LinkBack | Thread Tools |
#91 (permalink) |
My ABS pump went out the other day and I was thinking about getting a new one. This looks like an even better idea. Can this all be done for under $100?
#92 (permalink) |
Im getting confused. Everyone shows the prop valve being used on the back brakes and someone else just said the front brakes. Which one is it and how exactly does this prop valve function?
Terry
DR900 Powered 96 Red VR4
#93 (permalink) | |
3SX FTL
This is a link to a white paper on brake proportioning on Stoptech's website: http://www.stoptech.com/tech_info/wp...g_valves.shtml. It'll get you up to speed on valve design, knee point, and help you to understand why one would use a proportioning valve in one place but not another. Clint
The Pansy Patrol
1995 3000GT VR-4 but real niggaz don't give a fuck: V1, comprehensive denastificizzle, vishizzous accessory biznelt mod, K&N, Greddy Profec B S-P-to-tha-izzec II, S-AFC, Walbro 341, DSM 450s, n AEM UEGO; battery relocizzle K-R-to-tha-izzank Vents, EK2MFG fizzle rizzle loop n plenum spaca, lethal_vr4 manual gang bangin' rizzay, SKVR4 AWS delete, polyurethane motor mounts, adjustable control arms, SS brakes lines, n EGR blockoffs; Custom brakes lines wit cockpit-mounted adjustable proportion'n valve, 332mm Stoptechs, Carbotech Brotha Plus/Porterfield Rizzle ATE Pusha Blue, OZ Gang Bangin' F1 Plus 17x9.5 +36mm, Yokohama AVS ES100 275/40/17, Tein Fizzle w/EDFC n SCE Casta/Camba Plates, SCE oilpan, DSM sidemounts, DN Precat Eliminizzles 13G/9B combo (9psi springs), J-spec final drive, RPS flyhweel n Spec II clutch, IPO propane, ATR downpipe, tizzest pipe, n Single Shot1994 Mazda Protege DX: 260K miles, DOHC 1.8L swap, rear disc brake conversion, poorly-designed header, some cheap-ass suspension upgrades, Carbotech XP8/AX6, 15x7 +30 Kazera KZ-M w/ Avon Tech Ra slicks, other crap here and there (like an air filter that doesn't have 1/4 of a million miles), arguably the fastest piece of shit in New England and no one can do anything about it ![]() |
#96 (permalink) |
quick question why not just run a NA non abs valve in the stock location on the fire wall and the new front lines?
Knifed/Shot Peen Forged Crank, Shot Peened Rods w/ ARP Studs, 93mm Ross Pistons, 1mm Valves, 3sx Spring Kit, 99 Lifters, Ported Heads/Lower/Upper Intake/15g Housings/ Manifolds Stillen Dp, Custom 3in Exhaust, Direct Feed Fuel 450cc, Aeromotive FPR, Maft Pro, Front Mount, Spec flywheel Stage 2 Clutch Shifter Bushing Custom Sub Box Alpine Deck Zex kit Repainted Gunmetal 99 Bumper 98 Wing 18 inch gunmetal rims etc etc
http://www.3si.org/forum/showthread....89#post4621589 http://www.3si.org/forum/showthread.php?t=395449 |
#97 (permalink) |
You can, and thats what I did. Except I just picked up some lengths of brake line and bent up my own.
Advantage with struggly's method is it's more performance oriented.
![]() 1991 RT/TT Pearl White/Porn Red 15g's + supporting, other mods. 92 Stealth Base DD. |
#98 (permalink) |
crash & rebuild
Does anyone know of a way to get brake proportion adjustment and retain the ABS? I'd like to get the rear end a little more lively when braking into a turn on the track but not loose the ABS when traveling autobahn speeds.
#99 (permalink) | ||||
Master of the Universe
I love the work you did - however, why did you choose copper tubing?
It is an inherently bad and possibly dangerous choice for something like this.. The flares are known to suddenly fail without any warnings and thus make copper tubing a bad choice for brake lines.
-uli
#100 (permalink) | ||
3SX FTL
It is not pure copper tubing, nor is it a coated copper. It is a copper-nickel-iron alloy that is much more resistant to corrosion and weakening than steel and also much easier to work with. It's also DOT approved. This tubing (Cunifer tubing) is widely used for brake lines and is particularly popular in the UK. I've seen it on several local SCCA club racers too. It is also the OEM brake tubing for several manufacturers. If you google "Cunifer brake line" you'll pull up many threads from what I guess I'd call reputable forums (grassrootsmotorsports.com, aflabb.com, etc.). A bit of an old article, but still a good read: Copper.org: Applications: Automotive - Hydraulic Brake Tube Quote:
