Old 05-22-2006, 09:34 PM   #41 (permalink)
3SX FTL
Struggly's Avatar
Drives: Viciously
Struggly Level 1Struggly Level 1
Default Re: Pics of full ABS delete: Custom lines and Wilwood prop valve in center console
Originally Posted by TheOmniscientRT
Pics are on a server I don't control. Feel free to forward all complaints to username HenryC. It's his.
He's working on it though. The pics should work again soon.
Clint
The Pansy Patrol
1994 Mazda Protege DX: 260K miles, DOHC 1.8L swap, rear disc brake conversion, poorly-designed header, some cheap-ass suspension upgrades, Carbotech XP8/AX6, 15x7 +30 Kazera KZ-M w/ Avon Tech Ra slicks, other crap here and there (like an air filter that doesn't have 1/4 of a million miles), arguably the fastest piece of shit in New England and no one can do anything about it
Struggly is offline   Reply With Quote
Old 05-22-2006, 09:40 PM   #42 (permalink)
Native
Turbo Tension's Avatar
Drives: smokey/bandit
Trader Rating: (8)
Turbo Tension Level 1Turbo Tension Level 1
I think my ABS removal is easier
*yanks fuse*
1993 "dove gray metallic" Stealth R/T Turbo
For Sale! 6-speed transmission conversion, 2g front brake conversion, AWS delete with SK VR4 radius rod mod(BIG thanks to Joe G.'s website! )Kormex front LSD, Port matched Upper Intake -> Ported and port matched lower intake -> DR stage ]l[ heads, DR650Rs, ARC2 w/ 87mm MAF $ ARM1, Denso 255 hotwired, 720cc inj. fed by a Home made dual feed system for $800 w/ single hotwired intank pump, DR Weldin DSM sidemounts, DNP Y-pipe, 3SX poly motormounts, Vac hose reduction,, Chipped stock ECU -9000rpm rev limiter, Blitz DSBC in stock tape deck, VDO boost gauge, GREDDY EGT gauge, ATR downpipe - Borla catback w/ custom 3" flanges (3" all the way through), RPS flywheel, RPS clutch, Tein S-tech springs, Saner front and rear sway bars, Cusco adj. rear sway bar, 3SX adj. upper control arms, STEDEBANI front poly suspension bushings, 1995 VR4 front brake caliper conversion, Stillen Rotors,SCE extended wheel studs WELDED IN - THANKS SUPERCAR ENGINEERING! in NEW OEM hubs, Porterfield R4S pads, SILKOLENE brake fluid, Pro N1s w/ S03 Potenzas, 17x9 FNCRO1NFC01RN 5Zigens w/ NITTO 555Rs, POR15 on everything and a ton of new stock stuff For Sale...
Turbo Tension is offline   Reply With Quote
Old 05-22-2006, 10:33 PM   #43 (permalink)
Drives: 99 VR4
Trader Rating: (113)
SHiVeR-91VR4 Level 1SHiVeR-91VR4 Level 1
Yes, but I needed somewhere to put a 6" inlet
Plus I lost about 10lbs of shit.
SHiVeR-91VR4 is offline   Reply With Quote
Old 05-22-2006, 11:58 PM   #44 (permalink)
Drives: 97 VR-4
1500awhp is an unknown quantity at this point
Originally Posted by andyvr4
The sole purpose of ABS is to prevent a wheel from locking up, not to prevent flat-spots. On a street legal still tire your not going to flat spot it just by locking it up for a little bit. It takes a lot more than that. You also will still have steering under very heavy breaking without ABS you just half to make sure that you don't lock a tire. ABS can not make traction that isn't there you just half to be more careful and know the limits of the car a little better if your running it hard without ABS.
This is where I got that info from.
-Syed
1500awhp is offline   Reply With Quote
Old 05-23-2006, 12:07 AM   #45 (permalink)
3SX FTL
Struggly's Avatar
Drives: Viciously
Originally Posted by 1500awhp
And the information on that site is all very nice. But they forget to explain that only a douchedragon locks the wheels when braking.
It also doesn't discuss the improvements in and evolution of ABS systems. The 3/S ABS sucks: it intervenes no where near impending lockup, particularly in wet road conditions. Now, modern Porsche ABS, on the other hand, is as unintrusive as it gets. If we had ABS like that, I would probably keep it.
Clint
Old 05-23-2006, 12:51 PM   #46 (permalink)
Drives: 97 VR-4
Clint, thanks for clearing that up. I have one more question: From your experiance, what are the disadvantages of removing the ABS?
Old 05-23-2006, 02:23 PM   #47 (permalink)
3SX FTL
Struggly's Avatar
Drives: Viciously
In my opinion--remember that this is the opinion of someone who's been ripping shit out of his car for over 2 years--the only "disadvantage" is that you have to be more careful when braking. Since the sole function of the ABS is to prevent lockup, it conceals many of our braking mistakes: Slamming the pedal during panic stops, abrupt braking during rain, etc.
With the ABS gone, your leg is the only thing controlling wheel lockup. If that's not a responsibility you (and I mean the general you here) want, retain your ABS. It's fairly easy to learn the lockup threshold by doing some decelerations on highway off-ramps or on back roads. You want to feel comfortable applying the maximum pressure to the pedal without locking the wheels (this is threshold braking).
Clint
Old 05-23-2006, 05:08 PM   #48 (permalink)
Snakes on a Helicopter!
intruder1_92TT's Avatar
Drives: While Posting on 3si
Trader Rating: (8)
intruder1_92TT Level 1intruder1_92TT Level 1intruder1_92TT Level 1
To add to Struggly's post, once you've done a lot of "spirited" driving, you start to get a feel for that point just before the wheels lock up. It's not something that I can really describe, you just feel it; the feedback through the pedal and steering wheel, it's like you can feel just as the tires start to lose traction. Once you're at that point, then just let off the pressure a tiny, tiny bit, keeping it right at that threshold.
1992 Dodge Stealth RT/TT Pearl White and black /w blue pearl. Mods: Lightweight's MBC; K&N cone filter ; GReddy E-manage + all harnesses and press. snsr; DSM "Blacktop" 450's; Walbro 255; 1G DSM BOV (Recirculated); Polished Y Pipe; Slotted Rotors all around; Hawk HPS front pads and KVR CF rear pads; Enkei 18x8's with Nitto NT555 245/40's
intruder1_92TT is offline   Reply With Quote
Old 06-20-2006, 01:34 AM   #49 (permalink)
Oskar's Avatar
Drives: '96 R/T TT #57 of 57
Trader Rating: (33)
Oskar Level 3Oskar Level 3Oskar Level 3Oskar Level 3Oskar Level 3Oskar Level 3Oskar Level 3Oskar Level 3Oskar Level 3
I just happened upon this thread. Great info - thanks for posting!!
Oskar is offline   Reply With Quote
Old 06-20-2006, 02:22 AM   #50 (permalink)
Crap - you got me!
GTO Assassin's Avatar
Drives: 1993 Mitsubishi GTO
Trader Rating: (35)
GTO Assassin Level 1GTO Assassin Level 1
Clint
Hmmm, so having the ABS is kinda worthless as it doesn't do what it's suppose to when it's suppose to. But removing it requires caution as if you dont know your braking points, you may cause yourself a mischief? Is the ABS on the US models the same as the JDM ABS? My ABS actually saved me from rear ending someone. Tho a 4 wheeler then plowed into my rear. But I was happy for the ABS then. I have never circuit raced my car or had a long street race, so constant use of my brakes has not happened as of yet. Is this an 'all round' kind of mod for all seasons - wet/dry - dd/race?
Thanx for all the info
GTO Assassin is offline   Reply With Quote
