Old 11-26-2007, 10:03 PM   #21 (permalink)
thetjkid's Avatar
Drives: dodge stealth r/t
Trader Rating: (10)
thetjkid is an unknown quantity at this point
Default Re: Part number for VSS removal tool (valve spring compressor)???
that kit looks awesome... does it work well?
thetjkid is offline   Reply With Quote
Old 11-27-2007, 05:11 PM   #22 (permalink)
1stStealthN/A's Avatar
Drives: 94 SL, 92 VR4, 92 TT
1stStealthN/A is an unknown quantity at this point
[quote=thetjkid;4625690]that kit looks awesome... does it work well?
[quote]
Yes, it works great. A 3/4" pipe extension gives you more leverage. I bought some longer bolts and 1/2" washers to get the main brackets above the cam bearing cap alignment sleeves. Be sure to have a extendible pen magnet to grab the keepers. The magnet makes it easy to install the keepers too. You must have the cams out to use this tool.
Good luck....
1stStealthN/A is offline   Reply With Quote
Old 11-27-2007, 05:57 PM   #23 (permalink)
Oh SNAP!!!
mywetdream's Avatar
Drives: 94 TT, 69 427 vette
Trader Rating: (19)
mywetdream Level 7mywetdream Level 7mywetdream Level 7mywetdream Level 7mywetdream Level 7mywetdream Level 7mywetdream Level 7
i am also interested in this tool..more info please...
If you feel I have answered your question..leave me some rep...thanks
**1ST place RMG 07 best engine**
Like the snake the BITE must be felt and not seen, goin super, until then super slow want some!!!
1st car with the Enkei RZ-5 18''x8.5''
*534x306*
1994 Dodge Stealth R/T TT~Pearl Yellow
mywetdream is offline   Reply With Quote
Old 11-27-2007, 08:15 PM   #24 (permalink)
The quality is good and I have used it on 4g63s and 6g72s. I guess you can use it on almost any OHV or OHC engine. It works much better than the Snap-On you push down with your hand. The leverage makes the job easy.
