Old 04-30-2006, 03:17 PM   #1 (permalink)
3SX FTL
Struggly's Avatar
Drives: Viciously
Struggly Level 1Struggly Level 1
Default Pics of full ABS delete: Custom lines and Wilwood prop valve in center console
Here's my car, with custom lines and a Wilwood proportioning valve in the center console.
Below are small versions of 3 of many pictures. Go to the links below for full-size. I apologize in advance for the awkwardness and crappiness of some of the photos. There isn't exactly a lot of room to manipulate a camera in a lot of these places.
The new lines coming off the master cylinder (if you look down on the strut tower you can see the tee and the lines to the front left and right brake lines).
The Wilwood knob-style valve mounted where the cigarette lighter used to be.
The tee splitting the line originating at the prop valve and coming through the floorpan and along the driveshaft tunnel. These lead to the rear calipers.
More photos:
Full size of master cylinder photo above:
http://www.pansypatrol.com/people/cl...er1000x750.jpg
Driver's side firewall. You can see the line going to the pass. front caliper:
http://www.pansypatrol.com/people/cl...ll1000x750.jpg
Passenger side of engine bay/firewall. No more huge bundle lines going to ABS pump:
http://www.pansypatrol.com/people/cl...sengerside.jpg
Line turning through firewall right above shifter cables:
http://www.pansypatrol.com/people/cl...ghfirewall.jpg
Now inside car, heading towards center console and prop. valve:
http://www.pansypatrol.com/people/cl...hfirewall2.jpg
Line heading to prop valve:
http://www.pansypatrol.com/people/cl...opropvalve.jpg
Proportioning valve mount:
http://www.pansypatrol.com/people/cl.../propvalve.jpg
Turning down under e-brake cables and through floor:
http://www.pansypatrol.com/people/cl...ghfloorpan.jpg
Full size of Underside of hump photo above:
http://www.pansypatrol.com/people/cl...sideofhump.jpg
From rear tee to rear caliper:
http://www.pansypatrol.com/people/cl...driverrear.jpg
Continued:
http://www.pansypatrol.com/people/cl...riverrear2.jpg
From tee to other rear caliper:
http://www.pansypatrol.com/people/cl...sengerrear.jpg
Continued:
http://www.pansypatrol.com/people/cl...engerrear2.jpg
Coming up into one wheelwell and joining SS flex line:
http://www.pansypatrol.com/people/cl.../wheelwell.jpg
The knob:
http://www.pansypatrol.com/people/cl...ilwoodknob.jpg
Clint Fralick
The Pansy Patrol
1994 Mazda Protege DX: 260K miles, DOHC 1.8L swap, rear disc brake conversion, poorly-designed header, some cheap-ass suspension upgrades, Carbotech XP8/AX6, 15x7 +30 Kazera KZ-M w/ Avon Tech Ra slicks, other crap here and there (like an air filter that doesn't have 1/4 of a million miles), arguably the fastest piece of shit in New England and no one can do anything about it
Struggly is offline   Reply With Quote
Old 04-30-2006, 03:34 PM   #2 (permalink)
3KGTTusch's Avatar
Drives: Wishing
3KGTTusch is an unknown quantity at this point
Default Re: Pics of full ABS delete: Custom lines and Wilwood prop valve in center console
What are the advantages of removing your abs?
3KGTTusch is offline   Reply With Quote
Old 04-30-2006, 03:58 PM   #3 (permalink)
TEXAS!! FIGHT!!
AdamVR4's Avatar
Drives: '93 3000GT VR-4
Trader Rating: (22)
AdamVR4 Level 2AdamVR4 Level 2AdamVR4 Level 2AdamVR4 Level 2
Sweet! Thank you for doing this!
PEARL WHITE '93 VR-4 // Now running...
E16G's: 10.573 @ 135.01
(Trevor owns me )
E16G's: 11.28 @ 124.7
(Pure pump gas ET record )
14B's: 11.10 @ 127.3
(AWD 14B ET record. Take THAT, Trev! )
9B's: 12.78 @ 107.1
Congrats to the current top 10 members!!
DynamicRacing: US 3S Top 10 Fastest List
10th Amendment: The powers not delegated to the United States by the Constitution, nor prohibited by it to the States, are reserved to the States respectively, or to the people.
GIVE ME LIBERTY, OR GIVE ME DEATH!
AdamVR4 is online now   Reply With Quote
Old 04-30-2006, 04:01 PM   #4 (permalink)
chuck norris hater
rexkwando's Avatar
Drives: 98 vr4
Trader Rating: (6)
rexkwando is an unknown quantity at this point
how long did it take you to do this?
rexkwando is offline   Reply With Quote
Old 04-30-2006, 04:08 PM   #5 (permalink)
We live here.
VR-4ever's Avatar
Drives: 4.6is X5 w/ blower.
Trader Rating: (13)
VR-4ever is an unknown quantity at this point
weight/cleanliness
good work Clint.
VR-4ever is offline   Reply With Quote
Old 04-30-2006, 04:09 PM   #6 (permalink)
I miss my boost.
Synchro's Avatar
Drives: '01 S2000
Trader Rating: (10)
Synchro is an unknown quantity at this point
You won't be forced to slam into the car in front of you when you try to apply the brakes on wet pavement and the ABS kicks in - causing your brakes to fail.
The ABS system on these cars is terrible. It's nearly caused me to wreck three times.
Thanks for the pictoral Struggly!
Synchro is offline   Reply With Quote
Old 04-30-2006, 04:11 PM   #7 (permalink)
"The Fisherman"
pyun's Avatar
Drives: around scaring birds
Trader Rating: (75)
pyun is an unknown quantity at this point
Awesome Clint! Thanks for the write up!
pyun is offline   Reply With Quote
Old 04-30-2006, 06:43 PM   #8 (permalink)
3/S enthusiast
andyvr4's Avatar
Drives: 91 VR-4, 99 Zx2
andyvr4 is an unknown quantity at this point
You can actually stop on slick surface. I diffentely agree with the other posts the abs on these cars suck from the factory. I've had mine disabled pretty much since I got the car.
If you live in the Delaware, Maryland, or Virginia area check out our 3si chapter forum
andyvr4 is offline   Reply With Quote
Old 04-30-2006, 09:00 PM   #9 (permalink)
3SX FTL
Struggly's Avatar
Drives: Viciously
Thanks for the compliments.
I thought I'd post up a few more details about the delete. The lines are 90/10 copper nickel alloy, not stainless steel. (Most of you can probably tell that from the color, but anyway.... ) They were not pre-bent of course, nor were they pre-flared; the copper/nickel line comes in 30 foot rolls. The line is very soft and can be bent by hand. I figured I'd use a spring bender to prevent kinking, but in the end I didn't use any bending tools.The line is forgiving enough that it actually tolerated some straightening and re-bending, and it likes extreme bend angles just fine, as you can see.
To make the lines, I used thick solder to make a line "template" (so to speak), then took it off the car and straightened it to get a length measurement. Then, after flaring a copper/nickel line of the proper length, I simply shoved it into place. I was able to do all my bending with the line in the car, which would have been impossible with conventional line.
A normal flaring tool will not work. For one, they don't make double flares. And, for another, the tees I used require bubble flares, which you can't accurately make with a normal flaring tool even if you're inventive. I used a bench mounted tool that clamps the line between two blocks and then presses a flaring die against the line end. It worked exceptionally well; all of the flares on those lines were made on the first try and none of them leaks after over 2000 miles of driving.
Brake pedal feel has definitely improved, which confirms my long-standing suspicion that the shittiness of the stock ABS contributed heavily to the poor pedal feel of the 3/S.
Clint
Old 04-30-2006, 09:45 PM   #10 (permalink)
I found the turbos
Jerggy13's Avatar
Drives: GranTurismoOmologato
Trader Rating: (13)
Jerggy13 Level 1Jerggy13 Level 1Jerggy13 Level 1
i need to do that..........
i have been running with the abs fuse pulled for about 3 years
Jerggy13 is offline   Reply With Quote
