Old 10-21-2008, 11:57 PM   #101 (permalink)
99 SLut
Adollarwodbnice's Avatar
Drives: 99 SL, 96 GSXR
Trader Rating: (9)
Adollarwodbnice Level 1Adollarwodbnice Level 1
Default Re: Pics of full ABS delete: Custom lines and Wilwood prop valve in center console
Your threads all make me wanna rip everything outta my car... I need to pull the fuse and see if I like no ABS.
Bet it was a fuckin pain in the ass to get all that tubing to fit where you want it and route it....
Adollarwodbnice is offline   Reply With Quote
Old 10-22-2008, 12:58 PM   #102 (permalink)
OMGOMGOMGOMG
J-Ville VR-4's Avatar
Drives: 91 VR-4
Trader Rating: (13)
J-Ville VR-4 is an unknown quantity at this point
That 90/10 tubing is surprisingly easy to work with, its not nearly as bad as you would think.
Jake - 91 VR-4
J-Ville VR-4 is offline   Reply With Quote
Old 10-22-2008, 01:41 PM   #103 (permalink)
3SX FTL
Struggly's Avatar
Drives: Viciously
Struggly Level 1Struggly Level 1
Yes, very easy to work with.
Robb, the bending/fitting was a breeze. I had my engine out, which helped, but the Cunifer line is so tolerant of bending that I didn't need to pre-form any lines. I cut them to length, flared them, and then just sort of shoved the line into place. I was even able to straighten inaccurate bends and then rebend. Try that with stainless steel line.
Clint
The Pansy Patrol
1994 Mazda Protege DX: 260K miles, DOHC 1.8L swap, rear disc brake conversion, poorly-designed header, some cheap-ass suspension upgrades, Carbotech XP8/AX6, 15x7 +30 Kazera KZ-M w/ Avon Tech Ra slicks, other crap here and there (like an air filter that doesn't have 1/4 of a million miles), arguably the fastest piece of shit in New England and no one can do anything about it
Struggly is offline   Reply With Quote
Old 10-22-2008, 01:43 PM   #104 (permalink)
My92Stealth's Avatar
Drives: 91TT, 93ES
Trader Rating: (37)
My92Stealth is an unknown quantity at this point
I had my engine in and everything and I just bent up/shoved the lines as I went along as well, and used coated SS. Worked well.
My92Stealth is offline   Reply With Quote
Old 04-05-2009, 03:08 PM   #105 (permalink)
Drives: 1992 vr4
Brad0700 is an unknown quantity at this point
Anyone have a link of where I can get the 90/10 copper nickel line?
Brad0700 is offline   Reply With Quote
Old 06-07-2009, 03:19 PM   #106 (permalink)
Stuff and Junk and Things
EvanH's Avatar
Drives: NO PASSENGERS!!
Trader Rating: (7)
EvanH is an unknown quantity at this point
subscribed
EvanH is offline   Reply With Quote
Old 06-07-2009, 03:43 PM   #107 (permalink)
I've been here way too long
Colt45 GTO's Avatar
Drives: Like an Idiot
Colt45 GTO Level 1Colt45 GTO Level 1
how much was the wilwood valve?
looks like something i need to do in times of boredom.
Colt45 GTO is offline   Reply With Quote
Old 10-22-2009, 01:29 PM   #108 (permalink)
Drives: 91TT, 93ES
Trader Rating: (37)
Someone PM'd me for clarification so I drew up this diagram. It's how the lines are routed with the NONabs prop valve.
You tear out all the lines in the front of the car, but be sure you leave the lines that go to the rear
The prop valve in the picture below is as it sits in the car, as if you were standing in front of the engine lookign towards it. It is labeled to show which ports go to where.
Old 10-22-2009, 11:16 PM   #109 (permalink)
3SX FTL
Struggly's Avatar
Drives: Viciously
FedHill Brake Line - Where to buy brake line, fuel line, brake line flaring tools, brake line nuts and brake line fittings
Or just search for "Cunifer brake line".
Clint
