Old 03-13-2008, 07:19 PM   #1 (permalink)
noob-saibot
my3kgtvr4's Avatar
Drives: the women crazy
my3kgtvr4 Level 2my3kgtvr4 Level 2my3kgtvr4 Level 2
Default passenger window not working
well my passenger window only works on the passenger side button. it still rolls up and down, but i have to reach over and push the passenger side button. so its not the motor. but outside of stereos i have no electrical experience. any ideas on where to start? or what my problem is
my3kgtvr4 is offline   Reply With Quote
Old 03-13-2008, 07:37 PM   #2 (permalink)
HLxDrummer's Avatar
Drives: 3000GT, '71 Mustang
HLxDrummer Level 3HLxDrummer Level 3HLxDrummer Level 3HLxDrummer Level 3
Default Re: passenger window not working
I would test the driver's side switch if you have the manual or access to one. It's been a while since I had the stuff apart, but I think the wiring goes from the driver's switch to the passenger to the motor, but don't quote me. If it's not the switch then check the continuity of the wires going from the driver's side to the passenger's side.
My car's window didn't work at all and ended up being cut/corroded wires in the driver's door jam, just for future reference.
Good luck!
1994 3000GT SL - Old Daily Driver SOLD
Go: 3SX Downpipe with Custom DP Back Exhaust, K&N Filter
Show: 3SX Clear Corners, New Custom Paint
1993 VR4 with 150K miles - Daily Driver/Weekend Warrior/Sole Method of Transportation
Go: eBay Tanabe Concept G Blue Replica TBE, HKS SSQV, Maximals TC Bracket, PST Two Piece Steel/Aluminum Driveshaft
Monitoring: Palm M100 with MMCD, STRI X-Line Boost Gauge
Maintenance: 120K with oil pump and main/rod bearings, MSD 8.5MM wires, NGK Platinum plugs, Redline/Castrol Fluids, New ECU, Lowes Pressure Tester, New IAC/PVC/etc.
Show: '99 Garnish, Alan's Snake Eyes, Stealthy Wiper Mod, 3SX Aluminum Pedals
HLxDrummer is offline   Reply With Quote
Old 03-13-2008, 08:09 PM   #3 (permalink)
noob-saibot
my3kgtvr4's Avatar
looks like ill be taking the panels off my door. thanks for the input
Old 06-02-2008, 04:45 AM   #4 (permalink)
fastfalcon94's Avatar
Drives: 94 Panama Pearl VR-4
Trader Rating: (56)
fastfalcon94 Level 2fastfalcon94 Level 2fastfalcon94 Level 2
Did you ever get it working? Mine's been doing this for a while now, exact same thing. I think it's the switch contacts because before it stopped completely I use to be able to hit the switch 3-4 times then it would work.
Like the Rims in my Avatar? Click Here
fastfalcon94 is offline   Reply With Quote
