPS Pipes | FAL Fans | MP Motor Mounts | 99 Lash Adjusters | Clevite 77 Rod & Main Bearings | Leatherseats.com Dk. Graphite w/ Red Center Seats | Sparco Flash 5 Black w/ Red Alcantara | Spec Stg. 2 Clutch & 3SX Clutch Line | 3SX Crank Pulley | Bob's SS Shifter & All Solid Bushings | eK2 EGR Blockoffs, Fuel Line Loop, Injector & Harness Cover | PST 1 Pc. CFDS | Volk LE37T | Falken FK452 | Megan Racing Coilovers | Adj. Rear Control Arms | Slotted Rotors w/ Hawk HPS Pads | GReddy Profec B | AEM UEGO WB | GReddy PWH Boost, EGT, GReddy OP, FP, Temp | Hybrid Logger | McColluch 5300K HIDs | Shaved '99 Bumper & Turns | PRM Style Hood 295.7 AWHP / 310.3 TQ @ 1 Bar - BPU @ TX04
yeah, Ill end up doing it one day to reduce all the lines in the engine bay, this way is much cleaner looking
Just curious, if you could do it again.. $350 with an adjustable prop valve and non-stock brake lines vs $60 with a used prop valve and stock lines, which way would you do it?
I recently removed my ABS system, maybe 4 months ago? using all stock parts and a used es prop valve. Total cost was $60, took me an hour to install, I don't worry about leaking any brake fluid, and everything feels exactly the same.. granted I have been running without ABS properly functioning since I bought the car due to the datalogger not having a delay/switch.
I used the list of parts provided by JonsRT and did not do the rebuild kit.
Honestly? Neither.
What I would do--and what I still may do this coming spring or summer--is run new lines using 2 prop valves so that I can have a proper crossed pattern.
The one shortcoming of my system is that, in theory, the MC chamber may not be big enough to induce maximum braking in the fronts because of the volume. However, this has not proved an issue in actual testing on the track, likely because Mitsubishi factored in a significant safety margin to the MC.
That aside, your question is tough to answer. The stock prop valve an N/A lines are cheaper and easier, but doing my own was a fun project and good experience.
