Old 05-01-2006, 12:08 AM   #11 (permalink)
Aged Member
JonsRT's Avatar
Drives: 91 RT/TT
Trader Rating: (25)
JonsRT Level 2JonsRT Level 2JonsRT Level 2JonsRT Level 2
Default Re: Pics of full ABS delete: Custom lines and Wilwood prop valve in center console
Looks great. I did mine a couple of months ago. I used a Stock non-abs Prop. valve and ordered the stock brake lines from Mitsu. I didn't want to mess with bending my own or having to worry about my own flaring. Was easy but its good to see another way to do it.
-Jon
Oh and my ABS did cause a wreck. I took out 4 other cars when it gave..... Thank goodness for the crashbar!
Our experience of the past and of those dear to us is not lost at all, but remains richly within us.
1991 Stealth RT/TT Garage Ornament..... Resurrected March 09 Dead again July 09.......dam junkyard motor.....
Originally Posted by Jeremy C
Bah. Just start offing everyone with an IQ below 95. So many problems solved by one quick action (traffic, idiot lawsuits, get rich quick scams, etc).
JonsRT is offline   Reply With Quote
Old 05-01-2006, 12:41 AM   #12 (permalink)
I found the turbos
Jerggy13's Avatar
Drives: GranTurismoOmologato
Trader Rating: (13)
Jerggy13 Level 1Jerggy13 Level 1Jerggy13 Level 1
-Jon
do you have the break down on parts needed to convert to the non abs line?
Jerggy13 is offline   Reply With Quote
Old 05-01-2006, 12:52 AM   #13 (permalink)
3/S enthusiast
andyvr4's Avatar
Drives: 91 VR-4, 99 Zx2
andyvr4 is an unknown quantity at this point
I'd be interested in this also, I have mine disabled through the computer right now, but it seems stupid to keep all the extra stuff when I'm not even using it.
If you live in the Delaware, Maryland, or Virginia area check out our 3si chapter forum
andyvr4 is offline   Reply With Quote
Old 05-01-2006, 10:00 AM   #14 (permalink)
Wanted: Traction Problems
badass3000's Avatar
Drives: 18 Y.O. "badass" VR4
Trader Rating: (24)
badass3000 is an unknown quantity at this point
How much $$$?
how about a write up?
badass3000 is online now   Reply With Quote
Old 05-01-2006, 01:00 PM   #15 (permalink)
3SX FTL
Struggly's Avatar
Drives: Viciously
Struggly Level 1Struggly Level 1
Originally Posted by badass3000
How much $$$?
I'm going to do a full writeup on this fairly soon. For now, here's a general parts list:
Prop valve: $40
90/10 copper-nickel line: $120 (60 bucks per coil and you need just a little more than one to complete the car. Plus, it's good to have extra in case you screw up a line.)
Fittings: 2 tees at $30 each (these tees have an eyelet so you can bolt them to the car)
1 or 2 unions at $20 each (I think)
8 M8x1.25 inverted flare line ends: usual price for these
8-10 M8x1.25 bubble flare ends: usual price
Total for fittings was about 150 bucks I think.
Flaring tool rental: $50 dollars a week. Shouldn't need more than a day or two.
Miscellaneous L-brackets (to mount prop valve) and clamps to retain lines: 10 bucks
Total, depending on where you source fittings (I probably overpaid some for mine), should be around 350 bucks.
Clint
The Pansy Patrol
1994 Mazda Protege DX: 260K miles, DOHC 1.8L swap, rear disc brake conversion, poorly-designed header, some cheap-ass suspension upgrades, Carbotech XP8/AX6, 15x7 +30 Kazera KZ-M w/ Avon Tech Ra slicks, other crap here and there (like an air filter that doesn't have 1/4 of a million miles), arguably the fastest piece of shit in New England and no one can do anything about it
Struggly is offline   Reply With Quote
Old 05-01-2006, 02:12 PM   #16 (permalink)
OMGOMGOMGOMG
J-Ville VR-4's Avatar
Drives: 91 VR-4
Trader Rating: (13)
J-Ville VR-4 is an unknown quantity at this point
Very nice 2 of my friends and I did this to my friends 93 LS1 RX7 with the same prop valve and 90/10 line, that stuff kicks ass! Unfortunately we tried getting away with a shitty flaring tool my friend had (it did double inverted flares, but apparently not good enough) and had a lot of leaks, so we took all the lines to a brake shop and had them flare them to be safe, then we shaped them and installed it all. I need to make a trip back by his house again soon (he has about half of my tools over there ) and I'll get some pics, that car is so badass
Jake - 91 VR-4
J-Ville VR-4 is offline   Reply With Quote
Old 05-01-2006, 02:23 PM   #17 (permalink)
3SX FTL
Struggly's Avatar
Drives: Viciously
[quote=J-Ville VR-4]Unfortunately we tried getting away with a shitty flaring tool my friend had (it did double inverted flares, but apparently not good enough) and had a lot of leaks, so we took all the lines to a brake shop and had them flare them to be safe, then we shaped them and installed it all. QUOTE]
Originally I had thought I could get away with a crappy flaring tool, but there's simply no way to make clean inverted flares. With the bench tool, they come out perfect almost every time. If I was doing this job more often, I'd buy one.
Clint
Old 05-01-2006, 02:27 PM   #18 (permalink)
TajMan's Avatar
Drives: 93SOHCMTX
Trader Rating: (25)
TajMan is an unknown quantity at this point
I DID bump someone once when there was snow on the road and the ABS kicked in. Yeah old car's ABS sucks.
former 3/Ss: '92 R/T, '94 3KGT, modded '92 R/T TT
'93/94/97 Stealth-3000GT SOHC MTX 277K miles
-custom 1G R/T-2G GT front bumper
-TT wheels
-2G TT front brakes
'79 Yamaha XS11 special
TajMan is offline   Reply With Quote
Old 05-01-2006, 02:36 PM   #19 (permalink)
Twin Power Pellets
Drives: 94 Mitsu 3000GT VR4
pacman3000gt Level 1pacman3000gt Level 1
Originally Posted by Struggly
Brake pedal feel has definitely improved, which confirms my long-standing suspicion that the shittiness of the stock ABS contributed heavily to the poor pedal feel of the 3/S.
Even with the abs system completely disabled via all the fuses?
1994 Mitsubishi 3000gt VR4 - Black
AEM EMS | 700cc | Big16G | JPDC TD05 plates | FMIC | SouthBend DXD-F/UR Aluminum Flywheel | Blitz DSBC | Tanabe Hyper Medallion | Volk Racing LE37T | BFG KDW2 | R1Concepts Rotors
pacman3000gt is offline   Reply With Quote
Old 05-01-2006, 07:36 PM   #20 (permalink)
Aged Member
JonsRT's Avatar
Drives: 91 RT/TT
Trader Rating: (25)
Yeah. Here are all the parts you need from the dealer. Only thing else you need is a prop. valve from an ES model....Its the one with 6 ports on it instead of 4.
The following parts are needed:
MB618846 x1ea - Line from MS to PV
MB618849 x1ea - Line from MS to PV
MB618840 x1ea - Line from PV to RH
MB618843 x1ea - Line from PV to LH <--this one was a royal pain!
MB857842 x1ea - Master Cylinder rebuild kit
MB238309 x2 - Master Cylinder to resivor seals <--also a pain, def
recomend putting a little oil to install seals
All the lines were less than $40 with my good buddy discount. However the rebuild kit was $50 or so. Let me know if you need anything.
Jon
