Old 09-04-2008, 08:38 AM   #61 (permalink)
Former ROTY :-}
OhioSpyderman's Avatar
Drives: Back and Forth :)
OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7
Default Re: Part # Help Thread! If you have CAPS, help someone out!
Originally Posted by QSpectre View Post
I need the part number for a Crank Pulley Bolt for a 92 VR4. I don't know if they are different for the SOHC or for different years. But I need to find one pretty fast please.
CAPS shows only one for a Z16A chassis (VR4) - MD151793
Hope this helps...
Bob.
95 Caracus Red Spyder VR4
92 Wheat Beige Metallic Stealth TT..Winter DD!!
OhioSpyderman Short Shifter (in both!!!)
Cianci FG Viper Hood/Aerocatch Pins
Quad Carbon Fiber Tipped Borla Catback
SBC-iD Boost Controller (in both!!!)
Stock 18" 6 Spoke Chromies
K&N FIPK
Indiglo Gauges
JimVR4's Remote Start/Top Op Computer
OhioSpyderman is offline   Reply With Quote
Old 09-04-2008, 08:39 AM   #62 (permalink)
varicella's Avatar
Drives: Black '98 VR4
varicella is an unknown quantity at this point
Bolt: 1100A142
Washer: MR994412
I could be more sure if I had your vin.
Most times you can find the part numbers online from cherryhilltriplix:
Welcome to Cherry Hill Triplex Parts !
but sometimes they bury their parts and you can never find them.
varicella is offline   Reply With Quote
Old 09-04-2008, 08:41 AM   #63 (permalink)
varicella's Avatar
Hope this helps...
Bob.
this was superseded by 1100A142
Old 09-04-2008, 09:02 AM   #64 (permalink)
QSpectre's Avatar
Drives: 92 VR-4
QSpectre Level 1QSpectre Level 1
Originally Posted by varicella View Post
Bolt: 1100A142
Washer: MR994412
Vin is: JA3XE74C2NY030444
Thanks for your help!
1992 Fiji Blue VR-4
Works now!
QSpectre is offline   Reply With Quote
Old 09-04-2008, 09:06 AM   #65 (permalink)
varicella's Avatar
Yep, same part number MD151793 superseded by 1100A142. Part is $10 from cherry hill, $14.25 retail
Old 09-04-2008, 09:13 AM   #66 (permalink)
Former ROTY :-}
If you don't mind my asking, how did you find out about the supercede? Call?
Good work btw....I repped ya!!
Bob.
Old 09-04-2008, 09:16 AM   #67 (permalink)
varicella's Avatar
Bob.
haha.. thanks. if you look at the part number in caps sometimes it shows a part number listed below it which is the superceded part#, also you can go to cherry hill's website and put in the part number to check the price and it will tell you if there is a new part number for it
Old 09-04-2008, 09:18 AM   #68 (permalink)
Former ROTY :-}
Thanks for the info!!
Bob.
Old 09-04-2008, 09:20 AM   #69 (permalink)
QSpectre's Avatar
Drives: 92 VR-4
Thank you both for your fast help!! +rep
Old 09-12-2008, 05:37 AM   #70 (permalink)
Cyberwwolf!!
BlackDream's Avatar
Drives: The Blackdream:RT/TT
BlackDream Level 7BlackDream Level 7BlackDream Level 7BlackDream Level 7BlackDream Level 7BlackDream Level 7BlackDream Level 7
Default HELP I need water pump's o-ring part number
Anyone can tell me for sure the part number for the oring that you need to change with water pump? I think it is MD147332 ?
edit: anyone know the part number for the service belts too?
1992 Dodge Stealth RT/TT
Engine: K&N open intake, polished plenum, powdercoated valve cover, polished radiator cover, painted timing belt covers, red silicone hoses,cold air intake, chrome oil cap,Polished engine cover kit,...
Exhaust:Stainsless steel catback with no mufflers and stock tips look,test pipe.
Interior: Stainsless Stell door sills, autometer gauges.
Suspensions: Tein S.tech springs, -2° camber...
---> http://www.dodgestealth.it <---
BlackDream is offline   Reply With Quote
