Old 05-01-2006, 07:38 PM   #21 (permalink)
3SX FTL
Struggly's Avatar
Drives: Viciously
Struggly Level 1Struggly Level 1
Default Re: Pics of full ABS delete: Custom lines and Wilwood prop valve in center console
Originally Posted by pacman3000gt
Even with the abs system completely disabled via all the fuses?
I never did a direct comparison with my current car (it was down long enough beforehand that I hardly remembered stock pedal feel at all once I got it back together and put these brake lines in). But compared to what I remember of my first 3/S (a TT with disabled ABS) and what I've experienced driving stock 3/S's recently, my pedal is definitely better. I'm not quite sure how I would describe it except to say it's more direct.
And, of course, I imagine some of it is in my head.
Clint
The Pansy Patrol
1994 Mazda Protege DX: 260K miles, DOHC 1.8L swap, rear disc brake conversion, poorly-designed header, some cheap-ass suspension upgrades, Carbotech XP8/AX6, 15x7 +30 Kazera KZ-M w/ Avon Tech Ra slicks, other crap here and there (like an air filter that doesn't have 1/4 of a million miles), arguably the fastest piece of shit in New England and no one can do anything about it
Struggly is offline   Reply With Quote
Old 05-02-2006, 12:25 AM   #22 (permalink)
I found the turbos
Jerggy13's Avatar
Drives: GranTurismoOmologato
Trader Rating: (13)
Jerggy13 Level 1Jerggy13 Level 1Jerggy13 Level 1
Originally Posted by JonsRT
Yeah. Here are all the parts you need from the dealer. Only thing else you need is a prop. valve from an ES model....Its the one with 6 ports on it instead of 4.
The following parts are needed:
MB618846 x1ea - Line from MS to PV
MB618849 x1ea - Line from MS to PV
MB618840 x1ea - Line from PV to RH
MB618843 x1ea - Line from PV to LH <--this one was a royal pain!
MB857842 x1ea - Master Cylinder rebuild kit
MB238309 x2 - Master Cylinder to resivor seals <--also a pain, def
recomend putting a little oil to install seals
All the lines were less than $40 with my good buddy discount. However the rebuild kit was $50 or so. Let me know if you need anything.
Jon
very cool
Thanks a TON!
Jerggy13 is online now   Reply With Quote
Old 05-02-2006, 12:27 AM   #23 (permalink)
Aged Member
JonsRT's Avatar
Drives: 91 RT/TT
Trader Rating: (25)
JonsRT Level 2JonsRT Level 2JonsRT Level 2JonsRT Level 2
Originally Posted by Jerggy13
very cool
Thanks a TON!
Hey man not a problem. It took me and my parts guy at the dealership 1 1/2 hours working with CAPS to get the right ones. Glad I could help!
Jon
BTW having the motor and tranny out makes it a breeze!
Our experience of the past and of those dear to us is not lost at all, but remains richly within us.
1991 Stealth RT/TT Garage Ornament..... Resurrected March 09 Dead again July 09.......dam junkyard motor.....
Originally Posted by Jeremy C
Bah. Just start offing everyone with an IQ below 95. So many problems solved by one quick action (traffic, idiot lawsuits, get rich quick scams, etc).
JonsRT is offline   Reply With Quote
Old 05-02-2006, 01:09 AM   #24 (permalink)
Getrag Rebuilder
Steve3kgt's Avatar
Trader Rating: (18)
Steve3kgt is an unknown quantity at this point
Thanks for posting this guys... I've got the engine and trans out now and will be deleting my ABS before putting everything back together.
Steve3kgt is offline   Reply With Quote
Old 05-02-2006, 01:49 AM   #25 (permalink)
vehicular thaumaturgist
Multiades's Avatar
Drives: 1994 Stealth TT
Multiades is an unknown quantity at this point
So far, I'm the only other person to have done one of these modifications. I don't have many pics, but we did ours more-or-less concurrently, and using most of the same routing. I might be able to dig up a couple pics of my car that would enhance what Clint has already posted.
The Pansy Patrol - a 3000GT/Stealth car blog with how-tos
Pearl Yellow 1994 R/T TT w/84k - FOR SALE! new 4-Bolt factory short block, DR StgII heads, Titan TD05 headers, 14B turbos w/ ported 7cm^2 housings, 3" minimum-bend catless exhaust, SCE oil pan, RPSII clutch, Fidenza flywheel, OZ F1 Plus 17x9.5" wheels, Kumho Ecsta MX 245/45 tires, Drweldin DSM SMICs, 3SX engine mounts (Maximal solid front), GReddy 60mm P/H/W boost, Carbotech Panther Plus & Bobcat pads w/ slotted/drilled rotors, KSport GT-Pro coilovers, Maximal rear camber arms, SCE balljoints, ABS delete w/ cockpit-mounted Wilwood proportioning valve, AC delete, EGR/evap/dashpot delete, cruise/vacuum-tank delete, '95 Lexan headlights, McCulloch 4300K HIDs, GReddy Type-S BOV, solid shift bushings; Misc Parts: Walbro341, 20# fixed-back seats, Accelerated Moto catch can
Multiades is offline   Reply With Quote
Old 05-02-2006, 02:01 AM   #26 (permalink)
I found the turbos
Jerggy13's Avatar
Trader Rating: (13)
Jon
motor and tranny are still in car, I guess this is one of those mods that waits until i blow it up
Old 05-02-2006, 11:04 AM   #27 (permalink)
3SX FTL
Struggly's Avatar
Drives: Viciously
It's not that bad of a job even with the engine in the car. When Chris (Multiades) did his delete, his engine was in, and when we did another delete on Henry Cipolla's car (HenryC) that retained the stock prop. valve, we had the engine in the car.
Clint
Old 05-20-2006, 10:45 AM   #28 (permalink)
Twin Turbo Owner
97mits3kgtSOHC's Avatar
Drives: 95 Pearl White VR4
Trader Rating: (97)
97mits3kgtSOHC is an unknown quantity at this point
bump for a great thread....
so my brake pedal was going to the floor but brakes still worked....i replaced my master and they work but still feel not as tight....if i pump them once my brakes are tighter....if its my abs would disconnecting the abs fuse prove this theory? and if i disconnect it and reconnect it will it work again?
1995 Mitsubishi 3000gt Vr4 - Pearl White
Dr Stage 2 Heads, Dynamic Racing 16ts, New OEM Shorty...BPU...99 front end, intrax/kybs with chrome saleens....interior - corbeau cr-1's, defi bf's......
97mits3kgtSOHC is offline   Reply With Quote
Old 05-20-2006, 11:30 AM   #29 (permalink)
Mr. Chocolate
AudibleSilence's Avatar
Drives: 1997 3000gt VR4
Trader Rating: (49)
AudibleSilence Level 2AudibleSilence Level 2AudibleSilence Level 2AudibleSilence Level 2AudibleSilence Level 2
Doesn't your datalogger disable the ABS anyway?
Cars Owned:
1992 Dodge Stealth RT (sold)
1992 Mitsubishi 3000GT VR4 #1 (parted)
1992 Mitsubishi 3000GT VR4 #2 (sold)
1993 Mitsubishi 3000GT VR4 #1 (KIA)
1993 Mitsubishi 3000GT VR4 #2 (sold)
1994 Mitsubishi 3000GT VR4 (sold)
1994 Mitsubishi 3000GT Base - awd/atx (sold)
1997 Mitsubishi 3000gt VR4 (sold)
AudibleSilence is offline   Reply With Quote
Old 05-20-2006, 02:45 PM   #30 (permalink)
Twin Turbo Owner
Trader Rating: (97)
i didnt think so....then again i dont have it hooked up all the time
