Old 09-12-2008, 06:38 AM   #71 (permalink)
oohnoo's Avatar
Trader Rating: (156)
oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7
Default Re: HELP I need water pump's o-ring part number
Correct on the o-ring / MD147332
Belts are year dependent I believe
Originally Posted by BlackDream View Post
Anyone can tell me for sure the part number for the oring that you need to change with water pump? I think it is MD147332 ?
edit: anyone know the part number for the service belts too?
oohnoo is online now   Reply With Quote
Old 09-22-2008, 09:26 AM   #72 (permalink)
VA 3S
Tool Man's Avatar
Drives: 94 3000GT NA
Trader Rating: (27)
Tool Man Level 7Tool Man Level 7Tool Man Level 7Tool Man Level 7Tool Man Level 7Tool Man Level 7Tool Man Level 7Tool Man Level 7Tool Man Level 7Tool Man Level 7Tool Man Level 7
Default If you have CAPS I need a part number please :-)
I need the part number for the high pressuer fuel line that goes from the pump to the hard line under the car. Thanks in advance.
Pics of my car, click me!_______ August 2006 ROTM
DSM 13Gs, gutted pre-cats, 3" after market downpipe with 3" high flow Cat,Custom 3" stainless steel catback dual exhaust,Modified oil pan & Stainless steel oil return lines,APEXI S-AFC2, Manual Boost Controller, Front and rear Polly mounts. Running waste gate for now ( 7 PSI ) until I get to a Dyno.
Tool Man is offline   Reply With Quote
Old 09-22-2008, 10:05 AM   #73 (permalink)
'92 VR4
ras463us's Avatar
Drives: 1992 VR4
Trader Rating: (13)
ras463us Level 3ras463us Level 3ras463us Level 3ras463us Level 3
Default Re: If you have CAPS I need a part number please :-)
Looks like the original number was MB433988, and has been replaced by MR161794
Hope this helps!
Ricer: from the latin word Ricarius meaning to suck at everything you attempt
A person who makes unnecessary modifications to their most often import car (hence the term "rice") to make it (mostly make it look) faster. The most common modifications are (but not limited to):
- Huge exhaust that serves no purpose but to make the car louder
- Large spoiler on the back that looks like something Boeing made for the 747
- Lots of after-market company stickers they don't have parts from, but must be cool
- Expensive rims that usually cost more than the car itself
- Body kit to make the car appear lower, usually accented with chicken wire
- Clear tail lights and corner signals
- A "performance intake"- a tube that feeds cold air to their engine usually located in areas of excessive heat (behind or on top of the engine)
- Most of these riced cars (a.k.a. rice rockets or rice burners) are imports; Honda Civics, Accords, Integras, CRXs, RSXs, Del Sols Mitsubishi Eclipses, Lancers, Subaru Imprezas, however there are some domestics such as Chevrolet Caviliers, Dodge Neons, Ford Focus; small, slow, economy cars designed specifically to go slow. Please note that some 3000gt's Supras, Skylines, WRX's and other higher performance imports are designed to go fast, and are therefore not always considered rice, but it really depends on the severity of the case.
(courtesy urban dictionary)
ras463us is offline   Reply With Quote
Old 09-22-2008, 10:34 AM   #74 (permalink)
VA 3S
Tool Man's Avatar
Trader Rating: (27)
Default Re: Part # Help Thread! If you have CAPS, help someone out!
That did, + rep for you!!!!!!!!!!!!!
Old 10-08-2008, 01:52 PM   #75 (permalink)
Dec. 2001
TwinTurboKid's Avatar
Drives: 91 & 94 Stealth TT
Trader Rating: (37)
TwinTurboKid Level 7TwinTurboKid Level 7TwinTurboKid Level 7TwinTurboKid Level 7TwinTurboKid Level 7TwinTurboKid Level 7TwinTurboKid Level 7TwinTurboKid Level 7TwinTurboKid Level 7TwinTurboKid Level 7TwinTurboKid Level 7
Can someone confirm these are the right part #'s? They are for my 94 TT.
I can't seem to find Oil Pump and Timing Belt Tensioner part #'s.
Fuel Filter MB658136
Idler pulley MD319022
Oil pick up MD158618
water pump MD972005
Thanks
1991 Dodge Stealth R/T Twin Turbo
MODS|ATR Downpipe|HKS Super Dragger|DN Pre Cat Elims|AEM WB02 Gauge|Ek2mfg Fuel Rail Loop|Polished Fuel Rail|Wrinkle Black Intake Mani|Mirror Red Valve Cover|Injector Harness Cover|Ohio Bob Short Throw Shifter|DN Intake Pipes|Palm Datalogger|TD04L 15G Turbos|EGR Block Off Plates|Vac Reduction|Evap Delete|Cruise Control Delete|A/C Delete|Battery Relocated|E2kmfg Poly Mounts|PTE 680 Injectors|Hotwired Walbro 255lph FP|Snow Performance Water/Meth Injection|Tein Coilovers|18x9 Saleen Replicas| 265/35/18 Sumitomo HTR II|New Shortblock|Rebuilt Heads|IPS FMIC|RPS Max Street|AEM EMS|AEM IAT|AEM 3.5 BAR| Next Up: Tuning AEM
1994 Dodge Stealth R/T Twin Turbo Under Construction
TD05's & Much More
TwinTurboKid is online now   Reply With Quote
Old 10-08-2008, 03:04 PM   #76 (permalink)
varicella's Avatar
Drives: Black '98 VR4
varicella is an unknown quantity at this point
the easiest way for you to verify these is to go to cherry hill (http://www.trademotion.com/partlocat...?siteid=214619) go to the parts search section, enter your part number and "mitsubishi" and do a search, it will tell you what the part is for and the years and the retail price and cherryhill (usually the cheapest) price.
Tensioner is MD319040, in caps do part name search for 'tensioner'
Oil pump is MD190982 search in caps lubrication section 12/110
varicella is offline   Reply With Quote
Old 11-15-2008, 05:42 PM   #77 (permalink)
Twin Turbo Owner
97mits3kgtSOHC's Avatar
Drives: 95 Pearl White VR4
Trader Rating: (94)
97mits3kgtSOHC Level 397mits3kgtSOHC Level 397mits3kgtSOHC Level 397mits3kgtSOHC Level 3
can someone tell me what these bolts are for?
MF140292 it says T/M Bolt....u i have two of them
and
MF301372 says T/M....
eghh i have all these parts from rebuilding my car and dont remember where some of these bolts are from....im guessing trans or tcase but i dont remember
97mits3kgtSOHC is offline   Reply With Quote
