Old 05-20-2006, 12:06 PM   #31 (permalink)
The Smartest Idiot
Drives: a MONSTER
1500awhp is an unknown quantity at this point
Default Re: Pics of full ABS delete: Custom lines and Wilwood prop valve in center console
Originally Posted by Synchro
You won't be forced to slam into the car in front of you when you try to apply the brakes on wet pavement and the ABS kicks in - causing your brakes to fail.
The ABS system on these cars is terrible. It's nearly caused me to wreck three times.
Thanks for the pictoral Struggly!
From what I've read, the main purpose of ABS is to allow steering ability during emergency braking conditions and prevent "flat-spots" on tires. As far as braking distances are concerned, ABS actually increases them (in bad weather).
Someone correct me if im incorrect.
Kinda off-topic: So, the advantages of deleting ABS are better pedal feel, shorter stopping distances, less weight, better wieght distribution, and more room under the hood. While the disadvantages of doing this are little or no steering ability under very heavy braking, possible occurance of "flat-spots", and loss of confidance. Right? Did I leave anything out?
Thanks
1500awhp is offline   Reply With Quote
Old 05-20-2006, 01:09 PM   #32 (permalink)
BAWC: In the Mix
Monochrome's Avatar
Trader Rating: (28)
Monochrome Level 7Monochrome Level 7Monochrome Level 7Monochrome Level 7Monochrome Level 7Monochrome Level 7Monochrome Level 7Monochrome Level 7Monochrome Level 7Monochrome Level 7Monochrome Level 7
Originally Posted by AudibleSilence
Doesn't your datalogger disable the ABS anyway?
Not on a hybrid car. Shiver's cables can be left plugged in all the time without disabling the ABS.
05 MSM MX5 with 5K miles FOR SALE!
92 Green Stealth RT NA - 3.5L 4G64
94 Blue SL - coming soon
98 Black VR4: 100% stock - totalled by an Illegal 2-12-08
95 White Stealth TT: 11.852 @ 118.25 - sold
95 Green Stealth TT - Sold
95 SSG Stealth TT: 11.981 @ 115.81mph - sold
Nonstop Mixes by Monochrome
"I don't actually work on cars, I just talk about them on the internet."
Monochrome is offline   Reply With Quote
Old 05-21-2006, 10:32 PM   #33 (permalink)
3/S enthusiast
andyvr4's Avatar
Drives: 91 VR-4, 99 Zx2
andyvr4 Level 7andyvr4 Level 7andyvr4 Level 7andyvr4 Level 7andyvr4 Level 7andyvr4 Level 7andyvr4 Level 7
The sole purpose of ABS is to prevent a wheel from locking up, not to prevent flat-spots. On a street legal still tire your not going to flat spot it just by locking it up for a little bit. It takes a lot more than that. You also will still have steering under very heavy breaking without ABS you just half to make sure that you don't lock a tire. ABS can not make traction that isn't there you just half to be more careful and know the limits of the car a little better if your running it hard without ABS.
andyvr4 is online now   Reply With Quote
Old 05-21-2006, 10:55 PM   #34 (permalink)
vehicular thaumaturgist
Multiades's Avatar
Drives: 1994 Stealth TT
Multiades is an unknown quantity at this point
I beg to differ. You can flat-spot the shit out of a tire from locking it for a very short distance; I have done it, and I personally know no less than four other people who have also.
The Pansy Patrol - a 3000GT/Stealth car blog with how-tos
Pearl Yellow 1994 R/T TT w/84k - FOR SALE! new 4-Bolt factory short block, DR StgII heads, Titan TD05 headers, 14B turbos w/ ported 7cm^2 housings, 3" minimum-bend catless exhaust, SCE oil pan, RPSII clutch, Fidenza flywheel, OZ F1 Plus 17x9.5" wheels, Kumho Ecsta MX 245/45 tires, Drweldin DSM SMICs, 3SX engine mounts (Maximal solid front), GReddy 60mm P/H/W boost, Carbotech Panther Plus & Bobcat pads w/ slotted/drilled rotors, KSport GT-Pro coilovers, Maximal rear camber arms, SCE balljoints, ABS delete w/ cockpit-mounted Wilwood proportioning valve, AC delete, EGR/evap/dashpot delete, cruise/vacuum-tank delete, '95 Lexan headlights, McCulloch 4300K HIDs, GReddy Type-S BOV, solid shift bushings; Misc Parts: Walbro341, 20# fixed-back seats, Accelerated Moto catch can
Multiades is offline   Reply With Quote
Old 05-21-2006, 11:25 PM   #35 (permalink)
3/S enthusiast
andyvr4's Avatar
I've never seen that one street tires driven at close to the speed limit. I'm sure that on a track are at speeds much great then normal driving speeds it could be a problem, but I figure at normal speeds it wouldn't be much of an issue.
Old 05-22-2006, 12:17 AM   #36 (permalink)
Multiades's Avatar
Driving close to the speed limit is not something for which you require (a) threshold braking, (b) gummy rubber, and (c) adjustable brake proportioning.
Old 05-22-2006, 10:39 AM   #37 (permalink)
Drives: 99 VR4
Trader Rating: (88)
SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7
Just did mine this weekend, very easy install once you know what you're doing and get the hang of it.
Thought it was going to be a lot more difficult.
SHiVeR-91VR4 is offline   Reply With Quote
Old 05-22-2006, 06:04 PM   #38 (permalink)
TT's suck
TheOmniscientRT's Avatar
Drives: 94 Stealth Base
Trader Rating: (13)
TheOmniscientRT Level 3TheOmniscientRT Level 3TheOmniscientRT Level 3TheOmniscientRT Level 3
I flat spoted a s rated tire on my stealth(was on it when i bought it) in a parking lot going less than 30mph, any thing is possible
TheOmniscientRT is offline   Reply With Quote
Old 05-22-2006, 06:11 PM   #39 (permalink)
Brad5050's Avatar
Drives: 1994 3000GT VR-4
Trader Rating: (7)
Brad5050 is an unknown quantity at this point
pics not working
1994 VR-4
Brad5050 is offline   Reply With Quote
Old 05-22-2006, 06:13 PM   #40 (permalink)
TT's suck
Trader Rating: (13)
Originally Posted by Brad5050
pics not working
